Change icons
Paupole
Change icons
Hello
You can't change icons using the rfy type for somfy or there may be a trick to do it? Thanks for your help
- Domoticz version: 2026.3
Re: Change icons
What is the device type you want to change?
What version of Domoticz are you using?
Icon change is not implemented for all device types but for a lot it is.
Paupole
Re: Change icons
Hello
the lamp on off it would be good if we could change the icon because in all the icons for rfy we cannot change the icon I would like to put a portal icon
the version of domoticz is 2021.1
All the buttons on the rfxcom RFXtrx433 range you can´t change(sans titre rfy)
the other image is not rfy but my portal is rfy
- Sans titre1.jpg (34.78 KiB) Viewed 1712 times
- Sans titre.jpg (32.03 KiB) Viewed 1712 times
Re: Change icons
Strange, but I do not have RF hardware and so related devices so don't know why this is happening.
Perhaps somebody else can test this?
jarmoboy
- Domoticz version: v2022.2
Re: Change icons
is somewhere list of entities which can heve custom icon image?
DOCKERED v14824,NODE-RED,Tasmotized Sonoffs,Tasmoadmin,zigbee2mqtt,EWPE,REST980,WLED
Re: Change icons
Not that I know of, could be somewhere hidden in the code https://github.com/domoticz/domoticz
jarmoboy
Re: Change icons
iam trying to change icon for custom sensor and switch with no succes, so iam trying to find out if it works or not.
iam sending via MQTT :
{"command": "switchlight","idx":366,"switchcmd":"Toggle","customimage":101} // switch toggles but no icon change
{"command": "udevice","idx":367,"svalue":"45","customimage":104} // value 45 read but no icon changed
Re: Change icons
I never tried this option.
jarmoboy
Re: Change icons
Icons cant be changed by MQTT.
It can make f.e. http request.
- FireWizard
Re: Change icons
You cannot change the icons on the fly by MQTT, but by HTTP it is possible.
See: viewtopic.php?p=265212#p265212
Credits to waaren. RIP
