Dashticz TEXT device
gvandick
Domoticz version: 2026.2
Post by gvandick »
Using garbagecalender Dummy text device in Domoticz.
In text device show three text rows with the next three delivery days. (Updating from garbage calendar website lua script)
In dashticz these three lines show up as 1 line. Is there a way to show each day on different row, as in text device Domoticz.
madpatrick
Domoticz version: 2026.1
Re: Dashticz TEXT device
Post by madpatrick »
Can you post your setup.
Normal you can us html commands to Dashticz for layout, like <br>
HansieNL
Post by HansieNL »
@gvandick With Dashticz you can use a special garbage block if you like.
Screenshot 2022-01-06 at 20-02-55 Dashticz.png (2.34 KiB) Viewed 6702 times
See https://dashticz.readthedocs.io/en/mas ... rbage.html
Blah blah blah
gvandick
Post by gvandick »
Dashticz garbagecalendar doesn't support Gemeente Montferland so I use https://github.com/jvanderzande/GarbageCalendar
In Dashticz I added block Domoticz. In custom.css I can style text: allign, height, color .. and so on
I think the way Dash0ticz import data from Domoticz device is the issue
/*afvalcalendar*/
.block_1108 {
height: 100px !important;
font-size: 12px;
color: white;
gvandick
Post by gvandick »
Schermafbeelding 2022-01-07 105201.png (10.03 KiB) Viewed 6684 times
Schermafbeelding 2022-01-07 103729.png (4.67 KiB) Viewed 6684 times
gvandick
Post by gvandick »
madpatrick wrote: Thursday 06 January 2022 10:26 Can you post your setup.
Thanks for the hint
I found the solution
/*afvalcalendar*/
.block_1108 {
height: 120px !important;
font-size: 12px;
content: "\a";
white-space: pre;
color: white;
gvandick
Post by gvandick »
Schermafbeelding 2022-01-09 105947.png (5.9 KiB) Viewed 6663 times
