zwavejs2mqtt
EddyG
Re: zwavejs2mqtt
Post by EddyG »
But if you do not use that device, how do you control the Spirit?
heggink
Domoticz version: 12451
Re: zwavejs2mqtt
Post by heggink »
I only use the thermostat device.and set the temperature. It's permanently in heat mode. If I don't want heat, I switch it to 12C...
P1 meter & solar panel
Westcott
Re: zwavejs2mqtt
Post by Westcott »
Hi Heggink, same here.
I find the latest Spiritz to be a very reliable device when used this way.
EddyG
Re: zwavejs2mqtt
Post by EddyG »
I now have complete control of the device via dzVents and the mode and setpoint devices. :)
hestia
Domoticz version: 2022.1
Re: zwavejs2mqtt
Post by hestia »
As the mqtt autodiscovery is ongoing, I think that a point is still not working for my devices: Animation for RGBW Controller (Fibaro).
To get these animation you could set 6,7,8,9 or 10 in the 72 configuration field [95-112-0-72]
Screenshot 2021-11-08 204442.png (22.42 KiB) Viewed 3089 times
Screenshot 2021-11-08 204517.png (36.23 KiB) Viewed 3089 times
It's possible to do it with Home Assistant
action:
  service: zwave.set_config_parameter
  data_template: {
    "node_id": 5,
    "parameter": 72,
    "value": 6,
    "size": 1
I've tried do to it with mqtt from dz, but I could not figured out how to do it :-(
Do you have any example of mqtt command so I could try again?
jvdz
Domoticz version: 4.107
Re: zwavejs2mqtt
Post by jvdz »
Just look at what MQTT Topic & Payload HA sends when activating that option and do the same in your script. :)
hestia
Re: zwavejs2mqtt
Post by hestia »
I don't have HA :-(
just read this on a HA forum
I don't know if it is easy to install HA just for this.
Perhaps sbdy already have HA and could have this look or any look of a configuration parameter?
hestia
Re: zwavejs2mqtt
Post by hestia »
I've installed HA...
In fact the communication between HA and zwavejs2mqtt is ws, no mqtt
The log in HA for the call is
[Node 095] [REQ] [SendData]
│ transmit options: 0x25
│ callback id:      228
└─[ConfigurationCCSet]
                                      parameter #:      72
                                      reset to default: false
                                      value size:       1
                                      value format:     SignedInteger
                                      value:            6
I don't know if it's enough to make the call from dz to zwavejs
jvdz
Re: zwavejs2mqtt
Post by jvdz »
hestia wrote: Thursday 11 November 2021 22:38 I've installed HA...
That is their preferred communication method, but you can also use the MQTT AutoDiscover in HA!.
I use that to be able to compare the Domoticz behavior with HA when communicating to the different gateways.
hestia
Re: zwavejs2mqtt
Post by hestia »
hestia wrote: Monday 08 November 2021 20:52 As the mqtt autodiscovery is ongoing, I think that a point is still not working for my devices: Animation for RGBW Controller (Fibaro).
I've found how to do it with the help of the zwavejs2mqtt git discussions
Here is a script with the mqtt message
local LED_SELECTOR_ID = 887 -- dummy selector to manage the LED with predefined choices:
local LED_ANIMATION_AURORA = 10
local LED_ANIMATION_RAINBOW = 20
local LED_ANIMATION_STORM = 30
local LED_ANIMATION_FIREPLACE = 40
local LED_ANIMATION_LAPD = 50
local LED_ANIMATION_PAUSE = 60
-- zwavejs2mqtt
local mqtt_prefix = "zwave"
local NODE_nodeId = 95
local NODE_commandClass = 112
local NODE_endpoint = 0
local NODE_property = 72
     logging =   {   level   =
                    --domoticz.LOG_ERROR, --select one to override system log level normal = LOG_ERROR
                    domoticz.LOG_DEBUG,
                    --domoticz.LOG_INFO,
                    --domoticz.LOG_FORCE
    	devices = {LED_SELECTOR_ID},
    execute = function(dz, device)
    _G.logMarker =  dz.moduleLabel -- set logmarker to scriptname
    --local LOG_LEVEL = dz.LOG_INFO  -- LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE  - normal = LOG_INFO
    local LOG_LEVEL = dz.LOG_DEBUG
    dz.log("LED_SELECTOR " .. device.state .. " " .. tostring(device.level) .. " nValue: " .. device.nValue, LOG_LEVEL)
-----< BEG FUNCTIONS > ----------------------------------------------------------------------------------------
    local function logWrite(str, level)  -- Support function for shorthand debug log statements
        if level == nil then
            level = LOG_LEVEL
        dz.log(tostring(str), level)
	local function setRGBWAnimation(rgbAnimation)
        local codeAnimation
		if rgbAnimation == LED_ANIMATION_PAUSE then
    		codeAnimation = 1
    	elseif rgbAnimation == LED_ANIMATION_FIREPLACE then
			codeAnimation = 6
		elseif rgbAnimation == LED_ANIMATION_STORM then
			codeAnimation = 7
		elseif rgbAnimation == LED_ANIMATION_RAINBOW then
			codeAnimation = 8
		elseif rgbAnimation == LED_ANIMATION_AURORA then
			codeAnimation = 9
		elseif rgbAnimation == LED_ANIMATION_LAPD then
			codeAnimation = 10
        local NODE_value = codeAnimation
        local suffix = "set"
        --mqttTopic = "zwave/95/112/0/72/set"
        local mqttTopic = mqtt_prefix .. '/' .. NODE_nodeId .. '/' .. NODE_commandClass .. '/' .. NODE_endpoint .. '/' .. NODE_property .. '/' .. suffix
        local mosquitto_cmd = 'mosquitto_pub' ..' -t '.. mqttTopic .. ' -m '.. NODE_value
        os.execute (mosquitto_cmd)
        logWrite("mosquitto_cmd=" .. mosquitto_cmd)
-----< END FUNCTIONS > ----------------------------------------------------------------------------------------
		setRGBWAnimation(device.level)
mosquitto_pub -t zwave/95/112/0/72/set -m 8
EddyG
Re: zwavejs2mqtt
Post by EddyG »
Sample script for the EUR_SPIRITZ Wall Radiator Thermostat.
Just to show how settings can be changed that don't have a Domoticz device like the lower setpoint.
I included the modes, although 3 of them can be set by a selector device. I enhanced zwabejs2mqtt with the 'Full' mode in the selector switch.
The values in the ZSetHigh and ZSetLow are the setpoint values.
--local ZModeOff = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/64/0/mode/set -m "{\\"value\\": 0}"'
--local ZModeEco = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/64/0/mode/set -m "{\\"value\\": 1}"'
--local ZModeHeat = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/64/0/mode/set -m "{\\"value\\": 11}"'
--local ZModeFull = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/64/0/mode/set -m "{\\"value\\": 15}"'
local ZSetHigh = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/67/0/setpoint/1/set -m "{\\"value\\": 21}"'
local ZSetLow = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/67/0/setpoint/11/set -m "{\\"value\\": 17}"'
        active = true,
--      active = false,
                timer = { 'at 08:31',
                              'at 18:01' },
        logging = {
                level = domoticz.LOG_INFO,
--              level = domoticz.LOG_DEBUG,
                marker = 'ZT'
        execute = function(dz, item)
                                dz.executeShellCommand({ command = ZSetHigh })
                                dz.executeShellCommand({ command = ZSetLow })
                                if item.trigger == 'at 08:31' then
                                        dz.devices('Zolder Thermostaat Mode').switchSelector('Heat')
                                elseif item.trigger == 'at 18:01' then
                                        dz.devices('Zolder Thermostaat Mode').switchSelector('Eco')
ChriWo
Re: zwavejs2mqtt
Post by ChriWo »
Hi EddyG,
Thank you for the sample. But I have one problem I get this Error:
2021-11-22 19:25:00.292 Error: dzVents: Error: (3.1.8) ZT: levelname Eco does not exist
But I have also have not figured out how to get to the 'Full' mode in the selector switch and the ZSetLow.
Can you please explain.
Thank you
EddyG
Re: zwavejs2mqtt
Post by EddyG »
In the 'original' Auto-Discovery selector switch that level is called 'Energy Heat' I changed the levelname to Eco. It fits more what it does.
The Full mode is NOT implemented in the selector switch, if you need it in the script you can use the mosquitto_pub command.
ZSetLow is just a variable which includes a command to set the "Low" setpoint as in the script, because that is not included in the Auto-Discovery.
My script just 'resets' both setpoint twice a day to my default settings, just incase I changed those manually and forget to set them back.
B.t.w. the 'Full mode' is only active for 15 minutes after that the Thermostat sets it self back to the mode "Heat'
hestia
Re: zwavejs2mqtt
Post by hestia »
I've moved to mqtt auto discovery + zwavejs2mqtt last week.
So far it has been working mostly fine: better stability on some motion sensors than with OWZ: I was loosing them very often with OZW.
Some minors regressions: no kWh on some devices (I need to check the concerned models mostly Qubino), and the LED Controller
Sometimes the "connection" was lost between zwvajs2mqtt and domoticz: I don't know why and what happened exactly :-(
What is good, it's a better understanding of the network, so I could make some changes to get it better.
For the RGBW Controller, the setColor method in DzVents no longer works, so I extend the script above https://domoticz.com/forum/viewtopic.ph ... 37#p282437 like this
local LED_SELECTORS_ID = {887, 1114}    -- dummy selector to manage the LED with predefined choices:
local NODES_nodeId =    {               -- id in dz and relative zwave nodes
                            [887] = 95,
                            [1114] = 119
local RGBW_ORDER = -- animation and static color
    {   [0] =   {0, 0, 0, 0, 0, 0, 4},
        [10] =  {9},    -- Aurora
        [20] =  {8},    -- Rainbow
        [30] =  {7},    -- Storm
        [40] =  {6},    -- Fireplace
        [50] =  {10},   -- LAPD
        [60] =  {1},    -- Pause
		[70] =  {255, 255, 255, 255},   -- warm white !!!!
	    [80] =  {255, 165, 0, 50},      -- candle / bougie
        [90] =  {238, 130, 238, 0},	    -- violet
        [100] = {130, 65, 245, 0},      -- indigo
        [110] = {0, 0, 255, 0},         -- bleu
        [120] = {0, 128, 0, 0},         -- vert
        [130] = {255, 255, 0, 0},       -- jaune
        [140] = {255, 70, 0, 0},        -- orange
        [150] = {255, 0, 0, 0},         -- rouge
        [160] = {227, 137, 7, 251}      -- candle white
	-- static color
    -- setColor(r, g, b, ww):
   	-- r: Red level: 0-255
   	-- g: Green level: 0-255
   	-- b: Blue level: 0-255
   	-- ww: Warm white level: 0-255
-- zwavejs2mqtt
local NODE_nodeId
     logging =   {   level   =
                    domoticz.LOG_DEBUG,
    	devices = LED_SELECTORS_ID,
            level = LOG_LEVEL
	local function setZwavejs(p_NODE_commandClass, p_NODE_endpoint, p_NODE_property, p_NODE_value)
        local mqttTopic = mqtt_prefix .. '/' .. NODE_nodeId .. '/' .. p_NODE_commandClass .. '/' .. p_NODE_endpoint .. '/' .. p_NODE_property .. '/' .. suffix
        local mosquitto_cmd = 'mosquitto_pub' ..' -t '.. mqttTopic .. ' -m '.. p_NODE_value
	local function RGBWAnimation(p_rgbAnimation)
	    dz.log("RGBWAnimation " .. p_rgbAnimation, LOG_LEVEL)
        local NODE_value = p_rgbAnimation
        setZwavejs(NODE_commandClass, NODE_endpoint, NODE_property, NODE_value)
	local function RGBWColor (p_red, p_green, p_blue, p_warmWhite)
	    dz.log("RGBWColor " .. p_red .. '  '.. p_green .. '  '.. p_blue .. ' ' .. p_warmWhite, LOG_LEVEL)
        local NODE_commandClass = 51
        local NODE_property = 'targetColor'
        local NODE_value = '{\\"value\\":{\\"warmWhite\\":' .. p_warmWhite .. ',\\"red\\":' .. p_red .. ',\\"green\\":' .. p_green .. ',\\"blue\\":' .. p_blue .. '}}'
	logWrite(device.id .. ' ' .. device.level)
    local devLevel = device.level
    if  device.level == 0 or device.nValue == 0 then
        device.switchSelector(0).silent()
	    device.switchOff().silent()
	    devLevel = 0
	if  devLevel ~= 170 then
	    NODE_nodeId = NODES_nodeId[device.id]
	    logWrite('NODE_nodeId: ' .. NODE_nodeId)
     	local paramArray = RGBW_ORDER[devLevel]
    	if paramArray[1] == nil then
    	    logWrite('Level: ' .. devLevel .. ' bad parameters', dz.LOG_ERROR)
    	elseif paramArray[2] == nil then -- animation
    	    RGBWAnimation(paramArray[1])
    	    RGBWColor (paramArray[1], paramArray[2], paramArray[3], paramArray[4])
hestia
Re: zwavejs2mqtt
Post by hestia »
I've just had a discussion on the zwave-js / zwavejs2mqtt git and as a reply:
BTW as explained in docs I don't have any plan right now to keep mqtt discovery updated
https://zwave-js.github.io/zwavejs2mqtt ... stant-mqtt
The preferred method of integrating your Z-Wave components with Home Assistant is through the official Home Assistant Z-Wave JS integration, this because MQTT Discovery is limited compared to a native integration and Home Assistant updates frequently break it. Based on this I would NOT RECCOMMEND using MQTT Discovery, I don't plan to keep it maintained in the future.
so, I'm a bit surprised that the solution described here is presented as a future for zwave in domoticz, perhaps I've missed something, or a plan is ongoing...
heggink
Re: zwavejs2mqtt
Post by heggink »
hestia wrote: Thursday 09 December 2021 9:36 Hi,
Define future...
The thing is that OZW is pretty much a dead end street. Zwavejs is a much more workable and future proof solution. zwavejs2mqtt is based on zwavejs ('just' adds mqtt). The question then is "what's the most workable integration for domoticz". Zigbee2mqtt and zwavejs2mqtt both (still) support mqtt autodiscovery and only zwavejs2mqtt has announced that the developer has no plans to keep it maintained in the future but that does not mean that it's desupported. Zigbee2mqtt will continue to support mqtt so no problems there.
So then what? 2 options AFAICT:
  • either "someone" implements native zwavejs integration into domoticz
  • or "someone" takes over the mqtt side of zwavejs to keep it supported
Ultimately, this being open source, it all comes down to someone taking ownership for this hence my remark "define future". As long as this is open source, we all are responsible for keeping things maintained. Either that or we all switch to Home Assistant
EddyG
Re: zwavejs2mqtt
Post by EddyG »
What also concerns me is "this because MQTT Discovery is limited compared to a native integration"
I wonder if someone has experience with https://github.com/zwave-js/node-red-contrib-zwave-js
jvdz
Re: zwavejs2mqtt
Post by jvdz »
EddyG wrote: Thursday 09 December 2021 18:39 What also concerns me is "this because MQTT Discovery is limited compared to a native integration"
This is in comparison with the HomeAssistat addon integration so is all about HomeAssistant I think.
EddyG wrote: Thursday 09 December 2021 18:39 I wonder if someone has experience with https://github.com/zwave-js/node-red-contrib-zwave-js
Just wondering how having it in Nodered would help with the integration into Domoticz?
EddyG
Re: zwavejs2mqtt
Post by EddyG »
jvdz wrote: Thursday 09 December 2021 19:09 Just wondering how having it in Nodered would help with the integration into Domoticz?
The backend is Zwave-js API and towards Domoticz I have full control.
I could leave out devices that I don't need and include devices that I need.
In the current solution with Auto-Discovery I am missing 1 of the setpoints in my thermostats, and the mode selector switch does not have all the settings.
I have a solution in my dzVents script to change the missing setpoint, and found a solution for the missing mode.
If that missing setpoint and missing mode is accessible via Zwave-js API and nodered then that could be a route to go.
And I just asked if someone has experience with it, just to get more info.
hestia
Re: zwavejs2mqtt
Post by hestia »
heggink wrote: Thursday 09 December 2021 17:54 Define future...
If you're aware of this, I'm half reassured!
Anyway I still have some simple switches that don't trigger dzvents and don't report their status (on/off)
So what is working well zwavejs doesn't automatically work well in dz
