Hello everyone,
Santa has been generous to me: a (tuya based) Smart Camera. The camera works fine with my smart phone. The quality of the image is not bad at all... But I want more and for that I need some help: I want to connect it ot Domoticz. For an IP camera it is clear how to do that. But this is IoT... and it will most likely need 'extra attention'.
Anyone been able to connect it and willing to share the recipe?
kind regards, --Edgar
connect smart life camera?
- Domoticz version: 2023.2
RaspberryPi running Domoticz 2023.2
PIRs + lightswitches
thermometers + heating control
hygrometers + dehumifiers
TUYA switches
TUYA switches
- Domoticz version: 2024.7
Re: connect smart life camera?
Unless further details about your camera it will be guessing
Check if the snapshot link (http://192.168.x.x:8080) from below is working.
From https://www.gadgetvictims.com/2019/10/t ... -yt08.html
RTSP Streaming
The RTSP port is 6554
MediaProfile_000: 1920x1080@10fps + PCM Audio
rtsp://192.168.x.x:6554/stream_0 (or just rtsp://192.168.x.x:6554)
MediaProfile_001: 640x360@10fps + PCM Audio
rtsp://192.168.x.x:6554/stream_1
Live streaming via HTTP:
http://192.168.x.x:9527/live.htm
http://192.168.x.x:9527/videostream.cgi
Visiting this page from any browser will show a snapshot
RTSP Streaming
Smart Life Camera's are Internet Of Things camera's. This camera is tuya-based, which means:
- it sends its 'stream' to the cloud.
- my phone picks up the 'stream' from the cloud.
Furthermore: TUYA devices have an id, an IP-address and... an encryption key. I know all three but I don't know the algorithms (probably AES) and how to turn camera on and off. This all needs to be done to get the camera working.
It is obvious that the stream into the cloud is encrypted, for security reasons.
The info I need is how to
- turn the camera 'on'
- decrypt the stream
Tuya devices are very affordable and getting more common these days. As an example (I do NOT have shares and NOT promoting anything) see: https://www.aliexpress.com/item/1005002 ... mainSearch
I have managed to get switches working by applying Domoticz -> MQTT -> TinyTuya (Python) and v.v.
Next is the IP camera...
Hopefully this is enough background.
TUYA switches
TUYA switches
you did not send a link and/or type number for your type of camera.
Most IP cameras have an URL where they can be accessed directly. going to the cloud is a very bad idea (my opinion) especially for a camera.
so searching for your brand and type of camera will also give you possibilities to change the firmware and get rid of that cloud access.
https://www.kruidvat.nl/kruidvat-smart- ... /p/5314114
This is the camera I am talking about. It is called a Smart Life camera, which you operate through the smart life app... Since all works through the app (which is handy if you are not into programming, no offence!) there is no URL involved.
I agree because
- it makes it slow (upstream and downstream)
- Making a node in the middle comes close to 'the middle man' that can manipulate both up- and downstream
I don't agree because
- It allows you to have (full) control of all your devices wherever you are
so far so good...
I agree and I don't.going to the cloud is a very bad idea
I agree because
so far so good...
TUYA switches
TUYA switches
I do not think it is possible to get it working in Domoticz as it is not possible to get a proper url to get a stream or snapshot from the camera.
If you really want to get it to work with Domoticz (and probably not working anymore in the app) you have to find a hack solution like https://github.com/guino/Merkury1080P
It is just an IP camera. It does not stream to the "cloud" and back to your device.edgarhildering wrote: ↑Monday 27 December 2021 17:48 Smart Life Camera's are Internet Of Things camera's. This camera is tuya-based, which means:
It connects to your internal network and to the app on your phone.
For outside connection it uses some sort of DDNS mostly on port 80.
You could use WireShark to find out more of how the connection is made.
Best to search the Internet if somebody with the right skills already found the way to connect directly.
