Custom sensors not publishing status to mqtt domoticz/out
calania
Post by calania »
Hello! A few days ago I decided to update and completely reinstall Domoticz ( version 2022.1). It has so far worked nicely but I have encountered a issue. I have a few customs sensors (type general) that I send value to using mqtt. This works without issue and Domoticz updates the value without problem. The issue however is that Domoticz then doesn't seems to be publishing the device change to the domoticz/out topic. Is this a known issue? It seems to be working for all the other sensors except for theses custom sensors. Any ideas?
jvdz
Domoticz version: 4.107
Re: Custom sensors not publishing status to mqtt domoticz/out
Post by jvdz »
It is a known feature to avoid an endless loop of messages. I think you can set it in the mqtt hardware definition to send anyways... Just check there.
calania
Post by calania »
Disabling the "Prevent loop" did indeed fix the issue for me. So thanks for that! I however don't really understand how Domoticz publishing the status would start a loop. Could you explain how this loop would start?
FireWizard
Post by FireWizard »
Hi @calania,
For a brief explanation, see viewtopic.php?p=280055#p280055
