I want to help someone to migrate a Z-wave network that is currently running on domoticz t Home Assistant. After long searching it appears the Network Key is not set in the domoticz configuration. How can I safely migrate the network to Home Assistant without having to join all devices again?
The stick used is an Aeon USB stick, not sure about the exact type.
Migrating Z-wave from domoticz
- jvdz
- Domoticz version: 4.107
Re: Migrating Z-wave from domoticz
It is set in the Hardware click on the Setup on the ZWAVE Hardware item ... then you click on the ZWAVE Controller device and scroll down to the details where you will find "4. Security Network Key:" defined.smorty11 wrote: Wednesday 02 March 2022 16:51 After long searching it appears the Network Key is not set in the domoticz configuration.
