zwavejs2mqtt
Re: zwavejs2mqtt
But if you do not use that device, how do you control the Spirit?
- heggink
- Domoticz version: 12451
Re: zwavejs2mqtt
I only use the thermostat device.and set the temperature. It's permanently in heat mode. If I don't want heat, I switch it to 12C...
Sent from my SM-G980F using Tapatalk
P1 meter & solar panel
- Westcott
Re: zwavejs2mqtt
Hi Heggink, same here.
I find the latest Spiritz to be a very reliable device when used this way.
Re: zwavejs2mqtt
I now have complete control of the device via dzVents and the mode and setpoint devices.
hestia
- Domoticz version: 2022.1
Re: zwavejs2mqtt
As the mqtt autodiscovery is ongoing, I think that a point is still not working for my devices: Animation for RGBW Controller (Fibaro).
To get these animation you could set 6,7,8,9 or 10 in the 72 configuration field [95-112-0-72] .
It's possible to do it with Home Assistant
I've tried do to it with mqtt from dz, but I could not figured out how to do it
Do you have any example of mqtt command so I could try again?
action:
service: zwave.set_config_parameter
data_template: {
"node_id": 5,
"parameter": 72,
"value": 6,
"size": 1
}Do you have any example of mqtt command so I could try again?
- jvdz
- Domoticz version: 4.107
Re: zwavejs2mqtt
Just look at what MQTT Topic & Payload HA sends when activating that option and do the same in your script.
hestia
Re: zwavejs2mqtt
I don't have HA
just read this on a HA forum
I don't know if it is easy to install HA just for this.
Perhaps sbdy already have HA and could have this look or any look of a configuration parameter?
hestia
Re: zwavejs2mqtt
I've installed HA...
In fact the communication between HA and zwavejs2mqtt is ws, no mqtt
The log in HA for the call is
I don't know if it's enough to make the call from dz to zwavejs
[Node 095] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 228
└─[ConfigurationCCSet]
parameter #: 72
reset to default: false
value size: 1
value format: SignedInteger
value: 6- jvdz
Re: zwavejs2mqtt
That is their preferred communication method, but you can also use the MQTT AutoDiscover in HA!.hestia wrote: Thursday 11 November 2021 22:38 I've installed HA...
I use that to be able to compare the Domoticz behavior with HA when communicating to the different gateways.
hestia
Re: zwavejs2mqtt
I've found how to do it with the help of the zwavejs2mqtt git discussionshestia wrote: Monday 08 November 2021 20:52 As the mqtt autodiscovery is ongoing, I think that a point is still not working for my devices: Animation for RGBW Controller (Fibaro).
Here is a script with the mqtt message
local LED_SELECTOR_ID = 887 -- dummy selector to manage the LED with predefined choices:
local LED_ANIMATION_AURORA = 10
local LED_ANIMATION_RAINBOW = 20
local LED_ANIMATION_STORM = 30
local LED_ANIMATION_FIREPLACE = 40
local LED_ANIMATION_LAPD = 50
local LED_ANIMATION_PAUSE = 60
-- zwavejs2mqtt
local mqtt_prefix = "zwave"
local NODE_nodeId = 95
local NODE_commandClass = 112
local NODE_endpoint = 0
local NODE_property = 72
logging = { level =
--domoticz.LOG_ERROR, --select one to override system log level normal = LOG_ERROR
domoticz.LOG_DEBUG,
--domoticz.LOG_INFO,
--domoticz.LOG_FORCE
devices = {LED_SELECTOR_ID},
execute = function(dz, device)
_G.logMarker = dz.moduleLabel -- set logmarker to scriptname
--local LOG_LEVEL = dz.LOG_INFO -- LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE - normal = LOG_INFO
local LOG_LEVEL = dz.LOG_DEBUG
dz.log("LED_SELECTOR " .. device.state .. " " .. tostring(device.level) .. " nValue: " .. device.nValue, LOG_LEVEL)
-----< BEG FUNCTIONS > ----------------------------------------------------------------------------------------
local function logWrite(str, level) -- Support function for shorthand debug log statements
if level == nil then
level = LOG_LEVEL
dz.log(tostring(str), level)
local function setRGBWAnimation(rgbAnimation)
local codeAnimation
if rgbAnimation == LED_ANIMATION_PAUSE then
codeAnimation = 1
elseif rgbAnimation == LED_ANIMATION_FIREPLACE then
codeAnimation = 6
elseif rgbAnimation == LED_ANIMATION_STORM then
codeAnimation = 7
elseif rgbAnimation == LED_ANIMATION_RAINBOW then
codeAnimation = 8
elseif rgbAnimation == LED_ANIMATION_AURORA then
codeAnimation = 9
elseif rgbAnimation == LED_ANIMATION_LAPD then
codeAnimation = 10
local NODE_value = codeAnimation
local suffix = "set"
--mqttTopic = "zwave/95/112/0/72/set"
local mqttTopic = mqtt_prefix .. '/' .. NODE_nodeId .. '/' .. NODE_commandClass .. '/' .. NODE_endpoint .. '/' .. NODE_property .. '/' .. suffix
local mosquitto_cmd = 'mosquitto_pub' ..' -t '.. mqttTopic .. ' -m '.. NODE_value
os.execute (mosquitto_cmd)
logWrite("mosquitto_cmd=" .. mosquitto_cmd)
-----< END FUNCTIONS > ----------------------------------------------------------------------------------------
setRGBWAnimation(device.level)
}Re: zwavejs2mqtt
Sample script for the EUR_SPIRITZ Wall Radiator Thermostat.
Just to show how settings can be changed that don't have a Domoticz device like the lower setpoint.
I included the modes, although 3 of them can be set by a selector device. I enhanced zwabejs2mqtt with the 'Full' mode in the selector switch.
The values in the ZSetHigh and ZSetLow are the setpoint values.
--local ZModeOff = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/64/0/mode/set -m "{\\"value\\": 0}"'
--local ZModeEco = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/64/0/mode/set -m "{\\"value\\": 1}"'
--local ZModeHeat = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/64/0/mode/set -m "{\\"value\\": 11}"'
--local ZModeFull = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/64/0/mode/set -m "{\\"value\\": 15}"'
local ZSetHigh = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/67/0/setpoint/1/set -m "{\\"value\\": 21}"'
local ZSetLow = 'mosquitto_pub -h 127.0.0.1 -t zwavejs2mqtt/Zolder_Thermostaat/67/0/setpoint/11/set -m "{\\"value\\": 17}"'
active = true,
-- active = false,
timer = { 'at 08:31',
'at 18:01' },
logging = {
level = domoticz.LOG_INFO,
-- level = domoticz.LOG_DEBUG,
marker = 'ZT'
execute = function(dz, item)
dz.executeShellCommand({ command = ZSetHigh })
dz.executeShellCommand({ command = ZSetLow })
if item.trigger == 'at 08:31' then
dz.devices('Zolder Thermostaat Mode').switchSelector('Heat')
elseif item.trigger == 'at 18:01' then
dz.devices('Zolder Thermostaat Mode').switchSelector('Eco')
ChriWo
Re: zwavejs2mqtt
Hi EddyG,
Thank you for the sample. But I have one problem I get this Error:
2021-11-22 19:25:00.292 Error: dzVents: Error: (3.1.8) ZT: levelname Eco does not exist
But I have also have not figured out how to get to the 'Full' mode in the selector switch and the ZSetLow.
Can you please explain.
Thank you
Thank you
Re: zwavejs2mqtt
In the 'original' Auto-Discovery selector switch that level is called 'Energy Heat' I changed the levelname to Eco. It fits more what it does.
The Full mode is NOT implemented in the selector switch, if you need it in the script you can use the mosquitto_pub command.
ZSetLow is just a variable which includes a command to set the "Low" setpoint as in the script, because that is not included in the Auto-Discovery.
My script just 'resets' both setpoint twice a day to my default settings, just incase I changed those manually and forget to set them back.
B.t.w. the 'Full mode' is only active for 15 minutes after that the Thermostat sets it self back to the mode "Heat'
hestia
Re: zwavejs2mqtt
I've moved to mqtt auto discovery + zwavejs2mqtt last week.
So far it has been working mostly fine: better stability on some motion sensors than with OWZ: I was loosing them very often with OZW.
Some minors regressions: no kWh on some devices (I need to check the concerned models mostly Qubino), and the LED Controller
Sometimes the "connection" was lost between zwvajs2mqtt and domoticz: I don't know why and what happened exactly
What is good, it's a better understanding of the network, so I could make some changes to get it better.
For the RGBW Controller, the setColor method in DzVents no longer works, so I extend the script above https://domoticz.com/forum/viewtopic.ph ... 37#p282437 like this
local LED_SELECTORS_ID = {887, 1114} -- dummy selector to manage the LED with predefined choices:
local NODES_nodeId = { -- id in dz and relative zwave nodes
[887] = 95,
[1114] = 119
local RGBW_ORDER = -- animation and static color
{ [0] = {0, 0, 0, 0, 0, 0, 4},
[10] = {9}, -- Aurora
[20] = {8}, -- Rainbow
[30] = {7}, -- Storm
[40] = {6}, -- Fireplace
[50] = {10}, -- LAPD
[60] = {1}, -- Pause
[70] = {255, 255, 255, 255}, -- warm white !!!!
[80] = {255, 165, 0, 50}, -- candle / bougie
[90] = {238, 130, 238, 0}, -- violet
[100] = {130, 65, 245, 0}, -- indigo
[110] = {0, 0, 255, 0}, -- bleu
[120] = {0, 128, 0, 0}, -- vert
[130] = {255, 255, 0, 0}, -- jaune
[140] = {255, 70, 0, 0}, -- orange
[150] = {255, 0, 0, 0}, -- rouge
[160] = {227, 137, 7, 251} -- candle white
-- static color
-- setColor(r, g, b, ww):
-- r: Red level: 0-255
-- g: Green level: 0-255
-- b: Blue level: 0-255
-- ww: Warm white level: 0-255
-- zwavejs2mqtt
local NODE_nodeId
logging = { level =
domoticz.LOG_DEBUG,
devices = LED_SELECTORS_ID,
level = LOG_LEVEL
local function setZwavejs(p_NODE_commandClass, p_NODE_endpoint, p_NODE_property, p_NODE_value)
local mqttTopic = mqtt_prefix .. '/' .. NODE_nodeId .. '/' .. p_NODE_commandClass .. '/' .. p_NODE_endpoint .. '/' .. p_NODE_property .. '/' .. suffix
local mosquitto_cmd = 'mosquitto_pub' ..' -t '.. mqttTopic .. ' -m '.. p_NODE_value
local function RGBWAnimation(p_rgbAnimation)
dz.log("RGBWAnimation " .. p_rgbAnimation, LOG_LEVEL)
local NODE_value = p_rgbAnimation
setZwavejs(NODE_commandClass, NODE_endpoint, NODE_property, NODE_value)
local function RGBWColor (p_red, p_green, p_blue, p_warmWhite)
dz.log("RGBWColor " .. p_red .. ' '.. p_green .. ' '.. p_blue .. ' ' .. p_warmWhite, LOG_LEVEL)
local NODE_commandClass = 51
local NODE_property = 'targetColor'
local NODE_value = '{\\"value\\":{\\"warmWhite\\":' .. p_warmWhite .. ',\\"red\\":' .. p_red .. ',\\"green\\":' .. p_green .. ',\\"blue\\":' .. p_blue .. '}}'
logWrite(device.id .. ' ' .. device.level)
local devLevel = device.level
if device.level == 0 or device.nValue == 0 then
device.switchSelector(0).silent()
device.switchOff().silent()
devLevel = 0
if devLevel ~= 170 then
NODE_nodeId = NODES_nodeId[device.id]
logWrite('NODE_nodeId: ' .. NODE_nodeId)
local paramArray = RGBW_ORDER[devLevel]
if paramArray[1] == nil then
logWrite('Level: ' .. devLevel .. ' bad parameters', dz.LOG_ERROR)
elseif paramArray[2] == nil then -- animation
RGBWAnimation(paramArray[1])
RGBWColor (paramArray[1], paramArray[2], paramArray[3], paramArray[4])
hestia
Re: zwavejs2mqtt
I've just had a discussion on the zwave-js / zwavejs2mqtt git and as a reply:
https://zwave-js.github.io/zwavejs2mqtt ... stant-mqttBTW as explained in docs I don't have any plan right now to keep mqtt discovery updated
so, I'm a bit surprised that the solution described here is presented as a future for zwave in domoticz, perhaps I've missed something, or a plan is ongoing...The preferred method of integrating your Z-Wave components with Home Assistant is through the official Home Assistant Z-Wave JS integration, this because MQTT Discovery is limited compared to a native integration and Home Assistant updates frequently break it. Based on this I would NOT RECCOMMEND using MQTT Discovery, I don't plan to keep it maintained in the future.
- heggink
Re: zwavejs2mqtt
Define future...hestia wrote: Thursday 09 December 2021 9:36 Hi,
I've just had a discussion on the zwave-js / zwavejs2mqtt git and as a reply:https://zwave-js.github.io/zwavejs2mqtt ... stant-mqttBTW as explained in docs I don't have any plan right now to keep mqtt discovery updatedso, I'm a bit surprised that the solution described here is presented as a future for zwave in domoticz, perhaps I've missed something, or a plan is ongoing...The preferred method of integrating your Z-Wave components with Home Assistant is through the official Home Assistant Z-Wave JS integration, this because MQTT Discovery is limited compared to a native integration and Home Assistant updates frequently break it. Based on this I would NOT RECCOMMEND using MQTT Discovery, I don't plan to keep it maintained in the future.
The thing is that OZW is pretty much a dead end street. Zwavejs is a much more workable and future proof solution. zwavejs2mqtt is based on zwavejs ('just' adds mqtt). The question then is "what's the most workable integration for domoticz". Zigbee2mqtt and zwavejs2mqtt both (still) support mqtt autodiscovery and only zwavejs2mqtt has announced that the developer has no plans to keep it maintained in the future but that does not mean that it's desupported. Zigbee2mqtt will continue to support mqtt so no problems there.
So then what? 2 options AFAICT:
- either "someone" implements native zwavejs integration into domoticz
- or "someone" takes over the mqtt side of zwavejs to keep it supported
Re: zwavejs2mqtt
What also concerns me is "this because MQTT Discovery is limited compared to a native integration"
I wonder if someone has experience with https://github.com/zwave-js/node-red-contrib-zwave-js
- jvdz
Re: zwavejs2mqtt
This is in comparison with the HomeAssistat addon integration so is all about HomeAssistant I think.EddyG wrote: Thursday 09 December 2021 18:39 What also concerns me is "this because MQTT Discovery is limited compared to a native integration"
Just wondering how having it in Nodered would help with the integration into Domoticz?EddyG wrote: Thursday 09 December 2021 18:39 I wonder if someone has experience with https://github.com/zwave-js/node-red-contrib-zwave-js
Re: zwavejs2mqtt
The backend is Zwave-js API and towards Domoticz I have full control.jvdz wrote: Thursday 09 December 2021 19:09 Just wondering how having it in Nodered would help with the integration into Domoticz?
I could leave out devices that I don't need and include devices that I need.
In the current solution with Auto-Discovery I am missing 1 of the setpoints in my thermostats, and the mode selector switch does not have all the settings.
I have a solution in my dzVents script to change the missing setpoint, and found a solution for the missing mode.
If that missing setpoint and missing mode is accessible via Zwave-js API and nodered then that could be a route to go.
And I just asked if someone has experience with it, just to get more info.
hestia
Re: zwavejs2mqtt
If you're aware of this, I'm half reassured!heggink wrote: Thursday 09 December 2021 17:54 Define future...
Ultimately, this being open source, it all comes down to someone taking ownership for this hence my remark "define future". As long as this is open source, we all are responsible for keeping things maintained. Either that or we all switch to Home Assistant
Anyway I still have some simple switches that don't trigger dzvents and don't report their status (on/off)
So what is working well zwavejs doesn't automatically work well in dz
