Sunrise script
jacobsentertainment
Domoticz version: 2021-1
Sunrise script
Post by jacobsentertainment »
I try to reset an switch at sunrise do I need to check this every minute? Looks like timer = sunrise will do the same.
		timer = {
                 'every 1 minutes',
        local Bedtime = domoticz.devices(66)
        on = { timer = { 'sunrise' } }
            Bedtime.switchOn()
Domoticz version: 2025.1
Re: Sunrise script
On timer is sunrise will do.
jacobsentertainment
Re: Sunrise script
waltervl wrote: Monday 04 October 2021 22:29 On timer is sunrise will do.
Thanks for the quick reply :lol:
        local Bedtime = domoticz.devices(191)
        on = { timer = { 'sunset' } }
            Bedtime.switchOn()
rrozema
Re: Sunrise script
Post by rrozema »
Your code lacks an on = specification. That is where you should specify when to run the execute() function.
For example:
timer = {
'sunrise'
execute = function( domoticz, item, triggerinfo}
..... Your code here ....
jacobsentertainment
Re: Sunrise script
rrozema wrote: Thursday 07 October 2021 15:55 Your code lacks an on = specification. That is where you should specify when to run the execute() function.
Like in the first post but instead of every minute at sunrise :lol: Still learning (slow)
rrozema
Re: Sunrise script
Post by rrozema »
