I want to set up a stable system on a pi 3 and a testing system on a pi 4.
I have two Aeotec gen 5 sticks. Is it possible to have my devices in the stable system also connected to the stick on my testing system"?
Jan
using 2 aeotec zwave sticks
JuanUil
- Domoticz version: 4.11083
- heggink
- Domoticz version: 12451
Re: using 2 aeotec zwave sticks
Afaik, you can only pair devices to one controller.
P1 meter & solar panel
solarboy
- Domoticz version: 2026.4
You actually can have a "secondary controller" which could be the same device type.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),Harmony Hub, Kodi,APC UPS,SMA Modbus,Broadlink,Dombus
JuanUil
and how should I install that secondary controller?
mgugu
It has to be registered by the primary controller like any other device. You cannot register a device at a secondary controller.
Check https://www.vesternet.com/pages/underst ... es-devices
