has anyone written a LUA script for Domoticz that checks room temperatures, and in case that a room temperature increases too fast, send a fire alarm by Telegram, Email, internal siren, ...?
Thanks.
Fire detection script by checking room temperatures
- psubiaco
Paolo
- McMelloW
- Domoticz version: V2024.1
Re: Fire detection checking room temperatures
There is an example in the DzVents wiki. Very simple
return
on =
devices = {
'myDetector',
'roomTemp'
if ((device.name == 'myDetector' and device.active) or
(device.name == 'roomTemp' and device.temperature >= 45)) then
domoticz.notify('Fire', 'The room is on fire', domoticz.PRIORITY_EMERGENCY)
Greetings McMelloW
- psubiaco
hmm, that's too basic example!
I've decided to write a new script that detects fire by checking the rooms temperature:
* read a configuration file with the list of room name, temperature sensor name, deltaT to trigger the alarm
* stores in a variable, json encoded, the list of average temperature for each room
* when in one or more rooms the Temperature > Average_temperature + deltaT => send notification by Telegram
* works with both simple temperature and temperature+humidity(+barometric) sensors.
You can find the fire detector scripts in https://github.com/CreasolTech/domoticz_lua_scripts : they have to be placed into Domoticz scripts/lua directory:
* script_time_fireAlarm.lua => lua script triggered every minute
* config_fireAlarm.lua => configuration file
* globalvariables.lua => another configuration file with telegram API information and something else
* globalfunctions.lua => some functions that are used from my scripts
I'm just checking the script now... if you have any suggestions, please let me know!
I hope this script can be helpful even for you!!
Paolo
- psubiaco
I've updated the fire detection script again. You can download from github https://github.com/CreasolTech/domoticz_lua_scripts
Paolo
