Dashticz - Module - Garbage collector Topic is solved
peter68
Re: Dashticz - Module - Garbage collector
Post by peter68 »
thanks for the quick response. will switch to beta
sammyke007
Domoticz version: 2022.1
Post by sammyke007 »
Is it me or did recycleapp stopped working once again?
Gianni
Post by Gianni »
yep stopped again :-(
jvdz
Domoticz version: 4.107
Post by jvdz »
sammyke007 wrote: Tuesday 14 December 2021 9:50 Is it me or did recycleapp stopped working once again?
Just tested my set of scripts and that still seems to work with your details?:
Schedule: vri 17 dec: restafval, glas ; vri 24 dec: pmd, gft ; woe 29 dec: papier-karton
Jos
sammyke007
jvdz wrote: Tuesday 14 December 2021 15:27
Jos
The Domoticz script is working fine, it's the Dashticz part/code that stopped working.
I get the following errors in console:
Failed to load resource: the server responded with a status of 500 (Internal Server Error)
and
Error loading garbage:  Object
(anonymous) @ js/components/garbage.js:952
Running latest beta
Lokonli
Post by Lokonli »
sammyke007 wrote: Tuesday 14 December 2021 15:51
Jos
and
Running latest beta
Fixed in latest beta.
You can update with:
git pull
sammyke007
Faster than fast! Tnx!!
networkerict
Post by networkerict »
Hi lokonli,
Since a couple of days/weeks the garbage module for Purmerend isn't working anymore.
It's https://afvalkalender.purmerend.nl/overzicht for instance for the combination 1445GJ, number 11.
I was using 3.8.3 and have upgraded to 3.9 master (but it doesn't work there as well).
Lokonli
Post by Lokonli »
I've checked my 'allgarbage' test config, and indeed Purmerend, and also Blink, De Afval App and Suez are not working at the moment.
The other 35 garbage providers are ok.
I'll try to fix this in the coming days.
networkerict
Lokonli wrote: Friday 04 March 2022 16:13 I've checked my 'allgarbage' test config, and indeed Purmerend, and also Blink, De Afval App and Suez are not working at the moment.
Great! Thanks for your continuous support and optimizations in Dashticz!
Lokonli
Post by Lokonli »
networkerict wrote: Friday 04 March 2022 14:31 Hi lokonli,
NilsNijenhuis
Post by NilsNijenhuis »
Does anyone have the same problem that the garbage info of circulus berkel doesn't give results back?
couple of days ago it still worked and i haven't changed anything?!
circulus berkel.png (29.84 KiB) Viewed 6309 times
Lokonli
Post by Lokonli »
NilsNijenhuis wrote:Does anyone have the same problem that the garbage info of circulus berkel doesn't give results back?
Circulus Berkel indeed doesn't work at the moment. I'll try to fix it.
Verstuurd vanaf mijn SM-A526B met Tapatalk
NilsNijenhuis
Oké thanks
marmachine
Domoticz version: 3.4834
Post by marmachine »
NilsNijenhuis wrote: Saturday 02 April 2022 14:58 Does anyone have the same problem that the garbage info of circulus berkel doesn't give results back?
Same issue here, i was just looking into it and came accross your post and see that Lokonli is looking into it as well... :ugeek: great and thanks in advance!
Nice "Afval" graphic you have by the way!
Lokonli
Post by Lokonli »
Fixed in latest Dashticz beta.
Can you test?
NilsNijenhuis
sorry for the late response, will test it as soon as possible and will let it know :)
NilsNijenhuis
It works, thanks @Lokonli
NilsNijenhuis
marmachine wrote: Tuesday 12 April 2022 23:39
do you mean the afval icon? if you want to use it, see the attachment below
Snowdude
Post by Snowdude »
Can someone give a a push in the right direction. I'm not getting the right date format.
My calendar items show up nicely in the Su 15.05 format, but the garbage is in 5/10/2020
These settings are in my config file:
config["language"] = "nl_NL";
config["timeformat"] = "DD-MM-YY HH:mm";
config["calendarformat"] = "dd DD.MM HH:mm";
config["calendarlanguage"] = "nl_NL";
I found it. I was updating my config.js file in the wrong place.
