How to install plugins on Windows Topic is solved
LordMax
Domoticz version: 2021.1
Post by LordMax »
Hi!
I have tried to intall some plugins on my Domoticz server running on a windows machine. But I get the error :
Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
I have tried to intall the libpython but I cannot figure out how to do so. I have python 32bit and a domoticz version of 2020.2. Thanks beforehand!
Best regards Max
zicht
Domoticz version: 2023.1+
Re: How to install plugins on Windows
Post by zicht »
try installing python x86 first.
Python Version: 3.5.3 (v3.5.3:1880cb95a742, Jan 16 2017, 15:51:26) [MSC v.1900 32 bit (Intel)]
then puth a python plugin in a subfolder in the plugin directory
restart domoticz and it should be visible in the hardware tab
LordMax
Post by LordMax »
zicht wrote: Thursday 30 September 2021 19:56 Hi
Hi!
I tried to remove the current python and install it again with the version 3.5.3, but I still get the same error. Something weird I notice is that the first time you intstall python domoticz take a bit longer to start, maybe 10 seconds extra, then if you restart it it will boot up almost instantly...
LordMax
Post by LordMax »
Solved! It hade to be installed inside program files x86 instead of users folder!!
user4563
Domoticz version: 2025.2
Post by user4563 »
@LordMax
What had to be installed in the Program Files (x86) folder? Python?
I'm having an issue trying to get plugins to work as well, but in my case Domoticz sees Python and the PluginSystem shows started with no errors but nothing shows in the hardware.
ODroid H4+ / Ubuntu server 24.04 LTS
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Domoticz Scenes add-on in Kodi
