SML 1.04 ir adapter for DTZ-541 Stromzaehler
sailmich
I'm trying to get data from usb ir-connector connected via usb with my RPi. I tried P1 smartmeter without success. In iobroker wich I installed for testing it is running with a smartmeter app. I get datas eg. momentary current/overall current. Does domoticz have a plugin to handle smart massage language SML 1.04.
- FireWizard
Re: SML 1.04 ir adapter for DTZ-541 Stromzaehler
Hello @ sailmich,
You might want to look at Node-RED. You can load the module: https://flows.nodered.org/node/node-red ... smartmeter
This smart-meter module is based on library: https://github.com/Apollon77/smartmeter-obis
If you read its README file you will see:
Try, if you can collect the data from your device in Node-RED. If so, it's quite easy to send the data to a virtual device in Domoticz by means of MQTT.Supported Protocols:
SmlProtocol: SML (SmartMeterLanguage) as binary format
D0Protocol: D0 (based on IEC 62056-21:2002/IEC 61107/EN 61107) as ASCII format (binary protocol mode E not supported currently)
JsonEfrProtocol: OBIS data from EFR Smart Grid Hub (JSON format)
- Domoticz version: 2026.3
What about this: https://github.com/StefKode/smlogger
See also https://domoticz.com/forum/viewtopic.ph ... 26#p285326 for a user who has solution with Tasmota- MQTT
sailmich
Thx for your answers! Thought it would be easier. Got some homework from your posts and will check it. I will let you know which way I decided or when I have questions.
It should not be that hard. Can you read already the energy values with a bash or python script on your Pi?
Because then you could extend that script with the push to Domoticz.
Can you give an example what you can read?
sailmich
ir reader on my energy main counter connected with usb to Rpi iobroker. With mqtt on my domoticz server I subscribe to topic Gesamtverbrauch and Momentanverbrauch on my iobroker client. In a terminal with mosquitto I get
Node red flow in this case for Momentanverbrauch. Momentanverbrauch Unit is Watt.
- Spoiler: show
- FireWizard
Hello @sailmich
I do not know what the format is of your received message. I tested it with a simple value (in this case 597), represented as a string.
If you can connect a debug node after the MQTT input node (as shown on the picture below), I can check your function node.
I injected a string value (597) to your topic Momentanverbrauch and this is received by your MQTT input node.
You can see that on the first received message. On the second message you see the result of the output of your function node.
The svalue is undefined and that results in that the Domoticz virtual sensor is not updated.
But as said earlier, I'm not sure that the injected message is correct.
I modified your function node into:
Your declaration of a new variable (msg1) is not necessary, as there exist only 1 message for the output.
The result you will see in the last message of the picture above,
Complete flow, you will find below:
Let me know.
msg.payload = { "command": "udevice", "idx": 485, "nvalue": 0, "svalue": msg.payload };
return msg;The result you will see in the last message of the picture above,
[{"id":"f6c7807cab872308","type":"tab","label":"iobrokerZuDomoticz","disabled":false,"info":"","env":[]},{"id":"1ed653afb7e5303b","type":"mqtt in","z":"f6c7807cab872308","name":"Strom aktuell","topic":"Momentanverbrauch","qos":"1","datatype":"auto","broker":"f9f13036.e28b58","nl":false,"rap":true,"rh":0,"inputs":0,"x":190,"y":100,"wires":[["c3accf01d66fafc7","29aadd3461791c27"]]},{"id":"c3accf01d66fafc7","type":"function","z":"f6c7807cab872308","name":"","func":"msg.payload = { \"command\": \"udevice\", \"idx\": 485, \"nvalue\": 0, \"svalue\": msg.payload };\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":380,"y":100,"wires":[["c3ef3855cd5673a9"]]},{"id":"3ec6e831b9bc19ac","type":"mqtt out","z":"f6c7807cab872308","name":"domoticz/in","topic":"domoticz/in","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"f9f13036.e28b58","x":570,"y":100,"wires":[]},{"id":"c3ef3855cd5673a9","type":"debug","z":"f6c7807cab872308","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":570,"y":60,"wires":[]},{"id":"29aadd3461791c27","type":"debug","z":"f6c7807cab872308","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":390,"y":160,"wires":[]},{"id":"4bf2a1da2b1f3171","type":"mqtt out","z":"f6c7807cab872308","name":"MQTT Out","topic":"Momentanverbrauch","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"f9f13036.e28b58","x":390,"y":260,"wires":[]},{"id":"81dba57675f8969b","type":"inject","z":"f6c7807cab872308","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"597","payloadType":"str","x":210,"y":260,"wires":[["4bf2a1da2b1f3171"]]},{"id":"f9f13036.e28b58","type":"mqtt-broker","name":"localhost","broker":"127.0.0.1","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]Regards
sailmich
@FireWizard, I just took your modified function node and get the correct instant Watt into my domoticz device!
But I assume it wouldn't work the way I choose. I have to get booth values into my function node to modify the dummy devices
msg.payload = { "command": "udevice", "idx": 484, "nvalue": 0, "svalue":POWER;ENERGY };
How can I bring two topics Gesamtverbrauch = Energy and Momentanverbrauch Power into a function node?
I did that because later I would like to get booth values into Electricity (instant/counter) dummy device.Your declaration of a new variable (msg1) is not necessary, as there exist only 1 message for the output.
- FireWizard
Hello @sailmich,
You said:
You only need that, in case you want to send from the same Function node multiple messages, either to the same output or to different outputs,
Multiple messages are needed in case of multiple virtual sensors. This is not the case.
You want:
Therefore for simulation I created 1 Inject nodes (See picture)
In order to combine these 2 messages, you have to use a "Join" node. I use the msg.topic as the key/value pair. As soon as the "Join" node has received two messages it will send to the output.
See the picture below:
The picture is self-explanatory.
The contents of the Function node is now as follows:
Remarks!
1. The semicolon is part of the string and so should be concatenated and between " ".
2. Domoticz expert the Energy in Wh, If you send the data in kWH (what I assumed), you have to multiply with 1000.
See the result below:
The complete flow below:
Let me know, if this is what you want.
The result you will see in the last message of the picture above.
Also, if you want to send 2 or more values to the same virtual sensor, you do not need multiple msg definitions.I did that because later I would like to get booth values into Electricity (instant/counter) dummy device.
You want:
This is correct.msg.payload = { "command": "udevice", "idx": 484, "nvalue": 0, "svalue":POWER;ENERGY };
I assume that these two values are not in the same message but in two different messages with the topics Momentanverbrauch and Gesamtverbrauch.How can I bring two topics Gesamtverbrauch = Energy and Momentanverbrauch Power into a function node?
msg.payload = { "command": "udevice", "idx": 485, "nvalue": 0, "svalue": msg.payload.Momentanverbrauch + ";" + (msg.payload.Gesamtverbrauch) * 1000 };
return msg;1. The semicolon is part of the string and so should be concatenated and between " ".
[{"id":"f6c7807cab872308","type":"tab","label":"iobrokerZuDomoticz","disabled":false,"info":"","env":[]},{"id":"1ed653afb7e5303b","type":"mqtt in","z":"f6c7807cab872308","name":"Strom aktuell","topic":"Momentanverbrauch","qos":"1","datatype":"auto","broker":"f9f13036.e28b58","nl":false,"rap":true,"rh":0,"inputs":0,"x":190,"y":100,"wires":[["559fb68b706cd711"]]},{"id":"c3accf01d66fafc7","type":"function","z":"f6c7807cab872308","name":"","func":"msg.payload = { \"command\": \"udevice\", \"idx\": 485, \"nvalue\": 0, \"svalue\": msg.payload.Momentanverbrauch + \";\" + (msg.payload.Gesamtverbrauch) * 1000 };\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":140,"wires":[["c3ef3855cd5673a9"]]},{"id":"3ec6e831b9bc19ac","type":"mqtt out","z":"f6c7807cab872308","name":"domoticz/in","topic":"domoticz/in","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"f9f13036.e28b58","x":770,"y":140,"wires":[]},{"id":"c3ef3855cd5673a9","type":"debug","z":"f6c7807cab872308","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":60,"wires":[]},{"id":"29aadd3461791c27","type":"debug","z":"f6c7807cab872308","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":550,"y":60,"wires":[]},{"id":"4bf2a1da2b1f3171","type":"mqtt out","z":"f6c7807cab872308","name":"MQTT Out","topic":"Momentanverbrauch","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"f9f13036.e28b58","x":390,"y":260,"wires":[]},{"id":"81dba57675f8969b","type":"inject","z":"f6c7807cab872308","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"597","payloadType":"str","x":210,"y":260,"wires":[["4bf2a1da2b1f3171"]]},{"id":"6d3e0f9c584d476f","type":"mqtt in","z":"f6c7807cab872308","name":"Strom gesamt","topic":"Gesamtverbrauch","qos":"1","datatype":"auto","broker":"f9f13036.e28b58","nl":false,"rap":true,"rh":0,"inputs":0,"x":190,"y":180,"wires":[["559fb68b706cd711"]]},{"id":"b7531d04bc3918e8","type":"mqtt out","z":"f6c7807cab872308","name":"MQTT Out","topic":"Gesamtverbrauch","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"f9f13036.e28b58","x":390,"y":340,"wires":[]},{"id":"558e23349b261fdb","type":"inject","z":"f6c7807cab872308","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"11313.0046","payloadType":"str","x":210,"y":340,"wires":[["b7531d04bc3918e8"]]},{"id":"559fb68b706cd711","type":"join","z":"f6c7807cab872308","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":370,"y":140,"wires":[["29aadd3461791c27","c3accf01d66fafc7"]]},{"id":"f9f13036.e28b58","type":"mqtt-broker","name":"localhost","broker":"127.0.0.1","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]Regards
sailmich
Hello FireWizard, fantastic! But I'm to leazy to read the documentation of domoticz json/api
. Electricity (Instant/Counter) energy is todays consumption and not the total of my counter. I don't get a daily from my ir reader so I have to stay with first your flow and set counter to energy read: computed. The other value Gesamtverbrauch I will sent to /json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=COUNTER;USAGE;DATE. Because this value is not interesting to see it in real time I would like to update eg. every day at 23:00. Can I use inject for that?
Thanks a lot for your time and help!
sailmich
No, I can't. I must dig deeper into node red. I found some timer but so far can't get it working.
Just to check:
Gesamtverbrauch seems to be the correct value for ENERGY, perhaps needs a 1000 multiplier as it needs (as already explained by Firewizard) Wh values.
If you get Momentanverbrauch (= POWER) and no Gesamtverbrauch perhaps it is possible to use the last sent Gesamtverbrauch or ENERGY value if Node-Red is able to remember that.
The best value you get if Gesamtverbrauch is used.
- FireWizard
@sailmich
You asked:
I use the following timer: node-red-contrib-moment.
I used it to convert the epoch time to the by Domoticz expected date/time.
See the example flow below:
You can see the 3 debug messages below:
Some Remarks
1. I used as IP address 127.0.0.1 (localhost). If your Domoticz has a different address than your Node-RED you will have to change that.
2. Check also the Join node, Compared to my previous post I unticked "and every subsequent message." This means that the Join node has to receive the value AND the data/time. I joined these two messages into 1 and prepared the URL.
See below the complete flow:
Let me know the result, as it is untested.
You asked:
Yes you can.Can I use inject for that?
See below an example flow.I found some timer but so far can't get it working.
Some Remarks
[{"id":"7ff754e7b87b4a38","type":"mqtt in","z":"f6c7807cab872308","name":"Strom gesamt","topic":"Gesamtverbrauch","qos":"1","datatype":"auto","broker":"f9f13036.e28b58","nl":false,"rap":true,"rh":0,"inputs":0,"x":170,"y":500,"wires":[["587c60e05ae3cba3"]]},{"id":"fe21907678de1d0b","type":"inject","z":"f6c7807cab872308","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"00 12 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":560,"wires":[["d3e527a6c51a2444"]]},{"id":"d3e527a6c51a2444","type":"moment","z":"f6c7807cab872308","name":"","topic":"date","input":"payload","inputType":"msg","inTz":"Europe/Berlin","adjAmount":0,"adjType":"days","adjDir":"add","format":"DD-MM-YYYY HH:mm:ss","locale":"en-US","output":"payload","outputType":"msg","outTz":"Europe/Berlin","x":350,"y":560,"wires":[["4219702fa390e412","587c60e05ae3cba3"]]},{"id":"587c60e05ae3cba3","type":"join","z":"f6c7807cab872308","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":510,"y":560,"wires":[["4da225a51d28ea0b","0419446fe4174f9d"]]},{"id":"4da225a51d28ea0b","type":"function","z":"f6c7807cab872308","name":"Function","func":"var url = \"http://127.0.0.1:8080\";\n\nmsg.url = url + \"/json.htm?type=command¶m=udevice&idx=486&nvalue=0&svalue=-1;\" + (msg.payload.Gesamtverbrauch) * 1000 + \";\" + msg.payload.date;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":680,"y":560,"wires":[["3bb0a27c5d28dd28"]]},{"id":"7ce36d0df94c73e2","type":"http request","z":"f6c7807cab872308","name":"HTTP","method":"PUT","ret":"txt","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":890,"y":560,"wires":[[]]},{"id":"3bb0a27c5d28dd28","type":"debug","z":"f6c7807cab872308","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"url","targetType":"msg","statusVal":"","statusType":"auto","x":900,"y":500,"wires":[]},{"id":"0419446fe4174f9d","type":"debug","z":"f6c7807cab872308","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":690,"y":500,"wires":[]},{"id":"4219702fa390e412","type":"debug","z":"f6c7807cab872308","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":530,"y":620,"wires":[]},{"id":"f9f13036.e28b58","type":"mqtt-broker","name":"localhost","broker":"127.0.0.1","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]Regards
sailmich
Hello FireWizard,
your code work but the device 486 would not updated. Node red and domoticz are on the same RPi. I tried it also with complete url. I tried it also in firefox with no succeed.
Any idea?
- Spoiler: show
Any idea?
- FireWizard
Hello @sailmich
From the Wiki:
Try it with a positive value. I used 486 just as an example IDX. Replace it with yours.
From the Wiki:
Could this be caused by Counter = -1?To insert data in history log:
IDX = id of your device (This number can be found in the devices tab in the column "IDX")
COUNTER = total cumulative counter energy (Wh, can be set to -1 if unknown or unused, in that case it won't show on dashboard or in logs)
USAGE = energy usage in Watt-hours (Wh)
DATE = date with %Y-%m-%d format (for instance 2019-09-24) to put data in last week/month/year history log, or "%Y-%m-%d %H:%M:%S" format (for instance 2019-10-03 14:00:00) to put data in last days history log
sailmich
I tried it with 1 instead of -1 with same result. It shows Update Device but in fact it doesen't change!
There is a problem when using date but also
why it doesen't work without date from node red but change when using a browser?
- FireWizard
Hello @sailmich
I do not use HTTP very often. Mostly I use MQTT.
However this seems to work properly.
The managed counter, I never used.
You may want to look carefully to the WIKI and perhaps others can tell you more about the managed counter.I tried it with 1 instead of -1 with same result. It shows Update Device but in fact it doesn't change!
What do you exactly send with your browser?There is a problem when using date but also
why it doesn't work without date from node red but change when using a browser?
I would not use the managed counter as it has no history. You will have to manage that yourself with scripts.
Better use the Electric (instant and counter) device.
sailmich
@waltervl according to domoticz api/json in wiki, the syntax which is sending from node red flow is right. I assume this command is changing the data of Energy but at least it should insert data in history log. When I tic the log of the button there is nothing in.
@FireWizard just copy and paste of the string I get from your flow but instead of localhost I use 192.xxx.xxx.xx. The json without date change value with date no changes.
I might change to Electric as waltervl said.
