No data out domoticz
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
Filnet
Domoticz version: 2026.1 ß
Post by Filnet »
Hello
I submit my problem. I try using mqtt with dz.
When I select "MQTT Client Gateway...", data in and data out appairs in MQTT Explorer.
But when I select "MQTT Autodiscovery Client Gateway..." no data goes out domoticz.
Where is my mistake?
Used with Mosquitto/docker
Thanks for your help
Filnet
Domoticz version: 2026.3
Re: No data out domoticz
it goes out in the AD style so the AD hardware (eg zigbee2mqtt or zwavejs2mqtt) can understand. So look in the AD prefix (eg homeassistant) with MQTT Explorer.
Filnet
Post by Filnet »
Thanks for response. For testing, one hardware with AD (prefix homeassistant) and another one without AD (prefix domoticz)
Here is the log window of MQTT Explorer:
domoticz
status = online
out = { "Battery" : 255, "LastUpdate" : "2022-06-20 15:00:39", "RSSI" : 12, "description" : "", "dtype" : "General", "hwid" : "15", "id" : "00000003", "idx" : 522, "name" : "Core Clock Speed", "nvalue" : 0, "stype" : "Custom Sensor", "svalue1" : "400.0000", "unit" : 1 }
in = { "idx" : 1, "nvalue" : 0, "svalue" : "25.0" }
homeassistant
status = online
You can see no out with AD...
When do you expect something in out?
For AD is only something send to MQTT if something changes in Domoticz by UI (eg you switch a switch). The command is send to MQTT AD and will be read by the hardware and it will switch the device.
So MQTT Autodiscover is following the AD protocol as linked to in the wiki.
But you can have both if you want to. 1 MQTT AD hardware gateway and a legacy MQTT hardware gateway.
Filnet
Post by Filnet »
If I understand, "AD gateway" don't send data to mqtt from others devices included in Dz like the other gateway?
I am not sure but I think it sends out only data for those devices that are managed/discovered by the MQTT AD gateway.
But you can test it yourself.
Filnet
Post by Filnet »
Ok. i am trying install zwave2mqtt todo this testing.
