TP-Link Tapo wifi plug
MostlyStrawberry
Re: TP-Link Tapo wifi plug
I have several P100's around the house and some of them I can control using Domoticz and some I can't.
The error for those I cannot connect to is along the lines of host path not reachable (I will update with the whole error code if needed)
My suspicion is that is has to do with my network setup. There is one router (experiabox v10) with wifi off, then a TP-link switch which was 3 TP-link EAP (access points) and an Omada controller connected to it.
There is 1 SSID (2,4 and 5ghz) to which the Domoticz Raspberry and all P100's are connected.
The P100's that connect fine are on the same EAP as the Domoticz raspberry
The P100 that doesn't connect is on another EAP.
Is this a known issue or is there a problem with my network setup?
- Domoticz version: 2026.3
There is a current known issue with using Python plugins on RPi with Bullseye OS. viewtopic.php?t=37376MostlyStrawberry wrote: Monday 28 February 2022 9:03
Is that also the case in your setup?
MostlyStrawberry
I think this is a different issue as my plugin seems to be working fine for some of my P100's
Also my last Raspberry install is from October last year
Yes sorry I thought I reacted on another topic.....
Wouter81
Hey,
After reading the entire forum, I don't immediately see people with the same error message as I have:
2022-04-28 15:34:31.070 Error: Frigo: 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'handshake''.
2022-04-28 15:34:31.070 Error: Frigo: Exception traceback:
2022-04-28 15:34:31.070 Error: Frigo: ----> Line 206 in '/home/admin/domoticz/plugins/Tapo/plugin.py'
2022-04-28 15:34:31.070 Error: Frigo: ----> Line 141 in '/home/admin/domoticz/plugins/Tapo/plugin.py'
2022-04-28 15:34:31.071 Error: Frigo: ----> Line 43 in '/home/admin/domoticz/plugins/Tapo/plugin.py'
2022-04-28 15:34:31.071 Error: Frigo: ----> Line 145 in '/home/admin/domoticz/plugins/Tapo/plugin.py'
Are there people who are wiser from this?
In the plugin.py file code I see "Self" as attribute at OnHeartbeat
belzig
I installed the plugin, and after stetting up the P100 in the Hardware section, the devices shows up in Devices.
But I cannot switch it on or off
2022-05-10 17:42:26.118 Error: Test-Tapo: 'onHeartbeat' failed 'KeyError':'('result',)'.
2022-05-10 17:42:26.118 Error: Test-Tapo: Exception traceback:
2022-05-10 17:42:26.118 Error: Test-Tapo: ----> Line 207 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function onHeartbeat
2022-05-10 17:42:26.118 Error: Test-Tapo: ----> Line 142 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function onHeartbeat
2022-05-10 17:42:26.118 Error: Test-Tapo: ----> Line 44 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function beatHeartbeat
2022-05-10 17:42:26.118 Error: Test-Tapo: ----> Line 146 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function update
2022-05-10 17:42:26.119 Error: Test-Tapo: ----> Line 124 in '/home/pi/domoticz/plugins/Domoticz-Tapo/PyP100/PyP100.py', function handshake
I tried with buster and bullseye, installed the PyP100.py in the Domotics-Tapo directory, adjusted the permissions to 777, but no success.
Does anybody have an idea ?
belzig
With bullseye the error messages are like this.
2022-05-10 18:41:01.084 Error: Tapo Test: Call to function 'onCommand' failed, exception details:
2022-05-10 18:41:01.085 Error: Tapo Test: Traceback (most recent call last):
2022-05-10 18:41:01.085 Error: Tapo Test: File "/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py", line 195, in onCommand
2022-05-10 18:41:01.085 Error: Tapo Test: _plugin.onCommand(Unit, Command, Level, Hue)
2022-05-10 18:41:01.085 Error: Tapo Test: File "/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py", line 123, in onCommand
2022-05-10 18:41:01.085 Error: Tapo Test: self.p100.handshake()
2022-05-10 18:41:01.085 Error: Tapo Test: File "/usr/local/lib/python3.9/dist-packages/PyP100/PyP100.py", line 124, in handshake
2022-05-10 18:41:01.085 Error: Tapo Test: encryptedKey = r.json()["result"]["key"]
2022-05-10 18:41:01.085 Error: Tapo Test: KeyError: 'result'
2022-05-10 18:41:14.084 Error: Tapo Test: Call to function 'onHeartbeat' failed, exception details:
2022-05-10 18:41:14.085 Error: Tapo Test: Traceback (most recent call last):
2022-05-10 18:41:14.085 Error: Tapo Test: File "/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py", line 207, in onHeartbeat
2022-05-10 18:41:14.085 Error: Tapo Test: _plugin.onHeartbeat()
2022-05-10 18:41:14.085 Error: Tapo Test: File "/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py", line 142, in onHeartbeat
2022-05-10 18:41:14.085 Error: Tapo Test: self.heartbeat.beatHeartbeat()
2022-05-10 18:41:14.085 Error: Tapo Test: File "/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py", line 44, in beatHeartbeat
2022-05-10 18:41:14.085 Error: Tapo Test: self.callback()
2022-05-10 18:41:14.085 Error: Tapo Test: File "/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py", line 146, in update
2022-05-10 18:41:14.085 Error: Tapo Test: self.p100.handshake()
2022-05-10 18:41:14.085 Error: Tapo Test: File "/usr/local/lib/python3.9/dist-packages/PyP100/PyP100.py", line 124, in handshake
2022-05-10 18:41:14.085 Error: Tapo Test: encryptedKey = r.json()["result"]["key"]
2022-05-10 18:41:14.085 Error: Tapo Test: KeyError: 'result'
belzig
It seems that Version 0.0.19 of PyP100 is buggy. I finally installed the version PyP100 0.0.18 and now the Plugin works.
pip uninstall PyP100
sudo pip uninstall PyP100
Probably delete the directory
cd /home/pi/domoticz/plugins
sudo rm -R Domoticz-Tapo
git clone https://github.com/593304/Domoticz-Tapo.git
cd Domoticz-Tapo/
pip install PyP100==0.0.18 --target .
sudo service domoticz restart
cd Domoticz-Tapo/
acuponctus
- Domoticz version: 4.10659
Hi belzig,
I have 2 Tapo plug wich are not in domoticz because of errors.
I try your method, and I have errors :
Do you have same errors ?
And The plug is listed on harware, but nothing in device.
2022-05-20 09:41:23.491 Error: Tapo IP 21: 'onHeartbeat' failed 'Exception':'Error Code: -1501, Invalid Request or Credentials'.
2022-05-20 09:41:23.491 Error: Tapo IP 21: Exception traceback:
2022-05-20 09:41:23.491 Error: Tapo IP 21: ----> Line 207 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function onHeartbeat
2022-05-20 09:41:23.491 Error: Tapo IP 21: ----> Line 142 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function onHeartbeat
2022-05-20 09:41:23.491 Error: Tapo IP 21: ----> Line 44 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function beatHeartbeat
2022-05-20 09:41:23.491 Error: Tapo IP 21: ----> Line 147 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function update
2022-05-20 09:41:23.491 Error: Tapo IP 21: ----> Line 163 in '/usr/local/lib/python3.7/dist-packages/PyP100/PyP100.py', function login
2022-05-20 09:41:24.044 (Tapo IP 21) Acquiring lock for 'Tapo IP 21'
2022-05-20 09:41:24.044 (Tapo IP 21) Releasing lock for 'Tapo IP 21'
2022-05-20 09:41:24.044 Tapo IP 21: Pushing 'onHeartbeatCallback' on to queue
2022-05-20 09:41:24.094 Tapo IP 21: (Tapo IP 21) Processing 'onHeartbeatCallback' message
2022-05-20 09:41:24.094 (Tapo IP 21) Acquiring lock for 'onHeartbeatCallback'
2022-05-20 09:41:24.094 Tapo IP 21: Calling message handler 'onHeartbeat' on 'module' type object.
© 2012-2022 Domoticz | WWW: Domoticz.comAnd The plug is listed on harware, but nothing in device.
ABOX Raspberry Pi 3 Modèle B Plus + 1 en Backup
domoticz V2021.1 - Stick Aeon - 3x multisensors 6+ - Fibaro FGSD-002 - 6 prises Horsky flashées - 2x cameras sv3c et 1x wansview - 3xTH16 2xBasic et 1xRF tous flashés avec EasyESP
2 prises Tapo non reliées
ChrisH
Does anyone know if the P110 plug also works? And if the energy monitoring function is available in Domoticz?
I don't really care about the switching, but I want to use these plugs as cheap (I can get them for as cheap as €12 a piece) energy monitors for some appliances in my home, like the fridge.
belzig
The Line XYZ * function onHeartbeat error usually occurs when the smart Plug is not reachable by domoticz e.g. when the plug has no power.acuponctus wrote: Friday 20 May 2022 10:43 Hi belzig,
Do you have same errors ?Code: Select all
2022-05-20 09:41:23.491 Error: Tapo IP 21: 'onHeartbeat' failed 'Exception':'Error Code: -1501, Invalid Request or Credentials'. 2022-05-20 09:41:23.491 Error: Tapo IP 21: Exception traceback: 2022-05-20 09:41:23.491 Error: Tapo IP 21: ----> Line 207 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function onHeartbeat 2022-05-20 09:41:23.491 Error: Tapo IP 21: ----> Line 142 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function onHeartbeat 2022-05-20 09:41:23.491 Error: Tapo IP 21: ----> Line 44 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function beatHeartbeat 2022-05-20 09:41:23.491 Error: Tapo IP 21: ----> Line 147 in '/home/pi/domoticz/plugins/Domoticz-Tapo/plugin.py', function update 2022-05-20 09:41:23.491 Error: Tapo IP 21: ----> Line 163 in '/usr/local/lib/python3.7/dist-packages/PyP100/PyP100.py', function login 2022-05-20 09:41:24.044 (Tapo IP 21) Acquiring lock for 'Tapo IP 21' 2022-05-20 09:41:24.044 (Tapo IP 21) Releasing lock for 'Tapo IP 21' 2022-05-20 09:41:24.044 Tapo IP 21: Pushing 'onHeartbeatCallback' on to queue 2022-05-20 09:41:24.094 Tapo IP 21: (Tapo IP 21) Processing 'onHeartbeatCallback' message 2022-05-20 09:41:24.094 (Tapo IP 21) Acquiring lock for 'onHeartbeatCallback' 2022-05-20 09:41:24.094 Tapo IP 21: Calling message handler 'onHeartbeat' on 'module' type object. © 2012-2022 Domoticz | WWW: Domoticz.com
Did you check Setup->Settings->System-> Accept New Hardware Devices ?
It seems that you didn`t install the PyP100.py module in to the domoticz/plugins/Domoticz-Tapo/ directory
"2022-05-20 09:41:23.491 Error: Tapo IP 21: ----> Line 163 in '/usr/local/lib/python3.7/dist-packages/PyP100/PyP100.py', function login"
belzig
BTW: If you have WIFI Connection Problems (Lost Connections etc. ) the TAPO firmware upgrade to version 1.4.9 is really helpful
Alain
- Domoticz version: 2022.1
Are there any plans to expand this with support for the Tapo P110 and P115 plugs that have energy monitoring (like the HS110 had)?
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
Destyny
Someone use TAPO P110 with this plugins ? Compatible ?
Thanks,
Thanks,
mjray
- Domoticz version: 2022.2
I have not used it but I've read the code for other reasons. It looks to me like it will be compatible with a P110 but only as a switch. It would need someone to extend the plugin to report the energy sensor data returned by the additional getEnergyUsage method that the P100 doesn't have.Destyny wrote: Saturday 24 September 2022 13:49 Someone use TAPO P110 with this plugins ? Compatible ?
I don't know if you finally found your issue.
I encountered the same one today. After investigating, I finally found that the plugin is not compatible with python3_5. I installed a newer version (3_7) and now it's work without issue
I did't update to the latest version of python in order to avoid incompatibility with other scripts.
Hi,Destyny wrote: Saturday 24 September 2022 13:49 Hi,
Thanks,
I just successfully installed the plugin and it works with my P110 in switch mode.
Unfortunately the power consumption is not managed by the plugin.
MikeF
- Domoticz version: V2022.2
Whilst not helping people who are trying to get power data from the Tapo P115 plugin, I have come across an alternative power monitoring plug, from Local Bytes, available in UK and EU plug formats (£12.50 / €14.95).
It's pre-flashed with Tasmota, and so it can be linked directly to Domoticz, to provide power, voltage and current data, as well as on / off control.
I previously described it here: viewtopic.php?p=299741#p299741
If it can help, I implemented the energy monitoring for the P110: available on github Guintolli/domoticz-P110Tapo-plugin (I don't know how to add external url)
DrakarBarna
Just adding my 2 cents.
I had a TP-Link L610 light and it work with the "TP-Link Tapo Plugin".
But, same as with an L510 light, the dimmer did not work (or I was not able to make it work).
Regards.
Regards.
