Python Plugin : Broadlink
Valiran
Re: Python Plugin : Broadlink
Is you speak browser side, it's allowed.
I don't know how to check raspberry side.
Valiran
Ok, it still doesn't work, BUT looking at the code of the page, I managed to find the "sendCode?key=...." sentence.
Other thing that doesn't work for me is editing ini file. It doesn't save the modifications. Well infact it says it's saved but when I reopen it it's not modified. Had to scp-edit the ini ><
zak45
- Domoticz version: V2024.4
Not really Pi specialist, maybe check the rights ( chmod 777 ) ?
zak45
Cn you do a test with the last beta ???kollemt wrote: Thursday 10 February 2022 0:50 I installed Domoticz version 2021.1. No problems.
When back to my production Domoticz version 2022.1. Again the same problems.
Looks indeed that the problem was introduced with a later Domoticz version:
2020.2 build 2021-03-11 OK
2021.1 build 2021-04-17 OK
2021.1 build 2021-12-23 NOT OK
2022.1 build 2022-01-31 NOT OK
on my side, looks like no more problem :
Version: 2022.1 (build 14223)
Build Hash: 3e5942bb9
Compile Date: 2022-02-21 08:36:39
dzVents Version: 3.1.8
Python Version: 3.8.10 (tags/v3.8.10:3d8993a, May 3 2021, 11:34:34) [MSC v.1928 32 bit (Intel)]
Uptime: 3 Hours, 43 Minutes, 0 Seconds
kollemt
- Domoticz version: 2020.1
Tried to download the raspberry pi unix version.
Got an error.
Will try it later
Got an error.
Will try it later
kollemt
Upgraded to the 14223 version and indeed the problem is solved.
gorstj
I can't download form the link either - page never loads
https://synnas.publicvm.com:4430/s/Czn9r8G8QwrZ7ji
DAVIZINHO
Hello again.
Some can configure this plugin for 0x649b hardware device??
Flappie
I did a clean install of Domoticz and tried to add this plugin:
pi@domoticz:~/domoticz/plugins/broadlink $ sudo python setup.py
File "setup.py", line 229
print("\r>> Bytes downloaded -->" + state + str(leng) + state, end='', flush=True)
SyntaxError: invalid syntax
Any ideas?
Any ideas?
zak45
be sure that your default python is > 3.xFlappie wrote: Wednesday 09 March 2022 13:08 Hi,
Any ideas?
Flappie
That fixed it. Setup ends with:zak45 wrote: Wednesday 09 March 2022 13:27be sure that your default python is > 3.xFlappie wrote: Wednesday 09 March 2022 13:08 Hi,
Any ideas?
Checking installation ....
Successfully imported googletrans
Successfully imported translate
Successfully imported requests
Successfully imported requests_toolbelt
Successfully imported irgen
Successfully imported broadlink
Error : Directory ini do not exist, verify error... exiting
is that normal?
zak45
Verify rights... maybe do chmod 777 to the Broadlink folder (recursive)
bernardstef
Hi !Flappie wrote: Wednesday 09 March 2022 15:55That fixed it. Setup ends with:zak45 wrote: Wednesday 09 March 2022 13:27be sure that your default python is > 3.xFlappie wrote: Wednesday 09 March 2022 13:08 Hi,
Any ideas?
is that normal?
Same issue ... I'm an old user of the 1st plugin version !
Chmod 777 recursive didn't fixed it for me.. I'm digging on it ..
EDIT : created the missing directory myself and the plugin starts !
There should be : 'ini', 'lng', 'log', 'scr', 'web'
zak45
Hope you will enjoy this new one !bernardstef wrote: Tuesday 22 March 2022 17:50 Same issue ... I'm an old user of the 1st plugin version !![]()
nono212
- Domoticz version: 3.6179
Hello guys
I am trying to make work rhis plugin on my docker but witthout success
I have this error
2022-03-23 13:58:14.148 Error: Broadlink: (Broadlink) failed to load 'plugin.py', Python Path used was '/config/plugins/Broadlink/:/usr/lib/python38.zip:/usr/lib/python3.8:/usr/lib/python3.8/lib-dynload:/usr/local/lib/python3.8/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.8/dist-packages'.
2022-03-23 13:58:14.148 Error: Broadlink: Module Import failed, exception: 'AttributeError'
2022-03-23 13:58:14.148 Error: Broadlink: Error Line details not available.
2022-03-23 13:58:14.148 Error: Broadlink: Exception traceback:
2022-03-23 13:58:14.148 Error: Broadlink: ----> Line 134 in '/config/plugins/Broadlink/plugin.py'
on line 134 I see there is :
brodevices = broadlink.get_devices()
do you have any idea ?
I have this error
when installing plugin on Ubuntu 20.04 with 'sudo python setup.py', I get the following error:
Any idea?
(python --version -> Python 3.8.10)
put *.py files executable (+x) OK
chmod: impossible to access 'scr/*.sh': No such file or directory
ERROR to start subprocess
1
sudo chmod +x scr/*.sh
b''
ERROR to put +x to *.sh files
Any idea?
zak45
dombr.sh is missing from the download area... this has been corrected.
just download it or restart setup.py.
pfloryann
- Domoticz version: 2026.3
hi, i want to use 2 broadlink(rm pro and rm 3 mini). The rm pro working with plugin Broadlink with kodi remote, but when i add Rm 3 mini... The plugin displays it but show the commands from Rm Pro and doesn't save the new rm 3 mini command. So doesn't work. Someoane managed to integrate multiple broadlink? Thank you!
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
zak45
No problem to have more than one device.
you need to create two hardware in domoticz.
rfvdboom
- Domoticz version: 2023.2
I had the broadlink plugin working on buster. Since is did a fresh install and now have bullseye, i cant get the plugin working.
During setup.py i get at the end:
/usr/lib/python3/dist-packages/urllib3/connectionpool.py
InsecureRequestWarning: Unverified HTTPS request is being made to host 'synnas.publicvm.com'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/lates ... l-warnings
warnings.warn(
We download plugin files to: BroadlinkSetup.zip
File "/home/pi/domoticz/plugins/Broadlink/setup.py", line 222, in <module>
with open(updname, 'wb') as fh:
PermissionError: [Errno 13] Permission denied: 'BroadlinkSetup.zip'
Error receive / save files from Gdrive : https://synnas.publicvm.com:4430/s/Czn9 ... i/download
How to fix this?
warnings.warn(
How to fix this?
Odroid N2+ | Raspberry P 3 ModelB | RFXcom | AEOTEC Zwave | Honeywell Lyric T6| Milight | Milighthub (NodeMCU) | SolarEdge | P1 Smart meter USB | KAKU | Wemos D1 (esphome) | Denon | Logitech Harmony
