Dutch local covid-19 figures
Re: Dutch local covid-19 figures
Xenomes wrote: Tuesday 08 June 2021 20:21 Here is the extended log.
Sorry. No clue where to look for. Best to do is to add extra loglines at various places. Maybe that will point you in the right direction.
Xenomes
Domoticz version: 2024.7
Post by Xenomes »
Thanks for looking at the problem, I will recreate the device. The script was not changed in a long time.
edit: Make a new counter and it is working again!?!
2021-06-08 21_38_08-Domoticz - Overige.png (245.69 KiB) Viewed 1317 times
sqlite> select * from DeviceStatus where id in (638, 835);
ID|HardwareID|DeviceID|Unit|Name|Used|Type|SubType|SwitchType|Favorite|SignalLevel|BatteryLevel|nValue|sValue|LastUpdate|Order|AddjValue|AddjMulti|AddjValue2|AddjMulti2|StrParam1|StrParam2|LastLevel|Protected|CustomImage|Description|Options|Color
638|8|82638|1|Reported covid-19 in Steenbergen old|1|113|0|3|1|12|255|0|2283|2021-05-31 15:37:41|651|0.0|1.0|0.0|1.0|||0|0|0||ValueQuantity:UGVvcGxl|
835|8|82835|1|Reported covid-19 in Steenbergen    |1|113|0|3|0|12|255|0|2278|2021-06-08 21:36:41|650|0.0|1.0|0.0|1.0|||0|0|0||ValueQuantity:UGVvcGxl|
sqlite>
HP T630 (32GB SSD/8GB Mem) - Ubuntu 22.04.4 LTS (64Bit) - Domoticz 2024.7 with Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
Drees
Post by Drees »
Is this script still working, or is it stopped because they don't know all the positive tests humans?
If it is still working, can someone tell me where i need to put the second script of OP and what script language?
Xenomes
Post by Xenomes »
Yes, the script is still working, you only have to change line 158 because the data of rivm was getting very large.
local filterDelay = 900
The script to update the meters with all the data, will run for a long time be patient.
The original poster has passed a way (God rest his soul) :cry:
