What I mean by the title is if I create a block that says If the Lux level of a sensor is equal to or less than 90 then switch light A on and I then turn light A off manually will it turn it back on again or as it has already run once will that be it until the lux goes above 90 and then back below it again.
Dave
is Blockly a one shot operation ?
- Domoticz version: 2026.3
Re: is Blockly a one shot operation ?
A Blockly script is triggered by a change. The type of change can be set.
See wiki page https://www.domoticz.com/wiki/Blockly#Triggers
So in your case if the trigger is device the lamp will always be switched on if the lux has a value greater than 90. If you switch the lamp off manually after a device change (could be any device) the script is triggered again and the lamp will be switched on.
But as I have no Blockly scripts running I am not 100% sure...
Dave21w
- Domoticz version: Stable
OK looks like I need to do some research, I want the lounge table lamp to come on when my Lux sensor says its below 90 but obviously I need to turn it off when I go to bed !
- madpatrick
- Domoticz version: 2026.1
maybe this will help a bit
It is now a very simple script and you can please with the parameters.
For example with the LUX/TIME/etc...
Dave21w
Thanks for the suggestion, I have implemented something similar as you can see.
This allows me to turn the lamp off early as long as it's below 30 Lux outside without it then coming back on and stops it coming on early in the winter if it goes very cloudy during the day.
solarboy
- Domoticz version: 2024.6
Your "else if" has "<=" which is not correct, it can be "=" or "not ="madpatrick wrote: Wednesday 24 August 2022 10:07 maybe this will help a bit
