Because my pi 3 died I have bought the pi 4 and start the installation.
For using controlllicz I installed the certificate with certbot. But I used the wrong command. I used auto certbot for apache. And now if I use my domain name I get on the apache site.
I think the auto install made a change to some configuration, but I do not know where to start.
I de-installed certbot and apache, but still I get the apache site when I surf to my domain.
Somebody know where I have to look?
Verstuurd vanaf mijn SM-G991B met Tapatalk
433 to apache in stead of domoticz
Raspberry Pi 4 - Raspbian bullseye - Python 3.9 - stable
Dashticz on apache2 - Mqqt - node red
Zigate - USB Tll - Philips hue - Ikea - Innr - Xiaomi - TPlink - Nest -v3
- Domoticz version: 12467
Re: 433 to apache in stead of domoticz
Assuming you are using Raspberry Pi Os/debian
Certbot asked you if you would like to redirect http traffic to https.
A yes will create a line like:
In the file:
/etc/apache2/sites-available/000-default.conf
you could comment, or remove that line.
Certbot also created a new file, something like: default-ssl.conf
You can disable this 'ssl site' as:
Redirect / https://.....
sudo a2dissite default-ssl.conf
Tank u for a answer. I fully removed apache. The files you are talking about do not exist anymore.
even the var/www/ directory is gone and still getting the apache webpage....
(cookies cleared)
- HansieNL
Looks like the page is cached.
Try clearing cache or try to load the page in private browser mode.
Blah blah blah
That did not work too. I will reinstall again.
