In synology 7.1 I installed Domoiticz domoticz.v10.f40000[evansport].spk .
The dzVents directory was missing -> installed it from other source in /volume1/@appstore/domoticz/bin
dzVents is working but no templates (I can live by that).
But after that I get an error No information about longitude / latitude available. Please set lat/lng information in settings
I checked the database and found the correct values under Location.
Is it possible that I have to change a path ? Can sombody help me ?
dzVents longitude / latitude NOT available
- Domoticz version: 2026.3
Re: dzVents longitude / latitude NOT available
Make sure that in the Security section in the settings (Setup > Settings > System > Local Networks (no username/password) you allow 127.0.0.1 (and / or ::1 when using IPv6 ) to not need a password. dzVents does use this port to get the location settings and to send certain commands to Domoticz.
PeterM
127.0.0.* was set and is still.
There must be another reason.
I suppose something is not right in your installation in the first place.
What installation method is this? Is it documented? What version of Domoticz did you get as v10.f400000 is not telling me what vesion you are running.
Did you check the Docker container version of Domoticz? See wiki https://www.domoticz.com/wiki/Synology
PeterM
Domoticz version 2020.2 from Synocommunity (should be running on Synology without Docker)
dzVent version 3.0.2
python version 3.8.8
I would like to run Domoticz without Docker.
I got a lot of errors after installation, but succeeded in removing all the errors except for the location.
