Hi All,
For years I have been using a CRON bash script to backup my database on a NAS on a daily basis. This script uses the built-in "backupdatabase.php".
But now I get errors about reaching the 10 s limit, probably due to the database size which has increased (> 10M).
Instead of using backupdatabase.php it would be possible to make a direct copy of the database or even rsyncing the whole domoticz folder.
But my question is: Is it safe to make such copies while domoticz is in use ?
Database backup with backupdatabase.php gives 10 s limit errors
- Domoticz version: 2026.3
Re: Database backup with backupdatabase.php gives 10 s limit errors
I believe 10MB database is not that big, seems to be normal, mine is 16 MB. So probably look what is going on else, network, slow CPU, memory?
Is the automatic backup also working? Because then you could copy the domoticz/backups/daily folder daily. When you do that 10 min after the whole hour you are not conflicting with the automatic backup schedule that runs on the whole hour exactly.
mgugu
Same story with automatic backup so I really think this is due to baclupdatabase.php which takes too much time.waltervl wrote: Saturday 02 July 2022 15:12 I believe 10MB database is not that big, seems to be normal, mine is 16 MB. So probably look what is going on else, network, slow CPU, memory?
You are right, the slow CPU (Pi 2B that I use for domoticz since 2014) is probably the cause.
Changing to Pi 4 is impossible at the moment, that is why I am looking for a workaround.
Then check the CPU load of your Pi if it is doing something else besides Domoticz. Also check your SD card, if writing is slow it could fail too.
mgugu
Everything is OK.waltervl wrote: Saturday 02 July 2022 21:26 Then check the CPU load of your Pi if it is doing something else besides Domoticz. Also check your SD card, if writing is slow it could fail too.
Solved that issue by reducing the database size.
I discovered in *_calendar tables, a huge amount of expired values (date up to 2015).
After deleting values < 2021-01-01 in *_calendar tables and vacuuming the database, the size decreased from 13 M to 5 M.
