Because of these files in the docker-compose.yaml file
- /etc/timezone:/etc/timezone:ro
- /etc/localtime:/etc/localtime:roModerator: leecollings
- /etc/localtime:/etc/localtime:rohello,marsflow wrote: Thursday 24 June 2021 12:11 Hi,
the command "sudo systemctl start dzga" does not work anymore, I run it manually and it remains bugged on the command.andCode: Select all
pi@raspberrypi:~ $ sudo systemctl start dzga (after 2 min press CTRL C) pi@raspberrypi:~ $ sudo systemctl status dzga ● dzga.service - Domoticz-Google-Assistant Service Loaded: loaded (/etc/systemd/system/dzga.service; enabled; vendor preset: enabled) Active: inactive (dead)
sudo service dzga start (its good)
why ?
thank you
Hello, merry christmas to all the Domoticz Family!fabry91 wrote: Tuesday 21 December 2021 10:44 Hello everyone,
I'm having some problem to start DZGA on my RS815+ with docker.
I succesfully installed the DZGA docker but when I run "sudo docker-compose -f /volume1/${USER}/Domoticz-Google-Assistant/docker-compose.yaml up -d" it returns with this error:
The default_config file is in the config folder.
Thank you in advance![]()
Your docker cannot access the volume location you specified volume1. Check permissions and or try and move it to another location and confirm docker has permissions to read/write to itfabry91 wrote: Friday 24 December 2021 19:26Hello, merry christmas to all the Domoticz Family!fabry91 wrote: Tuesday 21 December 2021 10:44 Hello everyone,
Anyone could please help me about this problem?
Thank you very much
Hello, and thank you for your reply!vodor wrote: Monday 27 December 2021 13:42Your docker cannot access the volume location you specified volume1. Check permissions and or try and move it to another location and confirm docker has permissions to read/write to itfabry91 wrote: Friday 24 December 2021 19:26Hello, merry christmas to all the Domoticz Family!fabry91 wrote: Tuesday 21 December 2021 10:44 Hello everyone,
Thank you very much
Have found some more error that seems related to this post on GitHub:vodor wrote: Monday 27 December 2021 15:40 I don't know the synology nas devices. I use a qnap myself but that error is pretty much a standard docker error when it cannot find and/or mount a volume. So I would go read up on that if I am you.
Connection to Domoticz refused! Check configuration.Code: Select all
2022-01-11 16:39:09 - DEBUG - Starting new HTTP connection (1): 192.168.0.12:8080
2022-01-11 16:39:09 - DEBUG - http://192.168.0.12:8080 "GET /json.htm?type=devices&plan=0&filter=all&used=true HTTP/1.1" 401 91
2022-01-11 16:39:09 - DEBUG - http://192.168.0.12:8080 "GET /json.htm?type=settings HTTP/1.1" 401 91
2022-01-11 16:39:09 - DEBUG - http://192.168.0.12:8080 "GET /json.htm?type=command¶m=getversion HTTP/1.1" 200 216
2022-01-11 16:39:09 - DEBUG - {
"dzversion": "2021.1 (build 14018)"
}Hello, anyone can help me to solve this problem about the pip installation failed?fabry91 wrote: Monday 27 December 2021 14:53Hello, and thank you for your reply!vodor wrote: Monday 27 December 2021 13:42Your docker cannot access the volume location you specified volume1. Check permissions and or try and move it to another location and confirm docker has permissions to read/write to itfabry91 wrote: Friday 24 December 2021 19:26
Thank you very much
I've cheched all the permission under file station, I set all to "Full Control", the container starts but after some seconds it stops automatically.
docker-compose -f /volume1/docker/Domoticz-Google-Assistant/docker-compose.yaml up -dCode: Select all
sudo /home/pi/Domoticz-Google-Assistant/env/bin/python3 /home/pi/Domoticz-Google-Assistant/Code: Select all
version: '3'
services:
dz-googleassistant:
image: dewgew/domoticz-google-assistant:latest
container_name: domoticz-google-assistant
environment:
- PUID=1010
- PGID=1010
ports:
- 3030:3030
volumes:
- ./config:/config
restart: unless-stopped
What system are you on? I am starting to htink that my pi4 is what's causing the issues.wimmme wrote: Tuesday 05 April 2022 9:06 I run it in docker, works great, just a bug when asking the temperature for a non thermostat device, that's not working.
my docker-compose.yaml:Code: Select all
version: '3' services: dz-googleassistant: image: dewgew/domoticz-google-assistant:latest container_name: domoticz-google-assistant environment: - PUID=1010 - PGID=1010 ports: - 3030:3030 volumes: - ./config:/config - /etc/timezone:/etc/timezone:ro - /etc/localtime:/etc/localtime:ro restart: unless-stopped
I had it working, sort of, so that I could acces 192.168.0.11:3030/setting and could see the settings page, but not anymore. Safari gives an error that server unexpectedly closed the page. Chrome couldn't even locate the page.Apr 15 13:16:28 DomoServer systemd[1]: dzga.service: Service RestartSec=100ms expired, scheduling restart
Apr 15 13:16:28 DomoServer systemd[1]: dzga.service: Scheduled restart job, restart counter is at 10.
Apr 15 13:16:28 DomoServer systemd[1]: Stopped Domoticz-Google-Assistant Service.
Apr 15 13:16:28 DomoServer systemd[1]: dzga.service: Start request repeated too quickly.
Apr 15 13:16:28 DomoServer systemd[1]: dzga.service: Failed with result 'exit-code'.
Apr 15 13:16:28 DomoServer systemd[1]: Failed to start Domoticz-Google-Assistant Service.
username: Edwin
Low_battery_limit: 9
PidFile: ''
auth_pass: Fire2010
auth_user: Edwin
loglevel: Info
logtofile: true
ngrok_auth_token: ****
ngrok_tunnel: true
pathToLogFile: ''
port_number: 3030
ssl_cert: ''
ssl_key: ''
use_ssl: false
userinterface: true
