Growatt doesn't update anymore
Rolandet
Domoticz version: 2021.1
Post by Rolandet »
he all
For a couple of days now, my Growatt-data isn't updated anymore. Everytime I edit the hardware (change the name a bit) it updates once, but after that..........nothing.
Anybody experiencing the same?
Can anyone point me to the location of the log files?
Custodes Septentrionum
Domoticz version: 2026.3
Re: Growatt doesn't update anymore
What script or plugin is getting the data?
What does the logfile say (menu Setup - Log) ? Any Growatt errors?
Rolandet
Post by Rolandet »
waltervl wrote: Friday 15 October 2021 14:25 What script or plugin is getting the data?
Sorry, I had to be a little more specific.
I'm using this script:
https://github.com/sincze/Domoticz-Grow ... er-Plugin/
It's been working fine little over a year. No Growatt-specific errors in domoticz log (only status updates mentioning succesful login)
Did you install a new version of Domoticz or are you still on stable 2021.1 ?
If you go to the Growatt App/Portal do you still see the expected solar power data?
Rolandet
Post by Rolandet »
waltervl wrote: Friday 15 October 2021 14:51 Did you install a new version of Domoticz or are you still on stable 2021.1 ?
Indeed the stable 2021.1
Ueahz the growatt portal does show data.
Strange.... perhaps Growatt changed something.
You could try to set debug on in the Growatt hardware section and update. See what extra log data is poping up.
By the way: No need to change name to restart a plugin by update button.
Rolandet
Post by Rolandet »
waltervl wrote: Friday 15 October 2021 15:08 Strange.... perhaps Growatt changed something.
Unfortunately even that doesn't show any errors :(
It says (among other things: connection alive
2021-10-16 16:16:03.029 Growatt: (Growatt) Pushing 'onHeartbeatCallback' on to queue
2021-10-16 16:16:03.079 (Growatt) Processing 'onHeartbeatCallback' message
That's why I'm looking for the logfile location. Maybe that shows something.
The log file stores just the same information as what shows in menu setup-log.
It is default switched off.
Rolandet
Post by Rolandet »
waltervl wrote: Sunday 17 October 2021 0:38 The log file stores just the same information as what shows in menu setup-log.
I see. Well, no information in the log :cry:
Any suggestions? :D
Perhaps ask the question in the plugin topic https://domoticz.com/forum/viewtopic.ph ... 83#p221383
If that won't help make an issue in get github repository of the plugin.
Rolandet
Post by Rolandet »
waltervl wrote: Sunday 17 October 2021 16:02 Perhaps ask the question in the plugin topic https://domoticz.com/forum/viewtopic.ph ... 83#p221383
Will do, thanks.
