migrating from openzwave to zwavejs : newbie question
red59
Post by red59 »
hello,
i'm trying to upgrade my domoticz installation, and as recommanded, try to migrate from openzwave to zwavejs (and zwavemqtt).
for the moment i have setup a zwavejs container, and i am stuck with security, in domoticz/openzwave i had a network key, do i have to put it in zwavejs ?
if yes, i don't understand where, because in zwave parameters i have 4 keys :
S2 unauthenticated, S2 authenticated, S0 legacy and S2 access control.
thanks for your help and sorry if question has been already posted
heggink
Domoticz version: 12451
Re: migrating from openzwave to zwavejs : newbie question
Post by heggink »
I had the same issue a while back and ended up putting the one OZW in all of the zwavejs fields. It worked for me although I am not sure if that was how it's supposed to work.
Sent from my SM-G980F using Tapatalk
P1 meter & solar panel
red59
Post by red59 »
I would have liked to put same Key in all fields, but it is not working, zwavejs tells me Key must not be duplicated...
I try to put the old openzwave Key in s0_legacy(without 0x) but my 2 secured fgs213 still show as unknown security and are not working...
Any ideas ?
heggink
Post by heggink »
Apologies, you are absolutely right. I looked at the settings on my phone so didn't notice that I used the OZW key for S0 and then just numbered up (added 1 to every subsequent key).
red59
Post by red59 »
so you are right, you have to put openzwave key under S0 legacy, what i was missing was re-interview node and reset security classes after putting the key...
all is ok now.
thanks !!
