After two years I finaly upgraded from 4.10717 to 2021.1. Since then, I notice the the graphs of my energy meters are different. Before, power and energy were on two separate axis. Power was displayed as a yellow line, total energy usage per hour was displayed as a blue bar. This makes it very good visible what the differences were. Since 2021.1, power and energy are on the same axis, thereby reducing the power usage to a flat line, making the graph useless. How can this be restored to 2 axis?
update: it seems the energy usage per hour (Wh) is not calculated correctly anymore. It calculates 16000 Wh when the device is only using 151 watts.
Energy/Power graph both on the same scale?
microkid
- Domoticz version: 2024.7
- powergraph.png (129.53 KiB) Viewed 944 times
- Domoticz version: 2026.3
Re: Energy/Power graph both on the same scale?
I do not have this on 2021.1 I see different scales. Please clear your browser cache to get to get the proper graphs. https://www.domoticz.com/wiki/Browser_Cache
microkid
Tried that, in 2 browsers (Firefox and Safari). No change. Initially, when you open the graph, the yellow line is correct for a split second, then goes down to a flat line. The behavior is the same in both browsers. Even tried incognito mode, same result.waltervl wrote: Saturday 07 August 2021 15:29 I do not have this on 2021.1 I see different scales. Please clear your browser cache to get to get the proper graphs. https://www.domoticz.com/wiki/Browser_Cache
I was wrong, I also see one scale (but luckaly both in visible range)
