using 2 aeotec zwave sticks
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
I want to set up a stable system on a pi 3 and a testing system on a pi 4.
I have two Aeotec gen 5 sticks. Is it possible to have my devices in the stable system also connected to the stick on my testing system"?
Jan
heggink
Domoticz version: 12451
Re: using 2 aeotec zwave sticks
Post by heggink »
Afaik, you can only pair devices to one controller.
DASHTICZ 🙃
P1 meter & solar panel
solarboy
Domoticz version: 2024.6
Post by solarboy »
You actually can have a "secondary controller" which could be the same device type.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
JuanUil
Post by JuanUil »
and how should I install that secondary controller?
mgugu
Post by mgugu »
It has to be registered by the primary controller like any other device. You cannot register a device at a secondary controller.
Check https://www.vesternet.com/pages/underst ... es-devices
