Had planned to visit bad injured son in hospital in another country when I discovered last Friday that the boiler had been leaking 18 liters/day into the cellar sub-floor. Hidden by the flooring the damp showed up to a meter high in the concrete cellar walls.
That's going to be expensive. The dryer company reckons 2 to 3 months with 3 dryers and the insurance company has agreed to 3k euros electricity.
So any recommendations for a flood water sensor with 433 MHz capability to RFXCOM and a heartbeat battery status signal?
Oh we have a digital water meter which if I was able to monitor it would have shown the continuous loss through the night.
The unit is a Diehl Type 173. I asked the water supplier if it was possible to interrogate and they said "No". Has anyone been able to sniff pulses from it?
Flood water sensor and water meter reading
paul402
Re: Flood water sensor and water meter reading
I'm curious. Has no-one ever done this before with Domoticz? Am I breaking new ground?
Or is it the case that everyone knows about it already?
Anyone recommend another forum that might have some answers for me?
- heggink
- Domoticz version: 12451
Mine are ZigBee (aqara) as I don't trust the 433 mhz protocol (no guaranteed delivery).
Sent from my SM-G980F using Tapatalk
P1 meter & solar panel
paul402
Thanks heggink. What do I need to get started with Zigbee and connected to Domoticz? This is new territory for me.
Is there a tutorial?
- heggink
ZigBee is worth it. Much better than 433 and far cheaper than zwave
I can help set it up. There's multiple working options. I chose to use zigbee2mqtt as domoticz has native support for the autodiscovery protocol.
You would need a zigbee usb stick (I have the zzh stick but there are others that are as good or better) to connect zigbee2mqtt to ZigBee devices.
Have a look at the zigbee2mqtt site. It is pretty solid. I run zigbee2mqtt in a docker container. Literally up within a minute.
sammyke007
- Domoticz version: 2022.1
+1 for Domoticz + zigbee2mqtt in Docker and a ZZH stick. Working great for over a year and much more reliable than 433mhz which I used before. Batteries in my sensors last for +1 year and still going strong.
rylfas
- Domoticz version: 2026.1
I use the Shelly Flood in combination with MQTT and ShellYMQTT. Works directly with Domoticz without further hardware.
