Hi all
Im having problem in getting a value som node-red into a domoticz humidity dummy device.
I can make it work with all other types of device types, but not the humidity.
Any one that have some experience here.
Is there any specific restrictions for the Humidity device.
Right now i'm using a procenter device, but i dont like the icon for that purpose.
Im at latest stabile at a RPI3
Node-red at the same machine trough MQTT
br
AR
MQTT to write in Humidity device
- Domoticz version: 2024.7
Re: MQTT to write in Humidity device
Check this page, someone checked it all out: https://piandmore.wordpress.com/2019/02 ... -domoticz/
- FireWizard
Can you publish the MQTT command you try to send to the virtual humidity sensor in Domoticz?
Im sending this:
{"command":"udevice","idx":30057,"svalue":0,"nvalue":40}
to topic domoticz/in
and domoticz log: 2021-12-07 19:52:50.495 Error: MQTT: MQTT: Invalid data received!
Im sending this:
- FireWizard
Hi, @Allras82,
For all commands the svalue should be a string, while the nvalue should be a number.
Change "svalue":0 into "svalue":"0".
Ahhh...
Thanks a lot. That was it
