Domoticz version: 2026.3
Re: machinon theme
skom wrote: Wednesday 26 May 2021 15:05 On the Machinon Dashboard I would like to move some widgets from Light / Switches Devices and Utility Sensors to Security Devices (there is only a Security Panel) to "clean up" the widgets that monitor various security and alarm elements. Is it possible, because unfortunately I fail? :(
That is not possible in Domoticz (in no theme). You have to install Dashticz to do this.
Another possibility is to use rooms to filter devices based on function. Give the room a function name like "security".
DarkAllMan
Re: machinon theme
Post by DarkAllMan »
Suddenly an update from Machinon! Github is alive again?
https://github.com/domoticz/Machinon
Nephylim
Re: machinon theme
Post by Nephylim »
Is the update still on git hub?
My Domoticz reminds me to update but the version on github still seems to be 1.16.2 from august 2020
DarkAllMan
Re: machinon theme
Are you taking from the same github as me :)
It shows version: 1.17.3
heggink
Domoticz version: 12451
Re: machinon theme
Post by heggink »
For me, machinon on the latest beta is still not working well. Anyone having any luck? Cleared everything I could clear
P1 meter & solar panel
bartolomeo
Re: machinon theme
Post by bartolomeo »
After updating Domoticz to the latest Beta version disappeared those three dots on the switches tile that allows to enter the editing options.
So i thougt, that also upgradind the machinon plugin to Beta may help. Cleaning cache, etc. done, but nothing helps. On the default theme Domoticz everything works fine. What can I do?
heggink
Re: machinon theme
Post by heggink »
My issue was that the fixes require the directory name to be machinon. Mine was called Machinon (capital M). Cleared cache and things worked again.
galadril
Domoticz version: latest
Re: machinon theme
Post by galadril »
its actually stupid that the theme needs to hardcoded the install folder within the theme.. because everybody could install the theme in a different folder...
The theme should be able to use a variable for the install folder of the theme.
As it was previously with 'acttheme' the theme didn't had to know the location..
najtram
Domoticz version: v4.9700
Re: machinon theme
Post by najtram »
Some self made icon's.
GU10
Person
Tuinspot
Daynight (sun/moon)
Daylight (sun/greyed sun)
MagicMirror
Timer
Doorbell
Woman
DimmerRond
Blinds (same as normal but no arrow)
Umbrella
Download link: https://www.dropbox.com/s/9lgx3mmu6741z ... s.zip?dl=0
RFLink Gateway → 433Mhz/KAKU switches
Z-Wave → Z-Stick Gen5+
ZigBee → ConBee II
Bluetooth → Soma Smart Shades
Opentherm Gateway → Remeha iSense - Tzerra boiler
ESP8266+CC1101 → ITHO ecofan RFT
P1 cable → DSMR 2.2+ Landys +gyr E350
LAN → Enphase Envoy
JanZorz
Re: machinon theme
Post by JanZorz »
If you have issues with Machinon theme on latest beta - no "Edit" buttons and so on - you need to link machinon directory to acttheme directory.
ln -s /opt/domoticz/www/styles/machinon /opt/domoticz/www/acttheme
otherwise that directory is not there and not much works.
Cheers, Jan
kiddigital
Re: machinon theme
Post by kiddigital »
JanZorz wrote:If you have issues with Machinon theme on latest beta - no "Edit" buttons and so on - you need to link machinon directory to acttheme directory.
Cheers, Jan
@JanZorz , that (symbolic)link should not be necessary. There has been some changes to the theme processing but also Machinon theme has been updated also. Make sure you have the latest versions.
JanZorz
Re: machinon theme
Post by JanZorz »
kiddigital wrote: Tuesday 04 January 2022 17:12 @JanZorz , that (symbolic)link should not be necessary. There has been some changes to the theme processing but also Machinon theme has been updated also. Make sure you have the latest versions.
Without that link I get many errors on "Developer tools console" in Chrome and half things in MAchinon doesn't work. I have latest Machinon and Machinon beta, neither of them work. I also have latest Domoticz beta.
Cheers, Jan
JanZorz
Re: machinon theme
Post by JanZorz »
Cheers, Jan
Sorry, you are right. I was updating Machinon theme from wrong github address. All works now as expected!
Cheers, Jan
DarkAllMan
Re: machinon theme
JanZorz wrote: Wednesday 05 January 2022 13:27
Cheers, Jan
Cheers, Jan
So what is the one and only updated machinon Github?
Re: machinon theme
DarkAllMan wrote: Wednesday 05 January 2022 14:13
See wiki https://www.domoticz.com/wiki/Machinon_Theme
but it is https://github.com/domoticz/machinon
JanZorz
Re: machinon theme
Post by JanZorz »
waltervl wrote: Wednesday 05 January 2022 14:28
Indeed... I'm now updating from https://github.com/domoticz/machinon.git, but I used to update from the old address.
Cheers, Jan
PeJeWe
Domoticz version: Latest
Re: machinon theme
Post by PeJeWe »
i dont see the theme edit menu in my domoticz tabs
Re: machinon theme
PeJeWe wrote: Wednesday 22 June 2022 22:32 i dont see the theme edit menu in my domoticz tabs
I believe it is a tab in the settings menu. So menu setup - settings - tab theme
PeJeWe
Re: machinon theme
Post by PeJeWe »
waltervl wrote: Wednesday 22 June 2022 23:56
i only find the following tabs in the settings:
System
Log History
Notifications
Email
Meters/Counters
Floorplan
Other
Backup/Restore
madpatrick
Domoticz version: 2026.1
Re: machinon theme
Post by madpatrick »
Do you see the same in your view as this ?
2022-06-23 09_46_54-Domoticz - Instellingen.png (114.13 KiB) Viewed 11211 times
2022-06-23 09_49_08-Domoticz - Instellingen.png (21.86 KiB) Viewed 11211 times
