Upgrading Raspberry Pi can not move Domoticz
JackVeraart
- Domoticz version: 2023.1
I have 2 uSD cards.
One 'old' with an updated Domoticz Version: 2022.1 Build Hash: c9526851b on buster and I want to upgrade to bullseye so I have a 2nd 'new' uSD card for that and have already a lot running like on the 'old' one. pivpn, minidlna and some other things and now I want to get Domoticz from the old card to the new one and installed Domoticz by 'sudo curl -L https://install.domoticz.com | sudo bash'. Empty Domoticz runs fine but I want my old stuff. I made a backup in Domoticz on the old card which landed in de the downloads folder on my linux laptop as Domoticz.db. I also have a copy of all the plugins. So now I moved all the plugins to the new domoticz/plugins folder and restarted the new Domoticz and would able to Hardware with them. I see them in the dropdownbox but I do not use them because I want to restore the database. Now when I browse to the backuop I made and try a restore Domoticz does not like this. Restarting does not help. I get a domoticz_crash.log. I tried the old card and that is still running Domoticz fine so the backup should be fine also. I also tried a reinstall on the new one, stopped Domoticz and copied the plugins again and copied the backup Domoticz.db to domoticz.db directly. Same result. I stopped domoticz and copied the whole old tree from the old uSD to my linux laptop, inserted the new uSD with the new domoticz, stopped that domoticz off course and copied the complete tree to the new uSD. also generates a domoticz_crash.log.
Can someone help me please ?
Example of a domoticz_crash.log :
gdb: warning: Couldn't determine a path for the index cache directory.
[New LWP 1741]
[New LWP 1742]
[New LWP 1743]
[New LWP 1744]
[New LWP 1745]
[New LWP 1746]
[New LWP 1747]
[New LWP 1748]
[New LWP 1749]
[New LWP 1750]
[New LWP 1751]
[New LWP 1752]
[New LWP 1753]
[New LWP 1754]
[New LWP 1755]
[New LWP 1756]
[New LWP 1757]
[New LWP 1758]
[New LWP 1759]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
0xb6926f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0xbed0f988, req@entry=0xbed0f980, rem=0xbed0f998, rem@entry=0xbed0f990) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
52 ../sysdeps/unix/sysv/linux/clock_nanosleep.c: No such file or directory.
Id Target Id Frame
* 1 Thread 0xb6fa7240 (LWP 1740) "domoticz" 0xb6926f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0xbed0f988, req@entry=0xbed0f980, rem=0xbed0f998, rem@entry=0xbed0f990) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
2 Thread 0xb5923200 (LWP 1741) "Watchdog" 0xb6926f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0xb5922b70, req@entry=0xb5922b68, rem=0xb5922b80, rem@entry=0xb5922b78) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
3 Thread 0xb5122200 (LWP 1742) "SQLHelper" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
4 Thread 0xb4921200 (LWP 1743) "PluginMgr" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
5 Thread 0xb3ab3200 (LWP 1744) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
6 Thread 0xb32b2200 (LWP 1745) "Webem_ssncleane" 0xb696663c in epoll_wait (epfd=16, events=0xb32b1358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
7 Thread 0xb2ab1200 (LWP 1746) "WebServer_8080" 0xb696663c in epoll_wait (epfd=12, events=0xb2ab0328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
8 Thread 0xb20ff200 (LWP 1747) "Webem_ssncleane" 0xb696663c in epoll_wait (epfd=23, events=0xb20fe358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
9 Thread 0xb18fe200 (LWP 1748) "WebServer_444" 0xb696663c in epoll_wait (epfd=19, events=0xb18fd328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
10 Thread 0xb0eff200 (LWP 1749) "Scheduler" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
11 Thread 0xb06fe200 (LWP 1750) "TCPServer" 0xb696663c in epoll_wait (epfd=26, events=0xb06fd358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
12 Thread 0xafcff200 (LWP 1751) "MainWorker" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xafcfae10, clockid=<optimized out>, expected=0, futex_word=0xb5e1d9ec <_PyRuntime+260>) at ../sysdeps/nptl/futex-internal.h:323
13 Thread 0xaf4fe200 (LWP 1752) "MainWorkerRxMsg" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xaf4fdb80, clockid=<optimized out>, expected=0, futex_word=0xa8e3b0 <m_mainworker+3984>) at ../sysdeps/nptl/futex-internal.h:323
14 Thread 0xae8ff200 (LWP 1753) "Oneliners" futex_abstimed_wait_cancelable (private=0, abstime=0x0, clockid=0, expected=1, futex_word=0x1534b10) at ../sysdeps/nptl/futex-internal.h:323
15 Thread 0xae0fe200 (LWP 1754) "Fan" 0xb692d4d4 in __GI___wait4 (pid=1760, stat_loc=0xad784f00, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
16 Thread 0xad6ff200 (LWP 1755) "THP" futex_abstimed_wait_cancelable (private=0, abstime=0x0, clockid=0, expected=1, futex_word=0x1534b10) at ../sysdeps/nptl/futex-internal.h:323
17 Thread 0xacefe200 (LWP 1756) "Toon 2 Monitor" futex_abstimed_wait_cancelable (private=0, abstime=0x0, clockid=0, expected=1, futex_word=0x1534b10) at ../sysdeps/nptl/futex-internal.h:323
18 Thread 0xac6fd200 (LWP 1757) "Internet Radio" futex_abstimed_wait_cancelable (private=0, abstime=0x0, clockid=0, expected=1, futex_word=0x1534b10) at ../sysdeps/nptl/futex-internal.h:323
19 Thread 0xabefc200 (LWP 1758) "NotificationSys" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xabefbbb0, clockid=<optimized out>, expected=0, futex_word=0xa8de78 <m_mainworker+2648>) at ../sysdeps/nptl/futex-internal.h:323
20 Thread 0xab63b200 (LWP 1759) "Plugin_ASIO" futex_wait_cancelable (private=0, expected=0, futex_word=0x1525438) at ../sysdeps/nptl/futex-internal.h:186
Thread 20 (Thread 0xab63b200 (LWP 1759) "Plugin_ASIO"):
#0 futex_wait_cancelable (private=0, expected=0, futex_word=0x1525438) at ../sysdeps/nptl/futex-internal.h:186
#1 __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x0, cond=0x1525410) at pthread_cond_wait.c:508
#2 __pthread_cond_wait (cond=0x1525410, mutex=0x0) at pthread_cond_wait.c:638
#3 0x003d727c in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
#4 0x00683e74 in Plugins::BoostWorkers() ()
#5 0x0077d374 in thread_proxy ()
#6 0xb6aa2300 in start_thread (arg=0xab63b200) at pthread_create.c:477
#7 0xb6966208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 19 (Thread 0xabefc200 (LWP 1758) "NotificationSys"):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xabefbbb0, clockid=<optimized out>, expected=0, futex_word=0xa8de78 <m_mainworker+2648>) at ../sysdeps/nptl/futex-internal.h:323
#1 __pthread_cond_wait_common (abstime=0xabefbbb0, clockid=<optimized out>, mutex=0x0, cond=0xa8de50 <m_mainworker+2608>) at pthread_cond_wait.c:520
#2 __pthread_cond_timedwait (cond=0xa8de50 <m_mainworker+2608>, mutex=0x0, abstime=0xabefbbb0) at pthread_cond_wait.c:656
#3 0x00277298 in CNotificationSystem::QueueThread() ()
#4 0x00906734 in execute_native_thread_routine ()
#5 0xb6aa2300 in start_thread (arg=0xabefc200) at pthread_create.c:477
#6 0xb6966208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 18 (Thread 0xac6fd200 (LWP 1757) "Internet Radio"):
#0 futex_abstimed_wait_cancelable (private=0, abstime=0x0, clockid=0, expected=1, futex_word=0x1534b10) at ../sysdeps/nptl/futex-internal.h:323
#1 do_futex_wait (sem=sem@entry=0x1534b10, abstime=0x0, clockid=0) at sem_waitcommon.c:117
#2 0xb6aadc80 in __new_sem_wait_slow (sem=0x1534b10, abstime=0x0, clockid=0) at sem_waitcommon.c:285
#3 0xb5b30490 in PyThread_acquire_lock_timed () from /lib/arm-linux-gnueabihf/libpython3.9.so
#4 0xb5b30770 in PyThread_acquire_lock () from /lib/arm-linux-gnueabihf/libpython3.9.so
#5 0x00000000 in ?? ()
Thread 17 (Thread 0xacefe200 (LWP 1756) "Toon 2 Monitor"):
Thread 16 (Thread 0xad6ff200 (LWP 1755) "THP"):
Thread 15 (Thread 0xae0fe200 (LWP 1754) "Fan"):
#0 0xb692d4d4 in __GI___wait4 (pid=1760, stat_loc=0xad784f00, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
#1 0x0029121c in dumpstack_gdb(bool) ()
#2 0x002917e8 in signal_handler(int, siginfo_t*, void*) ()
#3 <signal handler called>
#4 raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
#5 <signal handler called>
#6 0x00000014 in ?? ()
#7 0x00679ef0 in Plugins::CPlugin::Start() ()
#8 0x00682f60 in Plugins::onStartCallback::ProcessLocked(Plugins::CPlugin*) ()
#9 0x002181fc in Plugins::CPluginMessageBase::Process(Plugins::CPlugin*) ()
#10 0x0068069c in Plugins::CPlugin::Do_Work() ()
#11 0x00906734 in execute_native_thread_routine ()
#12 0xb6aa2300 in start_thread (arg=0xae0fe200) at pthread_create.c:477
#13 0xb6966208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 14 (Thread 0xae8ff200 (LWP 1753) "Oneliners"):
Thread 13 (Thread 0xaf4fe200 (LWP 1752) "MainWorkerRxMsg"):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xaf4fdb80, clockid=<optimized out>, expected=0, futex_word=0xa8e3b0 <m_mainworker+3984>) at ../sysdeps/nptl/futex-internal.h:323
#1 __pthread_cond_wait_common (abstime=0xaf4fdb80, clockid=<optimized out>, mutex=0xb6a9da1c, cond=0xa8e388 <m_mainworker+3944>) at pthread_cond_wait.c:520
#2 __pthread_cond_timedwait (cond=0xa8e388 <m_mainworker+3944>, mutex=0xb6a9da1c, abstime=0xaf4fdb80) at pthread_cond_wait.c:656
#3 0x00263724 in MainWorker::Do_Work_On_Rx_Messages() ()
#5 0xb6aa2300 in start_thread (arg=0xaf4fe200) at pthread_create.c:477
Thread 12 (Thread 0xafcff200 (LWP 1751) "MainWorker"):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0xafcfae10, clockid=<optimized out>, expected=0, futex_word=0xb5e1d9ec <_PyRuntime+260>) at ../sysdeps/nptl/futex-internal.h:323
#1 __pthread_cond_wait_common (abstime=0xafcfae10, clockid=<optimized out>, mutex=0x0, cond=0xb5e1d9c0 <_PyRuntime+216>) at pthread_cond_wait.c:520
#2 __pthread_cond_timedwait (cond=0xb5e1d9c0 <_PyRuntime+216>, mutex=0x0, abstime=0xafcfae10) at pthread_cond_wait.c:656
#3 0xb5ad5e90 in ?? () from /lib/arm-linux-gnueabihf/libpython3.9.so
Thread 11 (Thread 0xb06fe200 (LWP 1750) "TCPServer"):
#0 0xb696663c in epoll_wait (epfd=26, events=0xb06fd358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#1 0x003d519c in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
#2 0x003d7194 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
#3 0x006e0d80 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<tcp::server::CTCPServer::StartServer(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#1}> > >::_M_run() ()
#5 0xb6aa2300 in start_thread (arg=0xb06fe200) at pthread_create.c:477
Thread 10 (Thread 0xb0eff200 (LWP 1749) "Scheduler"):
#0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
#1 0x008e41a4 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
#2 0x00288690 in CScheduler::Do_Work() ()
#3 0x00906734 in execute_native_thread_routine ()
#4 0xb6aa2300 in start_thread (arg=0xb0eff200) at pthread_create.c:477
#5 0xb6966208 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 9 (Thread 0xb18fe200 (LWP 1748) "WebServer_444"):
#0 0xb696663c in epoll_wait (epfd=19, events=0xb18fd328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#3 0x0072bc88 in http::server::server_base::run() ()
#4 0x002d9bfc in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::CWebServer::StartServer(http::server::server_settings&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)::{lambda()#280}> > >::_M_run() ()
#5 0x00906734 in execute_native_thread_routine ()
#6 0xb6aa2300 in start_thread (arg=0xb18fe200) at pthread_create.c:477
Thread 8 (Thread 0xb20ff200 (LWP 1747) "Webem_ssncleane"):
#0 0xb696663c in epoll_wait (epfd=23, events=0xb20fe358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#3 0x006fc0b4 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::cWebem::cWebem(http::server::server_settings const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#2}> > >::_M_run() ()
#5 0xb6aa2300 in start_thread (arg=0xb20ff200) at pthread_create.c:477
Thread 7 (Thread 0xb2ab1200 (LWP 1746) "WebServer_8080"):
#0 0xb696663c in epoll_wait (epfd=12, events=0xb2ab0328, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#6 0xb6aa2300 in start_thread (arg=0xb2ab1200) at pthread_create.c:477
Thread 6 (Thread 0xb32b2200 (LWP 1745) "Webem_ssncleane"):
#0 0xb696663c in epoll_wait (epfd=16, events=0xb32b1358, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#5 0xb6aa2300 in start_thread (arg=0xb32b2200) at pthread_create.c:477
Thread 5 (Thread 0xb3ab3200 (LWP 1744) "InfluxPush"):
#2 0x00393ed0 in CInfluxPush::Do_Work() ()
#4 0xb6aa2300 in start_thread (arg=0xb3ab3200) at pthread_create.c:477
Thread 4 (Thread 0xb4921200 (LWP 1743) "PluginMgr"):
#2 0x00684684 in Plugins::CPluginSystem::Do_Work() ()
#4 0xb6aa2300 in start_thread (arg=0xb4921200) at pthread_create.c:477
Thread 3 (Thread 0xb5122200 (LWP 1742) "SQLHelper"):
#2 0x002a8698 in CSQLHelper::Do_Work() ()
#4 0xb6aa2300 in start_thread (arg=0xb5122200) at pthread_create.c:477
Thread 2 (Thread 0xb5923200 (LWP 1741) "Watchdog"):
#0 0xb6926f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0xb5922b70, req@entry=0xb5922b68, rem=0xb5922b80, rem@entry=0xb5922b78) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
#1 0xb6927080 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0xb5922bb0) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
#2 0xb692d830 in __GI___nanosleep (requested_time=<optimized out>, remaining=<optimized out>) at nanosleep.c:27
#3 0x00224e2c in sleep_milliseconds(long) ()
#4 0x00291950 in Do_Watchdog_Work() ()
#6 0xb6aa2300 in start_thread (arg=0xb5923200) at pthread_create.c:477
Thread 1 (Thread 0xb6fa7240 (LWP 1740) "domoticz"):
#0 0xb6926f8c in __GI___clock_nanosleep_time64 (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0xbed0f988, req@entry=0xbed0f980, rem=0xbed0f998, rem@entry=0xbed0f990) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:52
#1 0xb6927080 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=<optimized out>, rem=0xbed0f9c8) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:92
#3 0x00224d98 in sleep_seconds(long) ()
#4 0x001af740 in main ()
Main thread:
[Inferior 1 (process 1740) detached]
[New LWP 1741]
[New LWP 1742]
[New LWP 1743]
[New LWP 1744]
[New LWP 1745]
[New LWP 1746]
[New LWP 1747]
[New LWP 1748]
[New LWP 1749]
[New LWP 1750]
[New LWP 1751]
[New LWP 1752]
[New LWP 1753]
[New LWP 1754]
[New LWP 1755]
[New LWP 1756]
[New LWP 1757]
[New LWP 1758]
[New LWP 1759]
Id Target Id Frame
Main thread:
R. Pi 3 : pivpn, Pi-Hole, minidlna,....... Domoticz with own plugins only
R. Pi 4 : pivpn, NextCloud, minidlna... Domoticz with own plugins only
Toon 1 & 2 with own apps
Some plugins, apps and notes : https://github.com/JackV2020
- FireWizard
Re: Upgrading Raspberry Pi can not move Domoticz
Hello @JackVeraart,
Domoticz is currently incompatible with Bullseye.
See the various posts in this forum.
JackVeraart
Hello @FireWizard,
Thanks for the fast response but......Auw, so sad to hear that.
So it will not run at all, also not when I just add the Hardware in the new setup and forget about my history?
Did not look for Bullseye issues yet but maybe you know when Bullseye will be supported ?
- FireWizard
Hi @JackVeraart,
No, I cannot tell you when these issue wiil be solved.
Sorry for that.
Sorry for that.
- Domoticz version: 2026.3
It is worked on but a lot of work as complete python framewerk has to be evaluated and a lot of parts rewritten.
For more info take a peek in the following topic: https://domoticz.com/forum/viewtopic.php?t=37376
JackVeraart
Thanks for the update. I am looking forward to the new version.
Is there a way to get a notification when it is available, maybe for beta testing ?
I can always get an extra uSD card to make a test installation.
Since I am retired I have some spare time available.....
Subscribe to the other topic and you will be notified if someone updates the topic. Hopefully also with the message that it is solved in a beta release.JackVeraart wrote: Wednesday 09 February 2022 9:21 Thanks for the update. I am looking forward to the new version.
- HansieNL
@JackVeraart There’s also a very recent Raspberry Pi OS (Legacy) version Buster.
You can find this version here https://www.raspberrypi.com/software/operating-systems/
Maybe you can try this version and see if the Python plugins works.
Blah blah blah
JackVeraart
@HansieNL
many thanks for the good suggestion to install on Buster.
I know that Domoticz will work on that because that is what was running on my Pi before and is still running on my other Pi. I will stick with Bullseye on this one and wait (im)patiently for Domoticz to become available on Bullseye. I already have samba, minidlna, openvpn, apache, mariadb and other stuff running and am now busy to get Nextcloud 23.0.1 up and running with PHP 8.0.
Thanks again!!
Thanks again!!
