Nefsolive
Re: Domoticz app 2.0
Hello
I've been a domoticz premium user for some time and since I updated to this latest version, I'm not able to configure an NFC TAG! The tag is configured with app://domoticz, but then in the app's settings it doesn't recognize the tag.
In the previous version I was always able to configure tags.
I'm using android 12.
I hope you can solve it, in case it's an app bug.
Thanks and keep up the good work on this project!
karl8754
- Domoticz version: stable
Agreed - I really don't like the on/off toggles - sometimes my app is out of sync with actual device status so I have to toggle on/off repeatedly to get the function I wanted - having direct on/off buttons allows me to easily control with one tap.Luigi87 wrote: Friday 15 July 2022 15:24I understand your point of view. But domoticz is all about the adjustably of the software.galadril wrote: Friday 15 July 2022 10:52
Also about all the different flavors people are asking:
- list / grid
- buttons / switch
- events/uservars/logs on main menu
- less data on dashboard
- more data on dashboard
- etc
Im actually checking events in analytics to see the usage.. and then the 100 options are really cluttering the project/code setup.
So if i notice that for example less then 1% uses some features, it could be worth to remove some flexibility, and gain more ease in development and be able to rework the app better.
I actually think i have been too flexible for the 1% users in the past, sorry for that.
These things above "on/off" buttons and "last update" will they come back?
Otherwise I have to revert to an older version of the premium app, to get all the things working again.
Thanks![]()
If you decide not to bring back direct buttons option for future versions, can we at least get the latest APK of the version that still had them and I'll just stick with using that?
If using 433MHZ light, you need a separate direct On / Off switch. Because Domoticz doesn't know the status. If the light is already On (manual switch in the wall), and domoticz has a status OFF, i need the switch the lights ON in the app, before switching OFF.
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
I'm user of the premium app for a long time.
The app was perfect but now with the upgrade there are a lot of problems.
Now in the main panel when i try to move a switch to reorder the app crash!
Someone has the same issue?
Thanks,
Ale.
Thanks,
Ale.
- jacobsentertainment
- Domoticz version: 2021-1
The widgets are still "beta" Just some feedback, the switches only update after opening the app and the temperature doesn't update!
For the rest the app is pretty ok and I like the widgets.
GJKNL
Before the app update, geofence was very reliable. Since the update not anymore. When I leave my location it looks like it works, but when I come home it does not trigger the switch. But hours later, somewhere around midnight it triggers the switch. And everytime when I open the app, it triggers my switch. The app is running in background and no energy savings, using location is allowed always.
- galadril
- Domoticz version: latest
Im back from a (needed) holiday, and going to look into those topics reported (widgets/geofences/etc)
Looks like those are mainly related to the Android 12 sdk changes..
- galadril
Upcoming version has some fixes for NFC tag usage and drag/drop. Thanks for reporting.Nefsolive wrote: Monday 18 July 2022 22:50 I've been a domoticz premium user for some time and since I updated to this latest version, I'm not able to configure an NFC TAG! The tag is configured with app://domoticz, but then in the app's settings it doesn't recognize the tag.
jefft
- Domoticz version: 2023.1
What's with the adverts? I previously paid for premium, premium app tells me I now need to use the 'one' version. Now I've got adverts where I expect to see my devices. That's irritating. It's also not very respectful to people who supported the app by paying for it!.
How do I remove the ads? I thought perhaps 'restore subscriptions' was it, but that appears to do nothing.
Domoticz, Z-Stick Gen.5, zzh Zigbee, rxftrx433XL on Ubuntu 22.04, HP 290 G1.
Node Red, MQTT, 80+ Z-wave, ESP8266 & Shelly, handful of Zigbee bulbs. EMS-ESP gateway for Bosch boiler. Controlicz, until it dies :-(
- user4563
- Domoticz version: 2025.2
Where are you seeing ads? I'm on the (origional) premium too and don't have ads
ODroid H4+ / Ubuntu server 24.04 LTS
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Domoticz Scenes add-on in Kodi
- galadril
Thanks for notifying that in release 2022.2 the blinds are changed command whise.. so the on/off actions are changed so they dont behave correctly in thee app anymore.
Im going to change that in the app
- user4563
I also noticed that after the 2022.2 update the logs show the following deprecated warning when logging in with the app. It does not appear when logging in by the browser.
2022-11-08 18:59:38.828 Depricated: Page LoginCheck! Use command instead!
2022-11-08 18:59:38.828 Status: Login successful from x.x.x.x for user 'mobile-xxxx'
2022-11-08 18:59:38.828 Status: Incoming connection from: x.x.x.xODroid H4+ / Ubuntu server 24.04 LTS
- jvdz
- Domoticz version: 4.107
Hope you are going to keep it backwards compatible for those that didn't switch to the latest yet.galadril wrote: Tuesday 08 November 2022 15:30 Thanks for notifying that in release 2022.2 the blinds are changed command whise.. so the on/off actions are changed so they dont behave correctly in thee app anymore.
- fabry91
- Domoticz version: 2022.2
I am not very statisfied with the concept of the new app.
We paid for the Premium app, forever, now we need to pay again and also every year, I don't think is the right way to have such a subscription for a "free home automation enviromental".
Considering the design of the app and his services that I think they are the same of the previous one a one time paid subscription were enough.
Ouate
The blinds are still inverted in the app.
Can you tell me if it's going to be fixed with new Domoticz update?
- galadril
yes Im still working on it.Ouate wrote: Friday 11 November 2022 23:39 The blinds are still inverted in the app.
- galadril
Its probably not going to work.jvdz wrote: Wednesday 09 November 2022 10:12 Hope you are going to keep it backwards compatible for those that didn't switch to the latest yet.![]()
- galadril
Thanks for the feedback. You can still use the Premium app that you payed for right?fabry91 wrote: Wednesday 09 November 2022 11:00 Hello,
- galadril
user4563 wrote: Wednesday 09 November 2022 1:02 I also noticed that after the 2022.2 update the logs show the following deprecated warning when logging in with the app. It does not appear when logging in by the browser.
2022-11-08 18:59:38.828 Depricated: Page LoginCheck! Use command instead! 2022-11-08 18:59:38.828 Status: Login successful from x.x.x.x for user 'mobile-xxxx' 2022-11-08 18:59:38.828 Status: Incoming connection from: x.x.x.x
Good one.. i have the feeling that the app should use the Applications setup in your Domoticz settings.
https://github.com/domoticz/domoticz/pull/4872
And implement an oAuth login flow.
- galadril
Did some cleaning today, removed all the unneeded inverted blind devices
https://github.com/domoticz/domoticz-an ... d51721f2ff
I've been testing the blinds with reverse state and reverse position settings, but they all seem the same for me.. i've tested them and they look good on the app. So if you have issues with those states in the last beta, please explain as good as possible
