FIBARO Motionsensor V2 Z-Wave Plus with domoticz
remko2000
Post by remko2000 »
I've bought two FIBARO Motionsensor V2 Z-Wave Plus sensors. I use domotiz 2021.1 and a Aeotec Z-Stick gen 5. Adding of the sensors went perfectly in domoticz. Problem is I can only use one type: ' lightswitch, switch, on/off' . This register motion well. I also want to monitor in domoticz if the sensor being tampered or covered.I see a type: ' general, alarm, event' but not a clue how I can use this in domoticz and trigger notifications for this type for example.
I also see another type: ' lightswitch, switch on/off' but this type doesn't have much info in his log and stays off in domitucz when I add this one.
Is there a way to get more info out of this sensor in domoticz so I can use this info to trigger notificatins or use them into blocky?
solarboy
Domoticz version: 2026.4
Re: FIBARO Motionsensor V2 Z-Wave Plus with domoticz
Post by solarboy »
You may need to look in "devices" and find the extra devices created and set them as "used", so the one you are looking for is called "burglar" if I am not mistaken but have a look at any that have the same node ID as your motion sensor and see if they change state when you remove the cover.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),Harmony Hub, Kodi,APC UPS,SMA Modbus,Broadlink,Dombus
