Script to get data from Solar Invertor to textdevices in Domoticz  [Solved]
Freakandel
Post by Freakandel »
I would like to get actual data from our Solar Invertor (Fronius) in Domoticz, so I can use this data for further automation of things. I found on this Forum a Python plugin but that is not working with my model invertor. It looks like it should be not too hard to get it working in dzVents.
The URL for connecting to the Fronius Inverter is in my case:
http://192.168.1.60/solar_api/v1/GetInv ... verterData
The output is as following:
   "Body" : {
      "Data" : {
         "DAY_ENERGY" : {
            "Unit" : "Wh",
            "Value" : 710.10000000000002
         "DeviceStatus" : {
            "ErrorCode" : 522,
            "LEDColor" : 2,
            "LEDState" : 0,
            "MgmtTimerRemainingTime" : -1,
            "StateToReset" : true,
            "StatusCode" : 7
         "FAC" : {
            "Unit" : "Hz",
            "Value" : 49.960000000000001
         "IAC" : {
            "Unit" : "A",
            "Value" : 0.23999999999999999
         "IDC" : {
            "Unit" : "A",
            "Value" : 0.52000000000000002
         "PAC" : {
            "Unit" : "W",
            "Value" : 33
         "TOTAL_ENERGY" : {
            "Unit" : "Wh",
            "Value" : 710
         "UAC" : {
            "Unit" : "V",
            "Value" : 225.90000000000001
         "UDC" : {
            "Unit" : "V",
            "Value" : 0.5
         "YEAR_ENERGY" : {
            "Unit" : "Wh",
   "Head" : {
      "RequestArguments" : {
         "DataCollection" : "CommonInverterData",
         "DeviceClass" : "Inverter",
         "DeviceId" : "1",
         "Scope" : "Device"
      "Status" : {
         "Code" : 0,
         "Reason" : "",
         "UserMessage" : ""
      "Timestamp" : "2020-11-15T14:20:52+01:00"
It would be nice to get the Day Energy, PAC, Total Energy and Year Energy in Domoticz (text?) devices for further analysis and automation.
Can someone help me with a bit of scripting? Many thanks!
Toulon7559
Domoticz version: <2025
Re: Script to get data from Solar Invertor to textdevices in Domoticz
Post by Toulon7559 »
As intermediary for information from Solar inverters Domoticz has nice Virtual Devices for Energy & Power:
why not use those Virtual Devices?
Just look into the examples in this Forum how to fill them, how to read them and how to apply for control functions.
Freakandel wrote: Sunday 15 November 2020 20:13 I would like to get actual data from our Solar Invertor (Fronius) in Domoticz,
Could look like below script
         Fronius.lua
        Script to collect information from a Fronius solar inverter and store it in a virtual (text) sensor
        History:
        20201115 initial release
local scriptVar = 'Fronius'
return
    on =
        timer =
            'every minute', -- set to the required frequency
        httpResponses =
            scriptVar,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    execute = function(dz, item)
        local textDevice = dz.devices('Fronius')
        if item.isTimer then
            dz.openURL(
                url = 'http://192.168.1.60/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceID=1&DataCollection=CommonInverterData',
                callback = scriptVar,
            return
        if item.ok and item.isJSON then
            local rt = item.json.Body.Data
            local text = ''
            text = text .. 'Current power: ' .. (rt.PAC.Value or '-') .. ' W\n'
            text = text .. 'Day energy: ' .. ( rt.DAY_ENERGY.Value or '-' )   .. ' Wh\n'
            text = text .. 'Total energy: ' .. (rt.TOTAL_ENERGY.Value or '-' ) .. ' Wh\n'
            text = text .. 'Year energy: ' .. (rt.YEAR_ENERGY.Value or '-' ) .. ' Wh'
            dz.log('\n' .. text,dz.LOG_DEBUG)
            textDevice.updateText(text)
            dz.log('There was a problem handling the request', dz.LOG_ERROR)
            dz.log(item, dz.LOG_DEBUG)
Freakandel
Thanks Waaren, again, for your input. I will try this out today!
Freakandel
@Waaren: the script is working and the readings from Fronius are in the Dummy Sensor in Domoticz now. I would like to get 4 different dummy sensors (energy based, so there is graphics behind the sensor) in stead of text for all values in one dummy device. Is this much effort to change in the script?
@Freakandel
It is not much effort to make these changes in the script. Please have a look at the dzVents wiki and examples and give it a try.
When you got stuck or have a question please feel free to ask.
Freakandel
Hi Waaren, I will give it a try, but your script looks already to complicated for me to get my head around ;-). I will get into the documents and hope I can figure it out. Thanks for your effort!
Freakandel
- keep loosing my post here, there looks something broken in the editor on this forum -
I think I'm on the right track but keep getting errormessages in Domoticz. I've used your script and changed the lower part of it to get the values from the Fronium in the 4 'energy' dummy devices. It seems however that the Fronius changes the output in the API when there is no sunlight: the PAC value is no longer in the json output. In that case, the value of the switch should be 0 (zero).
I can't copy the script in this Quick Reply editor, but the normal editor is not working, at least for me. This is my current version:
return
on =
timer =
httpResponses =
scriptVar,
logging =
marker = scriptVar,
dz.openURL(
url = 'http://192.168.1.60/solar_api/v1/GetInv ... verterData',
return
--domoticz.devices('curSolEnergy').updateEnergy(rt.PAC.Value)
domoticz.devices('daySolEnergy').updateEnergy(rt.DAY_ENERGY.Value)
domoticz.devices('totalSolEnergy').updateEnergy(rt.TOTAL_ENERGY.Value)
domoticz.devices('yearSolEnergy').updateEnergy(rt.YEAR_ENERGY.Value)
-- dz.log('\n' .. text,dz.LOG_DEBUG)
This is the error I receive in the log of Domoticz:
2020-11-16 21:38:03.131 Error: dzVents: Error: (3.0.16) Fronius: An error occurred when calling event handler Script #2
2020-11-16 21:38:03.131 Error: dzVents: Error: (3.0.16) Fronius: ...domoticz/scripts/dzVents/generated_scripts/Script #2.lua:51: attempt to index a nil value (global
A little help please?
Freakandel
PS. you shure can call me a noob, I am so I will not be offended ;-)
Freakandel wrote: Monday 16 November 2020 21:56Fronius: ...domoticz/scripts/dzVents/generated_scripts/Script #2.lua:51:
You are already quite close. Main issue is that you used domoticz as name for the domoticz object while the script refers to it as dz
Can you try this one?
return
    on =
        timer =
        httpResponses =
        scriptVar,
    logging =
        marker = scriptVar,
            dz.openURL(
            return
            dz.devices('curSolEnergy').updateEnergy( (rt.PAC and rt.PAC.Value ) or 0) -- if rt.PAC exists it will take its Value and if not it will be 0
            dz.devices('daySolEnergy').updateEnergy(rt.DAY_ENERGY.Value)
            dz.devices('totalSolEnergy').updateEnergy(rt.TOTAL_ENERGY.Value)
            dz.devices('yearSolEnergy').updateEnergy(rt.YEAR_ENERGY.Value)
Freakandel
Re: Script to get data from Solar Invertor to textdevices in Domoticz  [Solved]
Hi Waaren, tested this script and get rid of a little typo in the URL, now it works like a charme! Thanks again for your help. I'm a bit closer to understanding how dzEvents works thanks to you!
psubiaco
Post by psubiaco »
I've created a wiki page about Fronius Inverter: https://www.domoticz.com/wiki/Fronius_inverter
You can find there a simple LUA script that fetches data from the inverter, no need for any plugin.
Of course, anyone is able to modify the page to integrate plugins, other scripts, ....
Paolo
