I now there are all kind of plugins, only i do try to use les plugins...
Is there someone that have node red flows to read all the tasmota data from a device?
Love to have the all the data from a tasmota device separate into domoticz device with a flow
Reaseon very stable and i do not use any plugins.
Hope there is some that can share? because my node red is very weak.
Read value from tasmota with Node-red
Derik
- Domoticz version: BETA
- FireWizard
Re: Read value from tasmota with Node-red
Hello @Derik,
Do you know that Node RED has a node for Tasmota
See: https://flows.nodered.org/node/node-red-contrib-tasmota
- sincze
- Domoticz version: 2024.4
Works like a charm indeed.
and FAST!
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Derik
NoFireWizard wrote: Monday 12 July 2021 17:54 Hello @Derik,
Thanks for this..Looking great when i have holydays i give this a try..
Only do i mis the power usage total and actual?
Derik
And instead with domoticz?
Do i mis in the flow a domoticz in?
