yesterday I installed latest domoticz-zigbee2mqtt-plugin and now I see lots of
EventSystem: TEMP_HUM_BARO missing values : ID=946, sValue=5.5;56.98;0
errors in my logging ...
besides that, domoticz hangs every 12 hours, load goes high and I had to adjust monit to reboot the system it the load reaches 5 ...
the ID 946 is a zigbee temp sensor that worked fine before this "upgrade"
any suggestion ?
problem domoticz-zigbee2mqtt-plugin
eddieb
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
eddieb
Re: problem domoticz-zigbee2mqtt-plugin
seems a memory leak in the python plugins framework ..
https://github.com/stas-demydiuk/domoti ... issues/698
https://github.com/domoticz/domoticz/issues/4929
