Hi Folks,
I have bought 2 zwave Neo Coolcam repeaters, they are working well.
But in domoticz they appear as unknown devices.
How can I update domoticz configuration for this device.
I know how to update the Config/manufacturer_specific.xml file, but I need also a XML file in the shenzen_neo folder.
How to create such a file or does somebody has already created such a XML file.
Solved:
I have managed to create (read the manual and looked into other implementations) my own configuration file for this repeater.
If someone is interested please let me know, I can share the configuration file.
Thanks for the help.
Theo.
Solved: How to add Neo Coolcam repeater to domoticz
- Domoticz version: 2024.7
Domoticz v2024.7, running on RP5/RP3B+, Bookworm/docker.
Applications/Devices/plugins:
RP5: Z-wave-JS, MQTT Broker, Homebridge, Milight hub, LMS, Denon, MQTT client/auto, RFXCOM
RP3B+: SolarEdge, P1 Smart meter UBS, Plugwise Anna, LIBGPIOD (Doorbell)
Re: Solved: How to add Neo Coolcam repeater to domoticz
I would like to have that file. I recently purchased a repeater myself and get device unknown
Kind regards
Jimmy
Kind regards
Jimmy
Please share the config
Attached you find the config file.
You also have to add this device into the manufacturer_specific.xml file.
Add the following lines at the end of <Manufacturer id="0258" name="Shenzhen Neo Electronics Co Ltd">
<!-- NAS-RP01Z1 repeater -->
<Product config="shenzen_neo/nas-rp01z1.xml" id="0716" name="NAS-RP01Z1 Repeater" type="0010"/>
Good luck.
Kind regards,
Theo.
Good luck.
Kind regards,
Theo.
- nas-rp01z1.xml
- (6.77 KiB) Downloaded 24 times
