Python Plugin: TUYA
cache
Re: Python Plugin: TUYA
Post by cache »
adelafug wrote: Wednesday 01 September 2021 19:28 Hello
I install plugin tuyaha and configure params. But when plugin call skill api i no receibe my devices. I used Tuya Smart with iphone.. And i have 1 device registred ( sensor door ).
I test api with Postman y receive the same response..
https://px1.tuyaeu.com/homeassistant/sk ... dVersion=1
BodY: {'header': {'name': 'Discovery', 'namespace': 'discovery', 'payloadVersion': 1}, 'payload': {'accessToken': 'EUheu16305128439555U07k8PoLsNpHsU'}}
Response.
{"payload":{"devices":[],"scenes":[]},"header":{"code":"SUCCESS","payloadVersion":1}}
Any idea?
Thanks.
Anyone managed to get it working? Same situation here but with a RGBW LED stripe.
Local connection is not implemented nor will it? Always using tuya cloud services?
cache
Post by cache »
cache wrote: Thursday 17 March 2022 23:02
Response.
Any idea?
Thanks.
OK I got it working. Anyone facing the same issue: dont use tuyaha but tinytuya. Works like a charme in pure local mode. No cloud required. Could even implement the music mode provided by the LED stripe
manjh
Post by manjh »
cache wrote: Saturday 19 March 2022 18:03
How does thie TinyTuya interface with Domoticz?
Hans
manjh
Post by manjh »
cache wrote: Saturday 19 March 2022 18:03 OK I got it working. Anyone facing the same issue: dont use tuyaha but tinytuya. Works like a charme in pure local mode. No cloud required. Could even implement the music mode provided by the LED stripe
Can you provide a pointer to TinyTuya? How to install, and how to interface to Domoticz?
Hans
cobra045
Domoticz version: 3.4834
Post by cobra045 »
Yes, a step-by-step plan, that would be great.
I think many Domoticz users will thank you
manjh
Post by manjh »
cobra045 wrote: Saturday 14 May 2022 20:43 Yes, a step-by-step plan, that would be great.
I found some instructions online, but it is not as simple as the usual plugin install. You need to create a developer account with Tuya, to start with. The steps are not simple. I think I will stick to the plugin for now.
Edit: I decided to give it another try, and it turns out to be much more straightforward. I now have a full list of devices, along with their properties.
Hans
arjan93
Post by arjan93 »
Hii all,
Since a couple of days I have problems with my Tuya plugin on domoticz. Normaly I only use led bulbs from Tuya
in my house but since a couple of days I`ve add a Tuya wall switch to my system. From that moment I saw that
it takes a while before the status of the devices has been updated. For lights it not a big deal, but for a switch
it`s important that the status is updated directly.
Is this a know issue or did I something wrong in the set-up?
I`m using Domoticz version 2022.1 on a Raspberry Pi 4 with OS Raspbian GNU/Linux 10 (buster)
Xenomes
Domoticz version: 2025.1
Post by Xenomes »
arjan93 wrote: Wednesday 01 June 2022 20:59 Hii all,
The APIv1 doesn't allow to read a status two times in a minute.
Maybe this is a solution for you, Tuya as local device with MQTT.
EXPERIMENTAL only On/Off for devices is working!! But status changes will be almost instant in Domoticz.
Eclipse Mosquitto is required as a service.
Install tuya-mqtt and setup as mentioned in the description.
To extract the ID and Key, see link.
To run tuya-mqtt as a service
sudo nano /etc/systemd/system/tuya-mqtt.service
[Unit]
Description=tuya-mqtt
After=mosquitto.target
[Service]
ExecStart=/usr/bin/node /opt/tuya-mqtt/tuya-mqtt.js
WorkingDirectory=/opt/tuya-mqtt
StandardOutput=inherit
StandardError=inherit
Restart=always
User=pi
Group=pi
[Install]
WantedBy=multi-user.target
sudo systemctl enable tuya-mqtt.service
sudo systemctl start tuya-mqtt.service
Setup 'MQTT Discovery' in Domoticz, give the same 'topic' as in the config.conf file.
Enable new device detection and hit update in the plugin setting of 'MQTT Discovery' and your devices in the devices.conf file will be detected.
Debug:
cd /opt/tuya-mqtt
DEBUG=tuya-mqtt:* node tuya-mqtt.js
http://mqtt-explorer.com/
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.2 LTS (64Bit) - Domoticz 2025.1 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
luk085
Post by luk085 »
I have problem with login timeouts to API.
 2022-07-13 11:12:58.212 Status: Klimatyzacja: Started.
2022-07-13 11:12:59.688 Klimatyzacja: Waiting 60 seconds to connect TuyaApi login error timeout
2022-07-13 11:12:59.689 Klimatyzacja: Waiting 50 seconds to connect TuyaApi (Tuya Plug-in)
2022-07-13 11:12:59.684 Status: Klimatyzacja: Initialized version 1.0.13, author 'Wagner Oliveira contributed Xenomes'
2022-07-13 11:13:09.699 Klimatyzacja: Waiting 40 seconds to connect TuyaApi (Tuya Plug-in)
2022-07-13 11:13:19.706 Klimatyzacja: Waiting 30 seconds to connect TuyaApi (Tuya Plug-in)
2022-07-13 11:13:29.707 Klimatyzacja: Waiting 20 seconds to connect TuyaApi (Tuya Plug-in)
2022-07-13 11:13:39.708 Klimatyzacja: Waiting 10 seconds to connect TuyaApi (Tuya Plug-in)
2022-07-13 11:13:49.710 Klimatyzacja: Waiting 0 seconds to connect TuyaApi (Tuya Plug-in)
2022-07-13 11:13:59.711 Klimatyzacja: TUYA plugin started
2022-07-13 11:13:59.273 Error: Klimatyzacja hardware (3) thread seems to have ended unexpectedly
2022-07-13 11:14:01.841 Error: Domoticz(pid:12839, tid:13109('Klimatyzacja')) received fatal signal 11 (Segmentation fault)
2022-07-13 11:14:01.841 Error: siginfo address=0x3227, address=(nil)
debug_discovery.py script passes succesfully, I see my device and id.
What can I do now?
verysingh45
Post by verysingh45 »
I have made the changes that allow the plugin to be configured for SmartLife or Jinvoo Smart app (as well as Tuya). Simply select the app from the drop down in the hardware settings (Options are: Tuya, Smart Life or Jinvoo Smart) and it should automatically detect the devices from the app in question. The link on the original post has been updated with the latest version of the plugin.
19216811.bid
panorama charter com
BarryT
Domoticz version: 2024.3
Post by BarryT »
That would be great! +1
lamama1234
Post by lamama1234 »
EDIT: Solved after installing Xenomes' Domoticz-TUYA-Plugin.
Hi and many thanks for this plugin.
I've just added it to my Domoticz server and getting an error within my log, see below. I have 2 devices added to my Smart Life app, and one of them is intentionally offline. Could that be the issue? The online device is working ok from within Domoticz.
Error: (Tuya Smartlife) handleThread: ('Connection aborted.', TimeoutError(10060, 'A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond', None, 10060, None)) line 185
lamama1234
manjh wrote: Wednesday 13 October 2021 8:35
But also:
2021-10-13 08:30:48.671 Error: Bluetooth beacon hardware (20) thread seems to have ended unexpectedly
2021-10-13 08:30:48.671 Error: Xiaomi flowermate hardware (21) thread seems to have ended unexpectedly
2021-10-13 08:30:48.671 Error: Tuya_devices hardware (22) thread seems to have ended unexpectedly
Hi manjh. Were you able to solve those plugins failures? I'm also getting the same log errors for my other plugins after installing Xenomes' Domoticz-TUYA-Plugin.
tnx
Sarcas
Domoticz version: 2022.1ß
Post by Sarcas »
Hi there,
I recently bought my first Tuya-driven product and I am trying to integrate it in Domoticz. It doesnt use the Tuya, Smart or Jinvoo app though, but they have their own app ('create'). I tried my login credentials with every setting anyway, but no luck.
 2022-08-09 15:39:39.353 Error: TUYA: handleThread: Get accesstoken failed. Username or password error! line 207
Any suggestions?
S.
Domoticz on rPi4 - RFXCOM RFXtrx433 USB - ZW090 Z-Stick Gen5 EU - IKEA Tradfri - Philips HUE - YouLess meter - SolarEdge
Xenomes
Post by Xenomes »
Sarcas wrote: Wednesday 10 August 2022 10:14 I recently bought my first Tuya-driven product and I am trying to integrate it in Domoticz.
The chance that this device will work with the old API is very very small.
Sarcas wrote: Wednesday 10 August 2022 10:14 It doesnt use the Tuya, Smart or Jinvoo app though, but they have their own app ('create'). I tried my login credentials with every setting anyway, but no luck.
Normally you can pair a Tuya device in one of the three mentioned apps, you need a new account for the different apps. The Custom App is properly a rebranded Tuya app.
Domoticz version: 2024.7
Sarcas wrote: Wednesday 10 August 2022 10:14 Hi there,
Any suggestions?
S.
Solved by a workaround through RFXCOM
Sarcas wrote: Sunday 14 August 2022 14:53 After discovering that my ceiling fan with TUYA can't be added to Domoticz, I accidentally stumbled upon this post. Tried my remote and I'll be damned! My 433 picks it up :D
Thanks for posting!
dgilbert2
Post by dgilbert2 »
itguy78 wrote: Wednesday 15 July 2020 19:51
DarkG wrote: Tuesday 14 July 2020 22:06 Is there a way to change temperature for my AC? I can only turn on and off.
.... The API has functions to read and set the 'target' temperature and to read the 'current' temperature, but I have no way to test these features. Someone with access to the device should be able to add in a new device that displays current temperature and allows changing the target temperature. Only way I could work on this is if you sent me your app account information (private message) so I could configure it and add it to the plugin -- obviously you'd have to not mind me messing with the settings for development.....
Has it been determined if it is possible to read temperature values into Domoticz using this plugin? My setup works fine with on/off devices but I could do with adding a thermometer into Smartlife also.
dgilbert2
Post by dgilbert2 »
I'm trying to get the TUYA plugin to read the Thermometer below and show the "current_temperature" in Domoticz;
                                    {   'data': {   'current_temperature': 206,
                                                  'max_temper': 700,
                                                  'min_temper': 150,
                                                  'online': True,
                                                  'state': 'true',
                                                  'temperature': 155},
                                      'dev_type': 'climate',
                                      'ha_type': 'climate',
                                      'icon': 'https://images.tuyaeu.com/smart/program_category_icon/wk.png',
                                      'id': 'bf98439ce4381bxxxxxxx',
                                      'name': 'Smart Controller'},
So far I've added the lines below which have now made the Thermometer appear in Domoticz Devices:
   elif dev_type == "climate":
                        Domoticz.Device(Name=dev.name(), Unit=unit, Type=244, Subtype=73, Switchtype=0, Image=16, DeviceID=dev.object_id()).Create()
                        if dev.data.get("current_temperature") is not None:
                            unit = nextUnit()
                            Domoticz.Device(Name=dev.name(), Unit=unit, Type=80, Subtype=5, Switchtype=0, DeviceID=dev.object_id()).Create()
But now I'm stuck, as the "current_temperature" value is not being passed, or updated, in Domoticz, ie, it just displays 0.0.
Any ideas on the lines I need to add/change to read over the "current_temperature" value into Domoticz?
Xenomes
Post by Xenomes »
dgilbert2 wrote: Friday 23 September 2022 22:25 I'm trying to get the TUYA plugin to read the Thermometer below and show the "current_temperature" in Domoticz;
CODE
CODE
Hi, That part of the plugin not complete, I don't have a tuya temp device so i was depended for data from a other user witch stopped replaying. For updating you need to add code below here:
                # Update device
                if dev.state() == False:
                    UpdateDevice(unit, 0, 'Off', not dev.available())
                elif dev.state() == True:
                    UpdateDevice(unit, 1, 'On', not dev.available())
                else:
                    Domoticz.Log('DeviceID='+Devices[unit].DeviceID+' State update skiped. status = '+str(dev.state()))
                #if dev.device_type() == 'cover' and dev.state() != 'Stop':
                #    UpdateDevice(unit, 1, 'Stop', not dev.available())
                if dev.state() == True and not dev.available():
                    Domoticz.Log('DeviceID='+Devices[unit].DeviceID+' Turned off because device is offline.')
dgilbert2
Post by dgilbert2 »
Xenomes wrote: Saturday 24 September 2022 16:32 Hi, That part of the plugin not complete, I don't have a tuya temp device so i was depended for data from a other user witch stopped replaying. For updating you need to add code below here:
Thank you for your reply. I am making some progress and will post back where I end up. Coding is not my strong point so takes a little time ;)
Users browsing this forum: mxpwr and 1 guest
