TP-Link smart plug HS100/HS110
nosehook
Re: TP-Link smart plug HS100/HS110
Hi Richard,
Please have a look here:
https://github.com/J0hnMatrix/domoticz- ... 0-hs110-v2
This should do the trick.
Regards,
Freek
Regards,
Freek
Pi3 Domoticz | RFXcom 433E | KAKU/COCO |Harmony Hub | Samsung TV | HS100 | HS110| HUE | Tradfri | Tado| Xiaomi |sensors | scripts| Pi3 Node Red | Pi2 SDS_011 + MH-Z19B | PiAware (zero) | Pi2 breadboard with Node red and Domoticz
ricvee
- Domoticz version: Stable
Hi Freek,
Unfortunately the same result.
So right after I installed the HS110 in setup-hardware, domoticz crashes, and I can only bring it back to life when I delete the plugins,
and delete the database restart and restore the database.
Thanks for the effort,
Richard
Richard
Report button for energy cost etc?
First post on this thread.
I'm using the plugin on domoticz on pi.
Is ther any way to add the Report button to get energy cost as with other power devices?
ajay100
- Domoticz version: 4.10717
Hi @joew, sorry I haven't seen the Report button functionality and so I don't know the answer to your question, hopefully someone else will chime in.
Cheers - Andrew
Cheers - Andrew
- Domoticz version: 2026.3
The report function is only available for some device types.
For electricity it is for example available on the General (243), Subtype Kwh (29) device.
https://www.domoticz.com/wiki/Developin ... vice_Types
I did not read through all this topic but the plugin https://github.com/J0hnMatrix/domoticz- ... 0-hs110-v2 does not make use of this device subtype.
woempiej
- Domoticz version: 2021.1
I'm using the same steps as ricvee do and having the same problems.
- No plugin showed up in pp-manager list
- If a copy the plugin in the /home/pi/domoticz/plugin folder and install it from the hardware list, domoticz crashes until I'll remove the plugin
woempiej
HS110 isn't connecting anymore because TP-Link closed port 9999 in the new firmware.
ccounotte
Hello everyone.
I'm trying to get new HS110 plugs but can't find any. Instead I found a new TP-Link KP115 which are actually a lot cheaper.
Wondering if the plugin will also work with those?
Thanks.
Thanks.
Alain
- Domoticz version: 2022.1
I don't think they are available with an EU plug right now.ccounotte wrote: Sunday 28 November 2021 21:48 Hello everyone.
Thanks.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
ccounotte
Purchased 2 from Amazon yesterday, should get them in 1 to 3 months as per delivery information lol. I can post a link if it's allowed? Plug is for France by the way.Alain wrote: Tuesday 30 November 2021 6:04 I don't think they are available with an EU plug right now.
Alain
Please do.
Alain
Thanks.
ajay100
I purchased a KP115 in Australia (AU$29) and can confirm it is operating perfectly and exactly as per the HS110. It's quite a bit smaller, about the size of a typical USB charger.
In this case I'm using the plugin. I have it on long term test measuring my fridge power usage.
reddo
Anyone who can give me a step by step install ? I did this years ago for the HS100 and 110 the simple way (sending commands to the switches), updated over a year ago to the plugin so I could ready the power etc from the 110 but ... now did a fresh install and cannot get it to work
Running a RPI3 with Raspberry OS with the latest Domoticz.
Thanks !!
Reddo
Thanks !!
Reddo
-Domoticz-RFLink-PVoutput-Solarmeter-SBFSpot-ESPEasy-Volumio with spotify connect-
ajay100
Hi @reddo, I see you were part of this thread early on. I have information about getting the plugin working on page 7 of this thread and ongoing. The stand-alone script is described on page 5. Logs are helpful for trouble-shooting, as we don't know which part you can't get to work.
Cheers - Andrew
Cheers - Andrew
reddo
Thanks ! After grinding through all the stuff I did use this one which works well !! Thanks for the reply Ajay100 !ajay100 wrote: Thursday 17 November 2022 3:37 Hi @reddo, I see you were part of this thread early on. I have information about getting the plugin working on page 7 of this thread and ongoing. The stand-alone script is described on page 5. Logs are helpful for trouble-shooting, as we don't know which part you can't get to work.
Cheers - Andrew
viewtopic.php?p=219864#p219864
I do however still get these errors while all seems to be working well...
2022-12-03 00:19:19.281 Error: tplink: Traceback (most recent call last):
2022-12-03 00:19:19.281 Error: tplink: File "/home/pi/domoticz/plugins/domoticz-tplink-smartplug/plugin.py", line 290, in onHeartbeat
2022-12-03 00:19:19.281 Error: tplink: _plugin.onHeartbeat()
2022-12-03 00:19:19.281 Error: tplink: File "/home/pi/domoticz/plugins/domoticz-tplink-smartplug/plugin.py", line 137, in onHeartbeat
2022-12-03 00:19:19.281 Error: tplink: self.update_emeter_values()
2022-12-03 00:19:19.282 Error: tplink: File "/home/pi/domoticz/plugins/domoticz-tplink-smartplug/plugin.py", line 205, in update_emeter_values
2022-12-03 00:19:19.282 Error: tplink: Devices[2].Update(nValue=0, sValue=str(round(realtime_result['current'],2)))
2022-12-03 00:19:19.282 Error: tplink: KeyError: 2
