I've had a look through the guidance to see if this is possible from a user end, but am unable to find anything, so I'm putting this forward as a suggestion.
Given that smoke detectors and motion sensors have their own switch types, it would be really helpful to have a separate switch type to represent water sensors / water leak detectors.
Switch type of 'Water Sensor'
DO977
- Domoticz version: 2023.2
Re: Switch type of 'Water Sensor'
Given the lack of response, I'm not sure if it'll get much traction if I raise a ticket!
Does anyone know of another approach I could take? I'd like to make it visually different to motion sensors & fire alarms, because it is a different type of device!
- Domoticz version: 2026.3
You probably can upload your own custom water sensor icons and use it to change another sensor (motion/smoke/etc).
https://www.domoticz.com/wiki/Custom_ic ... binterface
