Plugwise ANNA preset support (beta)
eddieb
Re: Plugwise ANNA preset support (beta)
Ok,
one step further.
it all seems to work now.
OTGW and Plugwise Smile / Anna give me reasonable control over the heating system.
I don't get the point in this preset function.
Changing this on the anna does not change anything in domoticz.
AND I really miss an option to toggle "follow program".
Is ther no such function in the anna api ?
Eddie
one step further.
Eddie
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
Johnnybegood
I have a problem with connecties the plugwise anna smile with the Domoticz.
when i look in the log i see the errors : 2020-02-14 20:33:24.950 Error: AnnaThermostat: Invalid data received!
My domoticz Synology is version V3.9483 and the smile is version 4.0.15
wbmsmart
Plugwise ANNA preset support (beta) Hi there. You can detect when a preset/scene is changed and act on it.
Looking for smart home devices? Welcome to the smart home Devices, where you'll find great prices on a variety of smart products to automate your Smart Home
eddieb
Hi, that Domoticz version seems rather old to me...Johnnybegood wrote: Friday 14 February 2020 20:46 I have a problem with connecties the plugwise anna smile with the Domoticz.
I am running 4.11662 with smile 3.1.11 (with some help from plugwise support last week) and this all works fine...
Eddie
Johnnybegood
How do i install this new version of Domoticz in the DS212J.
The system keeps asking for the node.js_4 which i can not find for the DS212J.
My version on the ANNA is now 4.1.20
Hielkep
- Domoticz version: BETA
not really the right place to ask in this tread, but a short search on google points me to several Dutch websites, who tell me that for the DS212J there is no newer node.js.Johnnybegood wrote: Friday 25 September 2020 15:58 How do i install this new version of Domoticz in the DS212J.
elgringo
- Domoticz version: Left
I am running smile 4.0.20, domoticz build 12467 on an pi.
Temperture control works fine , but changing a preset is not possible. the preset selector switch in domoticz will change when I change it on Anna, but I cannot change the preset via domoticz.
There is a switch if the heater is on. It is possible to add the a switch if it is warm water of CV which triggered the heater?
Edit:
I removed the hardaware in domoticz, readded t and now it works. However it only works when Anna is in a preset, went it is changed manually I cannot set a preset. Is this bug?
Edit:
debouttek
I'm running Domoticz on PI 4, Version 2020.2
Plugwise Anna with firmware 1.8.21
I don't see Presets in my DEVICES list.
I see Proximity_sensor_state in the DEVICES list.
Where can I get the beta version so I can do testing?
Alain
- Domoticz version: 2022.1
If you go to settings in the app and then, in my case, choose Elga settings (heatpump), you can get the running status of the heatpump. The feed and return water temperatures are visible (which are also imported in Domoticz), but also the modulation level of the heatpump and if the connected gas-fired boiler is on or off. Unfortunately, these are not available as devices in Domoticz. Could they be added? I would like to have them visible as devices. Later on I might want to use them to switch other devices.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
wallgarden
Hi All,
I use Domoticz V2021.1 and Plugwise Anna app 4.0.27
These are my findings:
From Domoticz:
When I change the presets, after some time the preset returns to the preset already set in the iPhone app. Nothing changes in the iPhone app.
When I change the temperature it works ok. When I change the temperature or preset via a script, the temperature or preset does not change; not in Domoticz and not in the Iphone app.
When I want to set the temperature or the preset with Blockly, this does not work.
From the iPhone app:
When I change the presets, I see it in Domoticz. Okay so.
When I change the temperature it works for Domoticz and the Iphone app, but in Domoticz the preset goes to "Off", in the Iphone app the existing preset remains.
My questions:
-Are these issues known?
-How do I change the temperature and preset with Blockly?
-How do I check (if statement) the temperature and preset with a script?
-Is it possible to temporarily disable/enable the schedule?
From Domoticz:
My questions:
elgringo
The preset selection does not work anymore. I can change it in domoticz but Anna doe not act on it.
Domoticz version: Build 13872
Anna Version: 4.2.1
Manual setpoint does work, I tried to enable and disable the schedule on Anna but this has no effect.
After I removed the device and hardware and readded it the preset option is not available anymore. Why is that?
Anna Version: 4.2.1
internet
Sadely the presets disapeared with the firmware 4.2.1
Too bad, presets are very easy.
Can I get a downgrade please?
eddieb
indeed the preset function used to work fine but stopped working here a while ago.
Will this be fixed or is this a no longer supported feature and can I remove the preset device ?
mistysnip
- Domoticz version: 2024.7
I swapped to a Anna thermostat and I'm trying to add it to Domoticz, but I can't find which user/password to use?
Currently, both the app and the web versions work fine.
dheuts
The username is: smilemistysnip wrote:Hi,
The password is the ID of your Anna
Raspberry Pi 4 With Domoticz - RFXCom - Tuya Wifi LED lights - Chuango Alarm - Zwave+ - Zigbee2MQTT - Anna Thermostat - Broadlink IR, P1 - Eufy Robo Vacuum - Worx Robo Mower
Koektrommel
Does anyone know if there is a method to switch Anna schedule on/off using Domoticz?
