I have for some time the following error in the log.
Error: Daikin Airco: CConnection_connect, connect request from 'Daikin Airco' ignored. Transport is connecting.
I am using the BRP069A42 and the Domoticz Plugin Daikin Airconditioning (BRP069A42)
Update every x seconds= 60 (tried other values, no changes)
Domoticz 2021.1 (build 137138)
Any suggestions or help are welcome.
Daikin connection error
cirvent
Re: Daikin connection error
Hello
you have the same problem as me,
the new models must go through the daiki api which is on the amazon cloud:
https://github.com/Apollon77/daikin-controller-cloud
Regards,
Cirvent
Regards,
Cirvent
- Bospieper
- Domoticz version: 2022.1
Hi Cirvent,
Althoug my Daikin airco is from 2020 I don't think that the problem solving as you suggested is working in my case. My airco was equipt without the wifi module. I have sold the BRP069A42 after the airco was installed.
The strange thing is that the connection error is not always present in the logs. But when they are there the airco is not or sometimes half responding to the script I use for controlling.
Grz. Piet
Grz. Piet
