Insert delay option in script?
njlammerts
Domoticz version: 2022.2
Post by njlammerts »
I have a bathroom with a door and a window. Both have a open/close detection switch.
I made a Blockly script with a dummy switch to heat (CV5=Zigbee Radiator Valve) the bathroom when door and window are closed. When one of them is open, the "Badkamer" button switches of after 0.5 sec. After enabling, the dummy switch lights up and goes off again if the closed door/room condition is not closed.
Schermafbeelding 2021-12-23 om 10.37.17.png (100.62 KiB) Viewed 2928 times
If I walk in/out the bathroom the heating is switched off, because of the switch rule.
Is there a way to build in a kind of delay that keeps this scene enabled if the open/close door is < 10sec, so I can walk in and out again to fetch something without the script to stop. If the door is left open for >10sec it means it is open permanently and script should turn off
madpatrick
Domoticz version: 2025.2
Re: Insert delay option in script?
Post by madpatrick »
You can check this dzventz script. viewtopic.php?p=257729#p257729
I think this answers your question
For me it is working perfectly and you can customize it easily.
njlammerts
Thanks for the reply, but I I would like it implemented in Blockly
My Programm skills are not great and Blockly is for me an easy way to get things working
madpatrick
Blocky is user friendly, but limited in functionality
Dzvents is very powerful and once you tried it will get understandable.
Also there is some support on the forum to help
Post your complete Blocky and i’ll check if i can help
BennY
Post by BennY »
With Blockly you have everything you need for most House Automation, except calculation...
I think you are looking for this?
madpatrick
You could try this as an example
Check the variable (local) names if this matches your setting
local scriptVersion = 'Versie 1.00'
local scriptVar     = '-=# Badkamer #=-'
local ContactDoor   = 'Badkamer Door'
local ContactWindow = 'Badkamer Windows'
local Thermostat    = 'Badkamer'
return
    active   = true,
    on       = {
                devices         = {ContactDoor,ContactWindow},
    logging = {
                level = domoticz.LOG_ERROR, -- change to LOG_ERROR when all OK
                marker = scriptVar,
    execute = function(dz, item)
        local delay = 10
        local temp = dz.devices(Thermostat)
        local door = dz.devices(ContactDoor)
        local windows = dz.devices(ContactWindow)
        if temp.state == "On" and (door.state =="On" or window.state =="On") then
            if window.lastUpdate.secondsAgo or door.lastUpdate.secondsAgo >= delay then
                dz.log('Last update Sensors : ' .. door.lastUpdate.secondsAgo .. ' and ' .. window.lastUpdate.secondsAgo, dz.LOG_FORCE)
                dz.log('Badkamer temperaure set to 5°C ', dz.LOG_FORCE)
                temp.setpoint(5)
                dz.log('Nothing to do' , dz.LOG_FORCE)
kuifje
Domoticz version: latest
Post by kuifje »
njlammerts,
You can also use an user variable.
When the door and the window are closed then set the user variable to 1.
When one of them is open set user variable to 0.
When zero then badkamer is off.
Kuifje
njlammerts
BennY wrote: Saturday 25 December 2021 21:36 With Blockly you have everything you need for most House Automation, except calculation...
Im am told that "Nested Commands". can not be used?
Schermafbeelding 2022-01-28 om 17.04.11.png (257.3 KiB) Viewed 2631 times
jvdz
Domoticz version: 4.107
Post by jvdz »
njlammerts wrote: Friday 28 January 2022 17:05 Im am told that "Nested Commands". can not be used?
Guess you mean Nested IF commands as the shown blockly doesn't have any nested commands and only a one level If- ELSEIF. ;)
The AND OR logic could be a little bit tricky though.
njlammerts
I mean
....................AF-badkamer
........and
...............or. AF badkamer door
....................AF Badkamer window
I am repeating the command for AF badkamer door and AF badkamer windows
njlammerts
Sorry for the late reply, but the suggestions displayed above is not what I mean/want.
I have a window and door switch in the bathroom. When they both are open, I want the radiator valve in the bathroom to be closed, even if the temperature sensor "says" heat the bathroom. Only when window and door are closed and temperature sensor is below the set value, I want the radiator valve to open, so the bathroom can be heated with a script.
In my script the bathroom is heated when both window and door are closed. But when the bathroom door is opened, the script is set to "close valve" , even when you only walk in and out within 10-20 sec. I would like a delay in the door sensor, that leaves the script "running" when the door is opened for less the 10-20 sec (so the valve/script won't close). When the door is opened longer then I assume the door is "normal" open and should the valve close/script end
BennY
Post by BennY »
njlammerts wrote: Saturday 05 February 2022 11:47 In my script the bathroom is heated when both window and door are closed. But when the bathroom door is opened, the script is set to "close valve" , even when you only walk in and out within 10-20 sec. I would like a delay in the door sensor, that leaves the script "running" when the door is opened for less the 10-20 sec (so the valve/script won't close). When the door is opened longer then I assume the door is "normal" open and should the valve close/script end
That is what the blockly do, i Made for you on 25.12. You need a Dummy Switch for your delayed door. Then you use the Dummy instead your door Switch.
Benny
