Deconz cross-eyed text in hardware
Thuis
Post by Thuis »
Hello, i've been using deconz for a while now, with lots of different zigbee switches, sensors, lights etc.
I have a question, if i delete deconz from hardware and then put it back in, do the IDX come back the same or will they be different?
I ask this because i have a rare thing in hardware, it is displayed 2 times see picture. It works, but it looks ridiculous.
I dare not to try, if i do delete it says all my devices will be deleted, hence the question, if all devices come back as the same IDX, if i reinstall the plugin?
Oh wait, if i use the default Domoticz Weblayout, it is not cross-eyed, but it is double, see picture:
Thanks in advance.
If you can not handle a computer, you buy a Mac. If you can not handle domotica, you use Homeassistant!
Thorgal789
Re: Deconz cross-eyed text in hardware
Post by Thorgal789 »
Hello, can you take a look in the plugin folder to see if you have not 2 time the plugin ?
I think not, it s possible but when you delete en hardware, domoticz delete all devices associed with it, and not sure you will have the same if you re-add the hardware.
Thuis
Post by Thuis »
Ok thanks, no i have only one plugin.
But i now know, not to remove and reinstall it, thanks for that.
i learn to live with it.
Thorgal789
But I have already see this kind of issue, you are sure you have not 2 time the plugin in the hardwre list ? or 2 time in the "plugins" folders, even under different name ?
