Hii all,
I`m new with dzVents programming and for so far it works well for me.
There is only one thing i don`t get work for now. I have a program with multiple timer actions.
Is there a way to simply activate a switch or something on a specifically time?
I mean something like:
if (domoticz.time == '13:52') then
Test.switchOn()
Time actions
rrozema
Re: Time actions
You don't need a script for that: you can do that in the user interface. Click on the "Timers" button in the 'Switches' tab and add the timer using the "On time" option.
- heggink
- Domoticz version: 12451
Re: Time actions
If you wanted to use dzvents, you could use a simple timer trigger rule:
You can combine timer rules with device trigger rules in which case you can check what triggered the script. It's quite well described in the wiki (https://www.domoticz.com/wiki/DzVents:_ ... gger_rules) but feel free PM me if you need more help.
H
timer = { 'at 13:45' } ,
...H
P1 meter & solar panel
solarboy
- Domoticz version: 2026.4
Re: Time actions
If however, you do want to have this in a script function, how could you achieve it ?
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),Harmony Hub, Kodi,APC UPS,SMA Modbus,Broadlink,Dombus
rrozema
Re: Time actions
dzvents is a script function.
Go into the Events page ('Settings' -> 'More Options' -> 'Events'), click the +-sign at the right most of the tab header(s). Select 'dzvents' -> 'Timer' and you'll get a newly created example script with lots of timer-trigger examples to choose from.
