jump to my own web pages?
manjh
Domoticz version: 2025.2
Post by manjh »
I am a very enthousiastic user of Domoticz, but sometimes need a specific function that isn't available.
For this I would like to add web pages to which I can jump from the normal Domoticz user interface.
What is the best way to do this? Examples?
Hans
febalci
Re: jump to my own web pages?
Post by febalci »
Check out domoticz/www/templates/custom.example. You should enable Custom page in Settings/SsytemSetup/Active Menus.
As an example rename custom.example to custom.html, restart domoticz. You will see a 'Custom' tab.Under this you can open your own html pages.
manjh
Post by manjh »
febalci wrote: Tuesday 21 November 2017 8:51 Check out domoticz/www/templates/custom.example. You should enable Custom page in Settings/SsytemSetup/Active Menus.
Great! The custom.html is not very clear, there's almost no documentation (not even as comment in the code).
But the main thing is that I understand how to place my own pages in there.
Is there anything in the Wiki about this? If not, it may be worth while for me to document what I am learning and create a few things there!
Hans
febalci
Post by febalci »
manjh wrote: Wednesday 22 November 2017 10:30 Is there anything in the Wiki about this? If not, it may be worth while for me to document what I am learning and create a few things there!
Although i'm not 100% sure, the topic http://domoticz.com/forum/viewtopic.php?f=8&t=4698 might be of help!?
this also in French but you may get the general idea: https://easydomoticz.com/les-custom-pages-domoticz/
Domoticz version: 2026.3
Reviving an old topic as this still was not clearly documented.
But now it started, see wiki page https://www.domoticz.com/wiki/Custom_menu for instructions and examples.
