MQTT to write in Humidity device
Allras82
Post by Allras82 »
Hi all
Im having problem in getting a value som node-red into a domoticz humidity dummy device.
I can make it work with all other types of device types, but not the humidity.
Any one that have some experience here.
Is there any specific restrictions for the Humidity device.
Right now i'm using a procenter device, but i dont like the icon for that purpose.
Im at latest stabile at a RPI3
Node-red at the same machine trough MQTT
br
AR
Domoticz version: 2026.3
Re: MQTT to write in Humidity device
Check this page, someone checked it all out: https://piandmore.wordpress.com/2019/02 ... -domoticz/
FireWizard
Post by FireWizard »
Can you publish the MQTT command you try to send to the virtual humidity sensor in Domoticz?
Allras82
Post by Allras82 »
Im sending this:
{"command":"udevice","idx":30057,"svalue":0,"nvalue":40}
to topic domoticz/in
and domoticz log: 2021-12-07 19:52:50.495 Error: MQTT: MQTT: Invalid data received!
FireWizard
Hi, @Allras82,
For all commands the svalue should be a string, while the nvalue should be a number.
Change "svalue":0 into "svalue":"0".
Allras82
Post by Allras82 »
Ahhh...
Thanks a lot. That was it😀
