Domoticz plugin Growatt Web Domoticz-Pvoutput not working
dutchronnie
Post by dutchronnie »
I have installed the plugin to add growatt data to pvoutput, but it looks like it is doing nothing.
When i filled the parameters in the form, and add the hardware, there must be created some dummy devices, but i don't see any of this devices.
Is the plugin not working, or did i something wrong?
I can't find any tutorial on the net of this plugin.
Only the github page.
https://github.com/sincze/Domoticz-Grow ... ver-Plugin
I hope somebody can help
dutchronnie
Re: Domoticz plugin Growatt Web Domoticz-Pvoutput not working
ik have removed the plugin, en reinstalled again, but the plugin is still not working.
In the log i get the following messages, but what does it mean?
2022-03-21 08:48:38.321 Error: Sunpv2: (GrowattWebPVO) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-growatt-webserver-pvoutput-plugin/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'.
2022-03-21 08:48:38.321 Error: Sunpv2: Module Import failed, exception: 'SyntaxError'
2022-03-21 08:48:38.322 Error: Sunpv2: Import detail: File: , Line: 422, offset: 39
2022-03-21 08:48:38.322 Error: Sunpv2: Error Line ' path = f"/service/r2/addstatus.jsp"
2022-03-21 08:48:38.322 '
2022-03-21 08:48:38.322 Error: Sunpv2: No traceback available
Domoticz version: 2026.3
What is the link to the github where you have found this Growatt - PVoutput plugin?
The normal plugin that you already linked to is working fine on my environment.
That is not sending anything to PVOutput, nor has it a line 422 in python.py where your error is. Python.py is in total 369 lines.
So you use another python script.
dutchronnie
Strange, are we looking to the same plugin?
this plugin sends data to pvoutput (optional)
And line 422 is also in there
# 	Growatt Inverter Python Plugin for Domoticz                                   	   #
# 	MIT License        #
#	Copyright (c) 2018 tixi                                                            #
#	Permission is hereby granted, free of charge, to any person obtaining a copy       #
#	of this software and associated documentation files (the "Software"), to deal      #
#	in the Software without restriction, including without limitation the rights       #
#	to use, copy, modify, merge, publish, distribute, sublicense, and/or sell          #
#	copies of the Software, and to permit persons to whom the Software is              #
#	furnished to do so, subject to the following conditions:                           #
#	The above copyright notice and this permission notice shall be included in all     #
#	copies or substantial portions of the Software.                                    #
#	THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR         #
#	IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,           #
#	FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE        #
#	AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER             #
#	LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,      #
#	OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE      #
#	SOFTWARE.        #
#   Author: sincze        #
#   This plugin will read the status from the running inverter via the webservice.         #
#   V 1.0.0. 25-08-2019 Initial Release                                                    #
#   V 2.0.0. 17-08-2021 Added pvoutput upload between 06:00 and 23:00                      #
<plugin key="GrowattWebPVO" name="Growatt Web Domoticz-Pvoutput" author="sincze" version="2.0.0" externallink="https://github.com/HarryVerjans/domoticz-growatt-webserver-pvoutput-plugin">
    <description>
        <h2>Retrieve available Growatt Inverter information from the webservice</h2><br/>
    </description>
    <params>
        <param field="Address" label="Server Address" width="200px" required="true" default="server-api.growatt.com"/>
        <param field="Mode2" label="Portal Username" width="200px" required="true" default="admin"/>
        <param field="Mode3" label="Portal Password" width="200px" required="true" password="true"/>
        <param field="Mode1" label="Protocol" width="75px">
            <options>
                <option label="HTTPS" value="443"/>
                <option label="HTTP" value="80"  default="true" />
            </options>
        </param>
        <param field="Mode4" label="Pvoutput sysids" width="200px" required="true" default="optional"/>
        <param field="Mode5" label="Pvoutput apikey" width="300px" required="true" default="optional"/>
        <param field="Mode6" label="Debug" width="150px">
            <options>
                <option label="None" value="0"  default="true" />
                <option label="Python Only" value="2"/>
                <option label="Basic Debugging" value="62"/>
                <option label="Basic+Messages" value="126"/>
                <option label="Connections Only" value="16"/>
                <option label="Connections+Python" value="18"/>
                <option label="Connections+Queue" value="144"/>
                <option label="All" value="-1"/>
            </options>
        </param>
    </params>
</plugin>
try:
    from datetime import date								#added 2021-08-16 by HV
    from datetime import datetime							#added 2021-08-16 by HV
    import requests
    import os
    from urllib.parse import urljoin,urlencode
    import logging
    import csv
    import Domoticz
    import hashlib
    import json
    import re               # Needed to extract data from Some JSON result
    import urllib.parse     # Needed to encode request body messages
    local = False
    logfile = False
    starthour = "06"
    stophour  = "23"
except ImportError:
    local = True
    import fakeDomoticz as Domoticz
    from fakeDomoticz import Devices
    from fakeDomoticz import Parameters
class BasePlugin:
    logger = logging.getLogger(__name__)
    PVOUTPUT_URL = 'https://pvoutput.org/'
    httpConn = None
    runAgain = 6
    disconnectCount = 0
    sProtocol = "HTTP"
    cookieAvailable = False
    sessionId=""
    serverId=""
    plantId = ""
    serialnumber = ""
    pvosid = ""
    pvokey = ""
    def __init__(self):
        return
    def apiRequestHeaders(self):        # Needed headers for Login Function
            'Content-Type': 'application/x-www-form-urlencoded; charset=utf-8',
            'Connection': 'keep-alive',
            'Host': 'server-api.growatt.com',
            'User-Agent': 'Domoticz/1.0',
            'Accept-Encoding': 'gzip'
    def apiRequestHeaders_cookie(self): # Needed headers for Data retrieval
            'Verb': 'POST',
            'URL': '/newTwoPlantAPI.do?op=getUserCenterEnertyDataByPlantid',
            'Headers' : { 'Content-Type': 'application/x-www-form-urlencoded; charset=utf-8',
                          'Accept-Encoding': 'gzip',
                          'Cookie': ['JSESSIONID='+self.sessionId, 'SERVERID='+self.serverId]
            'Data': "plantId="+str(self.plantId)+"&language=1"
# Future use
#    def apiRequestHeaders_serialnumber(self):
#        return {
#            'Verb': 'GET',
#            'URL': "/newTwoPlantAPI.do?op=getAllDeviceList&plantId="+str(self.plantId)+"&content=",
#            'Headers' : { 'Content-Type': 'application/x-www-form-urlencoded; charset=utf-8',
#                          'Connection': 'keep-alive',
#                          'Host': 'server-api.growatt.com',
#                          'User-Agent': 'Domoticz/1.0',
#                          'Accept-Encoding': 'gzip',
#                          'Cookie': ['JSESSIONID='+self.sessionId, 'SERVERID='+self.serverId]
    def onStart(self):
        if Parameters["Mode6"] != "0":
            Domoticz.Debugging(int(Parameters["Mode6"]))
            DumpConfigToLog()
        if Parameters["Mode4"] != "":
           pvosid = Parameters["Mode4"]
        if Parameters["Mode5"] != "":
           pvokey = Parameters["Mode5"]
        # Check if devices need to be created
        createDevices()
        if (Parameters["Mode1"] == "443"): self.sProtocol = "HTTPS"
        self.httpConn = Domoticz.Connection(Name=self.sProtocol+" Test", Transport="TCP/IP", Protocol=self.sProtocol, Address=Parameters["Address"], Port=Parameters["Mode1"])
        self.httpConn.Connect()
    def onStop(self):
        Domoticz.Log("onStop - Plugin is stopping.")
    def onConnect(self, Connection, Status, Description):
        if (Status == 0):
            Domoticz.Debug("Growatt connected successfully.")
            password=Parameters["Mode3"]
            password_md5 = hashlib.md5(password.encode("utf-8")).hexdigest()
            for i in range(0, len(password_md5), 2):
                if password_md5[i] == "0":
                    password_md5 = password_md5[0:i] + "c" + password_md5[i + 1 :]
            sendData = { 'Verb' : 'POST',
                         'URL'  : '/newTwoLoginAPI.do',
                         'Headers' : self.apiRequestHeaders(),
                         'Data': "password="+password_md5+"&userName="+urllib.parse.quote_plus(Parameters["Mode2"])
            Domoticz.Debug("Step 1. Login SendData: "+str(sendData))
            Connection.Send(sendData)
            UpdateDevice(Unit=3, nValue=1, sValue="On", TimedOut=0)         # Inverter device is on
        else:
            Domoticz.Log("Failed to connect ("+str(Status)+") to: "+Parameters["Address"]+":"+Parameters["Mode1"]+" with error: "+Description)
            UpdateDevice(Unit=3, nValue=0, sValue="Off", TimedOut=0)        # Inverter device is off
    def onMessage(self, Connection, Data):
        DumpHTTPResponseToLog(Data)
        strData = Data["Data"].decode("utf-8", "ignore")
        Status = int(Data["Status"])
        LogMessage(strData)
        if (Status == 200):
            apiResponse = json.loads(strData)
            Domoticz.Debug("Retrieved following json: "+json.dumps(apiResponse))
            try:
                if ('back' in apiResponse):
                #if not ['back']['success']:
                #    Domoticz.Log("Login Failed")
                #elif ('back' in apiResponse):
                    Domoticz.Log("Login Succesfull")
                    self.plantId = apiResponse["back"]["data"][0]["plantId"]
                    Domoticz.Log("Plant ID: "+str(self.plantId)+" was found")
                    self.ProcessCookie(Data)                                        # The Cookie is in the RAW Response, not in the JSON
                    if not self.cookieAvailable:
                        Domoticz.Debug("No cookie extracted!")
                    else:
                        Domoticz.Debug("Request Data with retrieved cookie!")
                        Connection.Send(self.apiRequestHeaders_cookie())
                elif ('powerValue' in apiResponse):
                    current = apiResponse['powerValue']
                    total = apiResponse['totalValue']                               # Convert kWh to Wh
                    etoday = apiResponse['todayValue']                              # running total today Convert kWh to Wh
                    sValue=str(current)+";"+str( float(total)*1000 )
                    Domoticz.Log("Currently producing: "+str(current)+" Watt........ Totall produced: "+str(total)+" kWh in Wh that is: "+str(float(total)*1000) )
                    UpdateDevice(Unit=1, nValue=0, sValue=sValue, TimedOut=0)
                    UpdateDevice(Unit=2, nValue=0, sValue=current, TimedOut=0)
                    acpower = str(int(float(current)))
                    yieldtodaywh = str(int(float(etoday)*1000))
                    timenow = datetime.now()
                    uploadhour = str(timenow.strftime("%H"))
                    if (uploadhour >= starthour and uploadhour < stophour):
                          pvoutput = uploadToPvOutput(acpower, yieldtodaywh)
                          PrintToFile(pvoutput)
                          Domoticz.Log("PVOUTPUT: "+pvoutput)
                else:
                    Domoticz.Debug("Not received anything usefull!")
            except KeyError:
                Domoticz.Debug("No defined keys found!")
        elif (Status == 400):
            Domoticz.Error("Google returned a Bad Request Error.")
        elif (Status == 500):
            Domoticz.Error("Google returned a Server Error.")
        else:
            Domoticz.Error("Google returned a status: "+str(Status))
    def onCommand(self, Unit, Command, Level, Hue):
        Domoticz.Debug("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
    def onDisconnect(self, Connection):
        Domoticz.Log("onDisconnect called for connection to: "+Connection.Address+":"+Connection.Port)
    def onHeartbeat(self):
        #Domoticz.Trace(True)
        if (self.httpConn != None and (self.httpConn.Connecting() or self.httpConn.Connected())):
            Domoticz.Debug("onHeartbeat called, Connection is alive.")
        else:
            self.runAgain = self.runAgain - 1
            if self.runAgain <= 0:
                if (self.httpConn == None):
                self.runAgain = 6
            else:
                Domoticz.Debug("onHeartbeat called, run again in "+str(self.runAgain)+" heartbeats.")
        #Domoticz.Trace(False)
    def ProcessCookie(self, httpDict):
        if isinstance(httpDict, dict):
            Domoticz.Debug("Analyzing Data ("+str(len(httpDict))+"):")
            for x in httpDict:
                if isinstance(httpDict[x], dict):
                    if (x == "Headers"):
                        Domoticz.Debug("---> Headers found")
                        for y in httpDict[x]:
                            # Domoticz.Debug("------->'" + y + "':'" + str(httpDict[x][y]) + "'")
                            if (y == "Set-Cookie"):
                                Domoticz.Debug("---> Process Cookie Started")
                                try:
                                    self.sessionId = re.search(r"(?<=JSESSIONID=).*?(?=;)", str(httpDict[x][y])).group(0)
                                    Domoticz.Debug("---> SessionID found: "+ str(self.sessionId))
                                    self.cookieAvailable = True
                                except AttributeError:
                                    self.cookieAvailable = False
                                    Domoticz.Debug("---> SessionID NOT found")
                                if self.cookieAvailable:
                                    try:
                                        self.serverId = re.search(r"(?<=SERVERID=).*?(?=;)", str(httpDict[x][y])).group(0)
                                        Domoticz.Debug("---> ServerID found: "+ str(self.serverId))
                                        Domoticz.Debug("---> ServerID NOT found")
global _plugin
_plugin = BasePlugin()
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
def onConnect(Connection, Status, Description):
    global _plugin
    _plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
    global _plugin
    _plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
    global _plugin
    _plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
    global _plugin
    _plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
    global _plugin
    _plugin.onDisconnect(Connection)
def onHeartbeat():
    global _plugin
    _plugin.onHeartbeat()
# Generic helper functions
def LogMessage(Message):
    if Parameters["Mode6"] == "File":
        f = open(Parameters["HomeFolder"]+"http.html","w")
        f.write(Message)
        f.close()
        Domoticz.Log("File written")
def DumpConfigToLog():
    for x in Parameters:
        if Parameters[x] != "":
            Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
    Domoticz.Debug("Device count: " + str(len(Devices)))
    for x in Devices:
        Domoticz.Debug("Device:           " + str(x) + " - " + str(Devices[x]))
        Domoticz.Debug("Device ID:       '" + str(Devices[x].ID) + "'")
        Domoticz.Debug("Device Name:     '" + Devices[x].Name + "'")
        Domoticz.Debug("Device nValue:    " + str(Devices[x].nValue))
        Domoticz.Debug("Device sValue:   '" + Devices[x].sValue + "'")
        Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
    return
def DumpHTTPResponseToLog(httpResp, level=0):
    if (level==0): Domoticz.Debug("HTTP Details ("+str(len(httpResp))+"):")
    indentStr = ""
    for x in range(level):
        indentStr += "----"
    if isinstance(httpResp, dict):
        for x in httpResp:
            if not isinstance(httpResp[x], dict) and not isinstance(httpResp[x], list):
                Domoticz.Debug(indentStr + ">'" + x + "':'" + str(httpResp[x]) + "'")
            else:
                Domoticz.Debug(indentStr + ">'" + x + "':")
                DumpHTTPResponseToLog(httpResp[x], level+1)
    elif isinstance(httpResp, list):
        for x in httpResp:
            Domoticz.Debug(indentStr + "['" + x + "']")
    else:
def PrintToFile(cdata):
    # Log progress to file while debugging
    if logfile != False:
       p1_init_file="/home/pi/domoticz/plugins/domoticz-growatt-webserver-pvoutput-plugin/pvo.log"
       file=open(p1_init_file,"at")
       file.write(cdata)
       file.write('#\n')
       file.close
def UpdateDevice(Unit, nValue, sValue, TimedOut=0, AlwaysUpdate=False):
    # Make sure that the Domoticz device still exists (they can be deleted) before updating it
    if (Unit in Devices):
        if (Devices[Unit].nValue != nValue) or (Devices[Unit].sValue != sValue) or (Devices[Unit].TimedOut != TimedOut):
            Devices[Unit].Update(nValue=nValue, sValue=str(sValue), TimedOut=TimedOut)
            Domoticz.Log("Update "+str(nValue)+":'"+str(sValue)+"' ("+Devices[Unit].Name+")")
#            PrintToFile("Update "+str(nValue)+":'"+str(sValue)+"' ("+Devices[Unit].Name+")")
    return
#                       Device specific functions                           #
def createDevices():
    # Images
    # Check if images are in database
    if "Growatt" not in Images:
        Domoticz.Image("Growatt.zip").Create()
        image = Images["Growatt"].ID # Get id from database
        Domoticz.Log( "Image created. ID: " + str( image ) )
    # Are there any devices?
    ###if len(Devices) != 0:
        # Could be the user deleted some devices, so do nothing
        ###return
    # Give the devices a unique unit number. This makes updating them more easy.
    # UpdateDevice() checks if the device exists before trying to update it.
    if (len(Devices) == 0):
        Domoticz.Device(Name="Inverter (kWh)", Unit=1, TypeName="kWh", Used=1).Create()
        Domoticz.Log("Inverter Device kWh created.")
        Domoticz.Device(Name="Inverter (W)", Unit=2, TypeName="Usage", Used=1).Create()
        Domoticz.Log("Inverter Device (W) created.")
        Domoticz.Device(Name="Inverter Status", Unit=3, TypeName="Switch", Used=1, Image=image).Create()
        Domoticz.Log("Inverter Device (Switch) created.")
#https://pvoutput.org/help.html#api-addstatus
#https://pvoutput.org/service/r2/addstatus.jsp
#create url can be done simpler but i like this method
def build_api_url1():
    BASE_URL = os.environ.get("BASE_URL", "https://pvoutput.org/")
    query = ''
    return urljoin(BASE_URL, path + query)
#getrealtime info api call
def uploadToPvOutput(acPower, yieldTodayWh):
    pvosid = (Parameters["Mode4"])
    pvokey = (Parameters["Mode5"])
    uploaddate = str(timenow.strftime("%Y%m%d"))
    uploadtime = str(timenow.strftime("%H:%M"))
    PrintToFile("uploadToPvoutput: "+acPower+" "+yieldTodayWh+" "+str(uploaddate)+" "+str(uploadtime))
    Domoticz.Log("PVOUTPUT "+pvosid+" "+str(uploaddate)+" "+str(uploadtime)+" "+acPower+" "+yieldTodayWh)
#    PrintToFile(pvosid)
#    PrintToFile(pvokey)
    apiUrl = build_api_url1()
    pvoutputdata = {
      'd': str(uploaddate),
      't': str(uploadtime),
      'v1': str(yieldTodayWh),
      'v2': str(acPower)
    headerspv = {
        'X-Pvoutput-SystemId': str(pvosid),
        'X-Pvoutput-Apikey': str(pvokey)
    try:
        response = requests.post(apiUrl, headers=headerspv, data=pvoutputdata)
        response.raise_for_status()
#        logger.debug(f'Api url: {str(apiUrl)}')
#        logger.debug(f'pvoutputdata: {str(pvoutputdata)}')
    except requests.exceptions.HTTPError as err:
        logger.exception('HTTP Error')
    except requests.exceptions.RequestException as err:
        logger.exception('Exception occurred')
#    logger.info(f'HTTP Response status code: {str(response.status_code)}')
#    logger.debug(str(response.text))
    return response.text
I found it. I think you are using a fork (copy) modified for pvoutput: https://github.com/HarryVerjans/domotic ... put-plugin
Only no idea why you get the error. It is in this part of the script:
    query = ''
dutchronnie
Yes, thats alright.
The original growat webserver is :https://github.com/sincze/Domoticz-Grow ... ver-Plugin
The fork with pvoutput is :https://github.com/HarryVerjans/domotic ... put-plugin
The original webserver is working, no problem, but i want to upload the data to PVoutput, so i want to use the fork. But that isn't working, and i don't understand why.
It is almost the same script.
dutchronnie
I don't think it is in this piece of code, because i found exacly the same code in some other plugins, and there they are working.
dutchronnie
I think i have foud the solution, but tommorow i am shure.
For now the inverter is down.
  • sudo apt-get update
  • sudo apt-get install git python3-pip -y
  • sudo apt-get install python3.7 libpython3.7 python3.7-dev
  • sudo systemctl restart domoticz.service
i think there was something wrong in Python
dutchronnie
The first problems are gone, but now other problems.
What are i doing wrong?
Now i got this error messages in domoticz:
2022-03-22 08:38:48.287 Error: (FindModule) Domoticz/DomoticzEx modules not found in interpreter.
2022-03-22 08:38:51.748 Error: Zonpaneel: 'onMessage' failed 'NameError':'name 'logger' is not defined'.
2022-03-22 08:38:51.748 Error: Zonpaneel: Exception traceback:
2022-03-22 08:38:51.748 Error: Zonpaneel: ----> Line 310 in '/home/pi/domoticz/plugins/domoticz-growatt-webserver-pvoutput-plugin/plugin.py', function onMessage
2022-03-22 08:38:51.749 Error: Zonpaneel: ----> Line 234 in '/home/pi/domoticz/plugins/domoticz-growatt-webserver-pvoutput-plugin/plugin.py', function onMessage
2022-03-22 08:38:51.749 Error: Zonpaneel: ----> Line 457 in '/home/pi/domoticz/plugins/domoticz-growatt-webserver-pvoutput-plugin/plugin.py', function uploadToPvOutput
This error is from the below part of the plugin, line "logger.exception('HTTP Error')"
You got an HTTP Error only the author did not change that loging errors part of the codeto domoticz plugin python language.
Should be something like
Domoticz.Error("HTTP ERROR")
or put a # in front of the line, it will skip it then (but you also will not get an error....)
    try:
dutchronnie
Thank waltervl.
i wil stop with this plug in, everything i try, it doesn't work.
I wil try to find something else.
the goal is to put data on the pvoutput site, i have found several other scripts that promise to do that, but the most of all al produce errors.
I am not a programmer so it is difficult for me to solve this problems.
I only need a script that wil work.
The problem is that most scripts are made for P1 smart meter data. for the Growatt you need to adapt the scripts.
Only why send your data to PVOutput.org if you have Domoticz with report function? :-)
dutchronnie
Because i have a solar system with a trannergy inverter for years now, end that system is uploading from the trannergy site to pvoutput.
Now i have upgrades my pv system with new solar panels and a second inverter, a Growatt inverter.
My idea was to upload the data to 2 accounts, and to monitor them in a pvoutput app, i have all the data in one place.
And Domoticz doesn't have cool graphics, on pvoutput it looks some better better
Fgerrits
Domoticz version: 2020.1
Post by Fgerrits »
And for a few days the script isn't working anymore, only for a few hours then you'll be blocked.
They are using 2FA now to login, can this be in the script ?
output when trying to connect :
2023-02-28 23:29:31.455 (Solar) Queued asynchronous read aborted (47.91.67.66:80), [2] End of file.
2023-02-28 23:29:31.458 (Solar) Disconnect event received for '47.91.67.66:80'.
2023-02-28 23:29:31.459 (Solar) onDisconnect called for connection to: 47.91.67.66:80
And sometimes :
2023-02-28 23:28:31.379 (Solar) Connect directive received, action initiated successfully.
2023-02-28 23:28:31.429 (Solar) Sending 259 bytes of data
2023-02-28 23:28:31.479 (Solar) Received 357 bytes of data
2023-02-28 23:28:31.480 (Solar) Received 5 bytes of data
Try'd http, https, normal ip, server-api.growatt.com, server.growatt.com, all with the same results.
