Python Plugin: Python Plugin Manager
efarmer1
Re: Python Plugin: Python Plugin Manager
Post by efarmer1 »
Is it possible to install the Python Plugin Manager in a Docker Domoticz setup?
any one got a wiki
Gamester17
Post by Gamester17 »
Please consider adding an option to switch between "stable" and "beta" branch releases for the ZigbeeforDomoticz plugin?
https://www.domoticz.com/wiki/ZigbeeForDomoticz
Main reason is that currently only latest "beta6" branch releases contain support for mentioned Texas Instruments CC253x, CC13x2, CC26x2 Zigbee adapters:
https://github.com/zigbeefordomoticz/Do ... tree/beta6 (beta6 branch is currently their "beta")
https://github.com/zigbeefordomoticz/Do ... ee/stable5 (stable5 branch is currently their default stable)
https://github.com/zigbeefordomoticz/Do ... e-channels
About release channels
In order to provide stability and also provide more recent development, Zigbee for Domoticz plugin has the following channels
  • beta6: Current developpement branch integrates zigpy library and allow TI CCxxxx coordinators on top of ZiGate coordinators. Requires Domoticz 2021.1 at minima
  • stable5: Support ALL ZiGate models known today and requires Domoticz 2020.x at minima
  • Not supported
    • beta: deprecated (will be remove end of February 2022)
    • stable: latest version 4.11. - Feb. 2021) deprecated
    • master: latest version 3.0. - Sept. 2018) deprecated
eddieb
Post by eddieb »
Does the Plugin Manager still work ???
I noticed that 1 of my plugins on github is updated a couple of days ago but the plugin manager does not see that update ...
https://github.com/vaneeten/domoticz-wudirect is updated
I did allready created a github issue on this
https://github.com/stas-demydiuk/domoti ... /issues/33
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
eddieb wrote: Saturday 09 April 2022 8:32 Does the Plugin Manager still work ???
WUdirect is updated to v 0.2.6
After you used the plugin manager for update, make sure to restart domoticz and clear cache in your browser. It works OK at my RPi 3b+
Greetings McMelloW
eddieb
Post by eddieb »
I know wudirect is updated, but plugin manager did not see an update ...
I waited 48 hours before I manually updated wudirect
Tjilie
Post by Tjilie »
Does anyone know how to fix this?
2022-09-18 12:00:17.820 Error: PP-Manager: Call to function 'onHeartbeat' failed, exception details:
2022-09-18 12:00:17.834 Error: PP-Manager: Traceback (most recent call last):
2022-09-18 12:00:17.834 Error: PP-Manager: File "/home/pi/domoticz/plugins/PP-MANAGER/plugin.py", line 786, in onHeartbeat
2022-09-18 12:00:17.834 Error: PP-Manager: _plugin.onHeartbeat()
2022-09-18 12:00:17.834 Error: PP-Manager: File "/home/pi/domoticz/plugins/PP-MANAGER/plugin.py", line 454, in onHeartbeat
2022-09-18 12:00:17.834 Error: PP-Manager: self.CheckForUpdatePythonPlugin(self.plugindata[Parameters["Mode2"]][0], self.plugindata[Parameters["Mode2"]][1], str(dir))
2022-09-18 12:00:17.834 Error: PP-Manager: File "/home/pi/domoticz/plugins/PP-MANAGER/plugin.py", line 578, in CheckForUpdatePythonPlugin
2022-09-18 12:00:17.834 Error: PP-Manager: if (self.plugindata[ppKey][2] in self.ExceptionList):
2022-09-18 12:00:17.834 Error: PP-Manager: KeyError: 'examples'
Thanks, Michiel
pgielen
Post by pgielen »
I would really like to learn how to create a new Python plugin for Domoticz. Is there a manual somewhere to help me get going?
Pierre
https://robothuis.nl, RPi4B, RFXCOM XL, Aeotec Z-Stick, ESP Easy, Weatherstation, several switches and sensors, Ikea Trädfri, Philips Hue, Foscam, Reolink, Lyric T6, Ring
Nautilus
Post by Nautilus »
pgielen wrote: Sunday 25 September 2022 21:30 I would really like to learn how to create a new Python plugin for Domoticz. Is there a manual somewhere to help me get going?
Pierre
This should help, I hope: https://www.domoticz.com/wiki/Developin ... hon_plugin
And you can look for reference from the existing plugins: https://www.domoticz.com/wiki/Plugins
SterkeJerke
Post by SterkeJerke »
Tjilie wrote: Sunday 18 September 2022 14:04 Does anyone know how to fix this?
Thanks, Michiel
I have almost the same issue:
2022-11-25 12:32:44.065 Error: Plugin Manager: Call to function 'onHeartbeat' failed, exception details:
2022-11-25 12:32:44.066 Error: Plugin Manager: Traceback (most recent call last):
2022-11-25 12:32:44.066 Error: Plugin Manager: File "/home/henk-jan/domoticz/plugins/PP-MANAGER/plugin.py", line 786, in onHeartbeat
2022-11-25 12:32:44.066 Error: Plugin Manager: _plugin.onHeartbeat()
2022-11-25 12:32:44.066 Error: Plugin Manager: File "/home/henk-jan/domoticz/plugins/PP-MANAGER/plugin.py", line 422, in onHeartbeat
2022-11-25 12:32:44.066 Error: Plugin Manager: pluginKey = Parameters["Mode2"]
2022-11-25 12:32:44.066 Error: Plugin Manager: KeyError: 'Mode2'
2022-11-25 12:32:54.081 Error: Plugin Manager: Call to function 'onHeartbeat' failed, exception details:
2022-11-25 12:32:54.081 Error: Plugin Manager: Traceback (most recent call last):
2022-11-25 12:32:54.081 Error: Plugin Manager: File "/home/henk-jan/domoticz/plugins/PP-MANAGER/plugin.py", line 786, in onHeartbeat
2022-11-25 12:32:54.081 Error: Plugin Manager: _plugin.onHeartbeat()
2022-11-25 12:32:54.081 Error: Plugin Manager: File "/home/henk-jan/domoticz/plugins/PP-MANAGER/plugin.py", line 422, in onHeartbeat
2022-11-25 12:32:54.081 Error: Plugin Manager: pluginKey = Parameters["Mode2"]
2022-11-25 12:32:54.081 Error: Plugin Manager: KeyError: 'Mode2'
Harald777
Domoticz version: Latest
Post by Harald777 »
Thelion wrote: Tuesday 30 November 2021 12:30 Hi,
How do I remove Python Plugin Manager completely?
I removed the folder in the Domoticz Plugin folder, after I removed the hardware, but I still get the Plugins-Manager option in the Custom menu.
Did you solve this issue already.
Love to know how, I have the same issue after removing the not working alternative Plugins Manager.
Greetings,
Harald
Thelion
Domoticz version: 2022.1
Post by Thelion »
Harald777 wrote: Sunday 18 December 2022 10:26
Greetings,
Harald
Yes, I did, but I can't remember how exactly. It's been a while 😬
I think I went the way of fiddling with the files and database, after making a backup of course.
Domoticz version: 2026.3
To remove the custom page remove the plugins manager html from
domoticz/www/templates/
Harald777
Post by Harald777 »
waltervl wrote: Sunday 18 December 2022 18:23 To remove the custom page remove the plugins manager html from
Yes, that did the trick.
Thanks for this info, much appreciated.
Greetings, Harald
YrBo
Domoticz version: 2023.2
Post by YrBo »
I installed the plugin manager from https://www.domoticz.com/wiki/Python_Plugin_Manager
When installing a desired plugin the plugin is not installed.
I dont see a folder created at
pi@DomoticzPi:~/domoticz/plugins $ ls
AwoxSMP PP-MANAGER Zigate examples
I followed al the steps, please help...
Nautilus
Post by Nautilus »
Hopefully not an issue anymore but you have to restart domoticz and the go to create new hardware. Whatever plugin you installed, it should have created a new entry to the available hardware list for you to select.
domovincent
Domoticz version: 2026.2
Python Plugin Manager revival
Post by domovincent »
I've forked the pp-manager and refreshed it a bit, making sure it's python 3.9-3.14 compatible, using uv by default for env isolation, with fallbacks if needed.
Added a nicer registry file to the repo.
Removed dead/broken plugins (at first glance) and added some new ones.
Monthly github scan to detect new plugins.
Upgraded the security check to use python ast (still not 100% of course, but better nonetheless).
https://github.com/adrighem/pp-manager
Make sure you install it as 00-pp-manager, because domoticz loads python plugins alphabetically and this one should load first.
Domoticz (RPI 5), Z-Wave, 433, MQTT, ANWB-energy. Happy user since 2017
