Hoi
I like to collect the information from my SMA converter.
I did the installation curl -s https://raw.githubusercontent.com/sbfsp ... pot-config | sudo bash as described on the GITHUB.
Als configured the Domoticz as described in hardware and pointing the location to "/usr/local/bin/sbfspot.3/SBFspot.cfg"
See attached File
The problem is that I don't see any extra devices in mij list popup.
Als I get the information of my SMA when looking in to the logs.
Any hints, how to solve this, i think i almost there but forgot something
Thanks in advance
Chris
* ArchiveDayData() *
startTime = 614A55E0 -> 22/09/2021 00:00:00
Reading events: 2021-Sep-01
Wed Sep 22 10:25:03 2021: INFO: Done.
SBFspot V3.8.3
Yet another tool to read power production of SMA solar inverters
(c) 2012-2021, SBF (https://github.com/SBFspot/SBFspot)
Compiled for Linux (LE) 32 bit with SQLite support
Commandline Args: -v -ad1 -am0 -ae1 -cfg/usr/local/bin/sbfspot.3/SBFspot.cfg
Reading config '/usr/local/bin/sbfspot.3/SBFspot.cfg'
Wed Sep 22 10:30:01 2021: INFO: Starting...
sunrise: 07:28
sunset : 19:37
Connecting to Local Network...
Initializing...
SUSyID: 125 - SessionID: 942210757 (0x3828FEC5)
Inverter IP address: 192.168.178.108 from SBFspot.cfg
Logon OK
SUSyID: 409 - SN: 3008980029
Device Name: SB4.0-1AV-41 029
Device Class: Solar Inverters
Device Type: Sunny Boy 4.0
Software Version: 03.10.18.R
Serial number: 3008980029
Device Status: Ok
Device Temperature: 0.0°C
GridRelay Status: Closed
Pac max phase 1: 4000W
Pac max phase 2: 0W
Pac max phase 3: 0W
Energy Production:
EToday: 2.427kWh
ETotal: 142.672kWh
Operation Time: 155.37h
Feed-In Time : 148.12h
DC Spot Data:
String 1 Pdc: 0.154kW - Udc: 161.16V - Idc: 0.958A
String 2 Pdc: 1.677kW - Udc: 317.52V - Idc: 5.282A
Calculated Total Pdc: 1.831kW
AC Spot Data:
Phase 1 Pac : 1.717kW - Uac: 242.28V - Iac: 7.138A
Phase 2 Pac : 0.000kW - Uac: 0.00V - Iac: 0.000A
Phase 3 Pac : 0.000kW - Uac: 0.00V - Iac: 0.000A
Total Pac : 1.717kW - Calculated Pac: 1.717kW
Efficiency : 93.77%
Grid Freq. : 50.00Hz
Current Inverter Time: 22/09/2021 10:30:01
Inverter Wake-Up Time: 22/09/2021 07:26:49
Inverter Sleep Time : 22/09/2021 10:30:00
Wed Sep 22 10:30:02 2021: INFO: Done.
sbfspot and SMA converter
