Clear future history Topic is solved
xayide
Post by xayide »
I have had an accident where the date was wrong by a few years and domoticz logged history in the future so to speak. This renders all graphs to simple flatline. How can I remove all history logs for all devices from current time (+ 1minute) and forwards?
I have a few hundred devices so it will be timeconsuming to do this manually and preferable a SQL would help. I found an API that could do this on a per device manner, but it's very time consuming.
erem
Domoticz version: 2021.1
Re: Clear future history
Post by erem »
install sqlitebrowser (https://sqlitebrowser.org)
sudo apt-get install sqlitebrowser
stop domoticz
backup database
open database with sqlitebrowser
from the execute sql tab:
delete the future records from the *_calendar tables
with this statement for each *_calendar table that has future dates
delete from <tablename>_Calendar
where date > '2021-08-31'
example
delete from MultiMeter_Calendar
don't forget to write changes
start domoticz
Regards,
Rob
xayide
Post by xayide »
Wow thank you. So it is an ordinary sqlite-db. I was thinking along the lines of using the webapi but felt on the number devices…
/json.htm?type=command&param=deletedaterange&idx=IDX&fromdate=FROMDATE&todate=TODATE
Users browsing this forum: Bing [Bot] and 0 guests
